Tacoma Trailering in Colorado
Discussion in 'New Members' started by tomis916, Oct 21, 2018.
  1. Oct 21, 2018 at 4:04 PM
    tomis916
    tomis916 [OP] New Member
    Tom
    2001 Toyota Tacoma Xtra-Cab 4x4 TRD
    I've owned my Tacoma for 17 years, but just now joined TW.
    I've kept my 2001 pretty much stock and love it, but I bought a travel trailer (T@b) this summer. I have enough horsepower for my taste, but the suspension is struggling a little so I started to dig around the forum. There is a ton of good stuff here. I probably should have given it a read before I went and bought the trailer, but I'm learning now. Lots of wisdom here.
    Thanks everyone for your contributions.
  2. Oct 21, 2018 at 4:07 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
  3. Oct 21, 2018 at 4:10 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
  4. Oct 21, 2018 at 4:11 PM
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    Slap some Firestone or Air Lift bags on there and you should be all set. Just be sure to plumb them individually.
    Run a temp probe to keep an eye on transmission fluid temps. The Tacoma can run pretty hot while towing, so make sure you watch temps to prevent damage.
    Other than that have fun! Do yourself a favor and get some books on tape so you’ll have something to listen to as you chug up to the Eisenhower at 25 :D
    Oh, and just FYI, not sure how big your travel trailer is, but a weight distribution hitch with sway control will make towing a much more comfortable experience.
  5. Oct 21, 2018 at 4:30 PM
    tomis916
    Tom
    Your advice pretty much matches my research. I'm planning on the Firestone, but I've also been advised that I probably should refresh the shocks (Bilstein 4600), rear leaf springs (OEM) and I'm guessing the front coil springs too (not sure, but I think this may be OEM also). It makes sense to me that after 17 years and 87,000 miles (I don't drive much), I probably should refresh if I'm going to start trailering.
    I was ignorant of the transmission heat issue until I started to read the forum. It looks like I should get an aux cooler and gauge.
    As for taking it easy over the passes, the Tacoma takes care of my speed on the climbs and my wife keeps a close watch on the descents! :argue:
    Sum1 Else and buckhuntin-tacoma like this.
  6. Oct 21, 2018 at 4:47 PM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    I’ll also hop in the ring and suggest firestone airbags. I have them on my taco for my camper setup.
    If your going to refresh your suspension I’d go with 5100s over 4600s
  7. Oct 21, 2018 at 5:09 PM
    tomis916
    Tom
    I'll have another look at that. It was my understanding that the 4600s were good if you have no plans to raise the truck.
    Sum1 Else likes this.
  8. Oct 21, 2018 at 7:14 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW...Ride Rite air bags!!
    Sum1 Else, tomis916[OP] and irayfz6 like this.
  9. Oct 21, 2018 at 8:14 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  10. Oct 22, 2018 at 4:30 AM
    Sum1 Else
    Sum1 Else Well-Known Member
    Welcome to TW
  11. Oct 22, 2018 at 8:15 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW!!
    :hattip:
