Tacoma Traction Issues Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by memario1214, Dec 20, 2009.
  1. Dec 20, 2009 at 12:02 PM
    memario1214
    memario1214 [OP] Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Well, the rash of accidents over these last couple weeks has led me to start this thread. It seems to me that this whole new plastic bed idea has kind of turned out to be a bad thing for those of us who reside where it snows/gets icy. I have personally noticed that it takes very little effort to break my truck loose, and once it does, it gives me about 2 tenths of a second to realize and correct. Is anyone else, even those who have stayed out of the ditch, having these sorts of issues? Also, it hasn't been nice enough for me to run at the track yet, but these trucks seem to have some serious traction issues there as well. It just seems very pronounced and unsafe from what I see... Alright, discuss.
  2. Dec 20, 2009 at 12:05 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    No issues here. I run with studded winter tires and 4x4 when the going gets rough. I also go slow in poor conditions. The traction control really helps when the roads get greasy. I blame a lot of it on speed and improper tires for the conditions
  3. Dec 20, 2009 at 12:10 PM
    Voos
    Voos Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    Been driving in the snow since I was 15.... Experience goes a long way. No issues here
  4. Dec 20, 2009 at 12:13 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Well yeah, so have I and I have yet to be in an accident (Knock On Wood)... Maybe it's just me, but it just seems that this Taco is a little more skittish than other trucks, including my '03. Might be wrong, and it seemed that these accidents lately may be attributed to it.
  5. Dec 20, 2009 at 12:13 PM
    HooknBar244
    HooknBar244 Member
    Derek
    Sheppton/Hazleton PA
    08 TRD-Offrd
    Revtek lift 33"Nitto Terragrappler on 17"Gear wheels
    Had mine out last night in the snow. At times the ass end would break loose but that is expected on ice and snow with a heavy pedal. I thought it was better than any other p/u I have had.
    Good tires and throttle control can get u thru the worst.
  6. Dec 20, 2009 at 12:18 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    My truck, while not having the plastic bed probably has less weight on the rear wheels than the 2nd gens and I don't have much problem. I have to blame the drivers as well, these are pickup trucks with naturally light rears, they will handle differently than an SUV because of the weight distribution.
  7. Dec 20, 2009 at 12:25 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Pick-up trucks are generally light in the back end. On my old truck I used to fill the bed up with snow for added traction. I have a canopy on the Tacoma which helps alot. When things get really slick I throw in a couple of sandbags. Use the 4WD...that's what you got it for. Be careful out there!!!
  8. Dec 20, 2009 at 12:34 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Put 4 or 5 bags of sand/rocks what ever you want in the bed and you will have less of a problem. All pickup trucks are lighter in the back end than a regular vehicle. The composite bed has nothing to do with it. I drove for years in the snow/ice and never had an issue with any vehicle breaking loose (only happened when I wanted it to).
    A light foot on take off will help as well.
  9. Dec 20, 2009 at 12:37 PM
    dwalden2
    dwalden2 Your mom goes to college
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, BFG KM2 tires, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    The backend is light, but like SS said, I blame it on the drivers. Mine only breaks free when I tell it to.
  10. Dec 20, 2009 at 12:51 PM
    madisonsfinest
    madisonsfinest Addicted to my DSLR
    Madison, WI
    2010 DC OffRoad 4x4 Debaged
    Factory Roof Rack Avid Offroad Light Bar 16" XD Hoss Truxedo LoPro QT Window Tint Autobot Emblem w/Autobot Shifter Color Matched Grille
    I noticed in 4x2 the tail likes to give out. In 4x4 I have no problems. I put 3, 70lb tube sand bags in the back and that keeps it pretty straight in 4x2. I haven't really had to use the 4x4 since adding the weight, unless I need to get going from a stop in some snowy/icy conditions.
  11. Dec 20, 2009 at 1:19 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Only breaks loose when my tires are getting thin.....
    It's a TRUCK with a light rear-end.
    All 2WD (rear wheel drive) vehicles break loose in wet/snow - especially if you get on the gas too hard for conditions.
    You can do one or a combination of the following:
    Get used to the trucks personality - don't use the gas so hard
    Air down your tires a few lbs
    Put weight in the bed
    Get new or better tires
  12. Dec 20, 2009 at 1:27 PM
    MGRS
    MGRS Well-Known Member
    08 6spd TRD 4x4
    I recently wrecked mine. The thread is located on this forum.
