Tacoma Tow Package
Discussion in 'Canada' started by vansrv7a, Nov 2, 2013.
  1. Nov 2, 2013 at 8:28 PM
    vansrv7a
    vansrv7a [OP] New Member
    Good Day Folks,
    I'm looking at buying my first truck. I have my eye set on a used Tacoma 4X4 TRD Sport Crew Cab.
    I understand that the standard tow package is for 6500lbs. Is it possible to get an upgrade to tow heavier loads? I'm looking at buying a 28' boat as well. Dry weight is 6510lbs, so you can see once I add in the trailer and "wet" considerations I'm probably upwards of 8000-10000lbs towing weight.
    Thanks
  2. Nov 3, 2013 at 2:56 AM
    eastcoastcowboy
    eastcoastcowboy just sittin' in the corner, havin' a beer
    Brian
    Redneckville, NB
    '15 Skewped!!
    Weathertecs, 265/70/17 Duratracs, Trifecta Tonneau
    6500 is the upgraded tow package. The standard tow rating of these trucks is 3500.
    My opinion, you can't safely stop a 10000 pound load with a truck this small.
  3. Nov 3, 2013 at 3:24 AM
    WoadWunner
    WoadWunner Well-Known Member
    Peter
    Bridgetown, Nova Scotia
    17 Accesscab TRD Offroad Inferno
    Tonneau Cover, Devils Horns on the way, Blackened Grill, LED Low beams and Fogs, weathertecs
    I agree, brakes and stopping would be the issue.
  4. Nov 3, 2013 at 4:30 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    You'd be better off in a Tundra or some other full size.
  5. Nov 4, 2013 at 9:11 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^This.
    Very very dangerous to exceed the weight ratings on vehicles. These are generally the more interesting calls I get in my job.
    Usually someone ends up buck ass naked on a spine board with an express trip to FootHills Emerge.
  6. Nov 4, 2013 at 12:14 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    For that amount of weight.... GET A FULLSIZE truck.
    DO NOT even attempt to tow that much weight with a tacoma. It's extremely UNSAFE.
    In fact, it's probably ILLEGAL. In my state of PA - you are given a registration based on your vehicles GVWR. If you are caught towing outside of your allowed 'registration' amount - TICKET!!!
  7. Nov 4, 2013 at 10:13 PM
    BDBSoCal
    BDBSoCal The Safety Guy
    Brad
    SoCal
    Silver 2008 SR5 V6 4x4 TRD Sport
    Just starting...
    You shouldn't go over the specified towing weight without a really good reason.
    (Seriously though, you're going to want to tow with fuel, food, lifejackets, etc. You need a 3/4 ton truck at least.)
