Tacoma Towing Micro Minnie 1706FB
Discussion in 'Towing' started by Sucksqueezebangblow, Nov 20, 2023.
  1. Nov 20, 2023 at 3:01 PM
    Sucksqueezebangblow
    Sucksqueezebangblow [OP] Well-Known Member
    Drake
    2017 TRD Off-road in Quicksand
    Stock as hell
    Howdy!
    Will be pulling out a Micro Minnie 1706FB over Thanksgiving, I know these trucks arent meant for towing has taller leafs in the rear (ARB OME)... and my 33" Load Range E Falken Wildpeaks may not help... but yall think I will be good?
    Towing it only 40 miles there, then 40 miles back, gunna have a wife, and camping gear (beer/water/food etc.) only issue is, its pretty damn hilly... dont want to blow up my truck... have the tow package I guess that may help a bit
    Cheers
  2. Nov 20, 2023 at 3:06 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    1. Get a brake controller and get it installed before you go. You might want to hop on that 1-day shipping right now.
    2. You won't blow up the truck. Pack that trailer light, if possible don't fill the water tank until you are at camp. Take it slow, its your first time pulling that trailer. Also try to time it so that you have 3 hours of daylight remaining when you arrive. Nothing sucks like backing and leveling an unfamiliar trailer after dark.
    3.Read up on the towing bible thread tonight after you have ordered your brake controller.
    Enjoy your holiday.
  3. Nov 20, 2023 at 3:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The transmission will go long before the engine.
    if you have an Auto, tow in 4th, or what ever gear it takes to keep the transmission from shifting all the time.
    If it's a manual, keep it above 2,500 rpm.
    These engine don't even start to come alive until about 3,000 rpm.
    The 3.5 will turn more RPM the the 4.0 in my truck.
    And I tow mine in 4th pushing 3,000+ rpm steadily. No issues yet.
    I'm at 167k miles.
  4. Nov 20, 2023 at 3:09 PM
    Sucksqueezebangblow
    Drake
    Stock as hell
    Awesome! I only plan to do this once, maybe twice a year at the most
    I am actually renting the trailer, wife is sick of sleeping in a tent so when I take her to the desert she wants a trailer
    No backing up needed, out in the desert so just pull along side everyone else and pull away when its time to leave
    I will look into a brake controller as well, might be a good idea for peace of mind
  5. Nov 20, 2023 at 3:11 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Looks like it's well within the towing capacity, as long as you don't max it out with cargo.
    I'd avoid loading things in the bed, but rather load as much as possible in the trailer, ahead of the axle.
    Keep it in S4 or maybe S5 if you're on a flat road. Don't try to accelerate fast. Just take your time and plan ahead. Don't exceed 65 MPH.
    +1 on the brake controller!
  6. Nov 21, 2023 at 5:26 AM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    For a couple times a year, you should be ok for short distances. I had to upgrade to a full size after my first trip with my MM1708. It was not fun.
  7. Nov 21, 2023 at 8:34 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    The trailer is under 3000 lbs. and you’re only going 40 miles and hills or not this ain’t a big deal. Just load up the trailer and go. You learn as you go. All of us started towing not knowing shit. We just hooked up a trailer and went. If it has brakes (I assume it does) then yes hook up a brake controller. This just really is no biggie. Don’t worry about it, just do it. Enjoy the journey.
  8. Nov 22, 2023 at 9:52 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I tow a micro minnie 2108 and it handles it. Brake controller and weight distribution hitch are musts. I try to keep it under 60 and tow in S4 with ETC button pressed.
    MGMDesertTaco likes this.
  9. Nov 27, 2023 at 11:30 AM
    Sucksqueezebangblow
    Drake
    Stock as hell
    Update: It did fine, no brake controller or special hitch. Handled it like a champ no worries
    Brake controller and a bigger trans cooler would have been nice, but didn't absolutely need it
    These trucks tow fine, even with bigger tires and some suspension thanks all for the help!
    MGMDesertTaco, Da Voke and Sprig like this.
  10. Nov 29, 2023 at 6:43 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
  11. Nov 29, 2023 at 7:35 AM
    PatZ
    PatZ Active Member
    2023 Ford F150 Lariat
    Get the brake controller. You don't need a special hitch or trans cooler, but you do need a brake controller. It's not just for safety, but you are legally required to have one at those weights. They don't have to cost much and the install is pretty simple.