    I should have been in 4WD when it happened. I only had vic. 300 lb in the back and my air pressure was too high for conditions.
    I drove a 2x4 Ford Ranger up in OH for years with no problems during the winter. This was the first time I had my Tacoma in snow, having lived in AZ and TN for the balance of my time owning it.
    Call me crazy, and it might be lack of experience with the Tacoma in snow, but that accident would not have happened had I been driving the old Ranger. The Ranger had very thin (225) tires, which may have been a factor.
  13. Dec 20, 2009 at 1:29 PM
    JONNY TACO
    JONNY TACO Well-Known Member
    PA.
    DARK METALLIC GRAY -DOUBLE CAB SHORT BED
    ADVANTAGE TONNEAU COVER,TOYOTA BED LINER, POP&LOCK TAILGATE LOCK, SIDE TUBES, WIFE IN PASSENGER SEAT
    I was driving in 10+ inches of snow yesterday and today. Used 4 wheel Hi- NO PROBLEMS. Don't know what the problem is with the stock tires. Was at my friends farm last weekend. 3 inches of snow than rain that 14 degrees. Turned the snow into a slosh- icy mess. Had to go up an old logging trail in that slop. AGAIN- NO PROBLEMS. No complaints about the truck or tires in any condidion I encountered so far.
  14. Dec 20, 2009 at 2:28 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Every time it snows I do the Balsa wood mod on my foot.
    I switch out my lead foot for one of...you guessed it. Balsa wood.
    Never had an issue since. :)
  15. Dec 20, 2009 at 2:35 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I think most are not using 4x4 when necessary... How a 4x4 truck handles snow and ice in 2wd is irrelevant...
    Why is everyone so scared to put their truck in 4x4 when there is snow or ice on the road... What did you buy it for?
    In 4 Hi, you have to make a bunch of tight turns on absoluteley dry pavement to cause any issues...
    I live here at 9500 feet in the CO mountains and I use 4 Hi all the time... If it's snowing or slick, I use 4 Hi... No issues... These trucks handle snow and ice really well in my opinion...
    PS - I usually keep ~ 200 lbs of tube sand in my bed when I know it is going to snow...
  16. Dec 20, 2009 at 3:38 PM
    Janster
    Jandy
    Lancaster, PA
    Honestly?
    Most of the comments here have been.... "Oh, I drove through 6"+ without any problems"
    I'd hate to say this, but.... Driving through the thick unplowed snow is the easy part.
    The worst and most challenging part, is driving on Ice AND hard packed snow on the roadways. Knowing how SLOW you need to ge prior to approaching a turn so the wheels will actually make the turn and not go straight. Knowing how to utilize engine braking so you don't have to use the brakes unless you absolutely have to. Knowing how much room to leave behind the person in front of you and resisting the urge to go any faster. Knowing how fast NOT to go to prevent skidding, fish tailing, etc. Once you fishtail, knowing how to handle it safely without freaking out.
    Most of everything mentioned above - has a lot to do with YOU as the driver - not the truck.
    So, go ahead and complain about the Tacoma's in the snow if you must. Gimme the keys and I'll show you how to drive it. ;):p:p
  17. Dec 20, 2009 at 3:42 PM
    TL697
    Jacksonville, FL
    I agree... When it snows, I travel 20 miles each way to work on State Hwy throught the mountains that is packed snow an ice... Everything you mentioned + 4 Hi + some weight in the bed = No issues in the snow...
  18. Dec 20, 2009 at 4:11 PM
    roddy1
    roddy1 Active Member
    Its all in the tires when it comes to winter driving. If your running the factory tires compared to a set of snow tires, you will see a big difference in traction.
    And for the couple of dollars, pick up 5-6 sandbags for back there and run a few psi lower in the rear tires.
  19. Dec 20, 2009 at 4:13 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    My Taco could have better traction in the rain, but I'm still happy with it.
  20. Dec 20, 2009 at 4:14 PM
    JDMcQ
    Actually, it's all in the driver. People drive everyday in the snow on all season tires without issue. You just need to know what you are doing and don't get cocky or impatient.
