Tacoma transmission 04 ran in water.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toyogmom, Dec 28, 2019.
  1. Dec 28, 2019 at 6:16 AM
    Toyogmom
    Toyogmom [OP] New Member
    Will it need rebuild?
  2. Dec 28, 2019 at 6:20 AM
    Toyogmom
    Well, the fluid mostly leaked out although I know it was run thru a river.
  3. Dec 28, 2019 at 6:26 AM
    Toyogmom
    Transmission fluid was not milky , The water ran out, it has also been leaking fluid.
  4. Dec 28, 2019 at 6:37 AM
    Toyogmom
    Too late it has been driven, It was driven home from the river.
  5. Dec 28, 2019 at 6:43 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    “Run through a river.” How deep was the river, 6”, 12”, 18”, more? Why are you concerned? Did water get in the cab?
  6. Dec 28, 2019 at 6:45 AM
    rnish
    Tacoma 2nd gen
    If it still drives then most likely its ok. I would drive it a lot to get the truck components hot enough to drive the water off.
  7. Dec 28, 2019 at 6:57 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it had water in it it would have been on the bottom of the pan and the trans would have already sucked it up.
  8. Dec 28, 2019 at 7:00 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    He means don’t drive it anymore until you change your fluid out. If your not comfortable doing the job take it to whatever service station you like then drive it and see how it goes.
  9. Dec 28, 2019 at 7:15 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Being submerged in water destroyed the auto trans in my 95 4Runner. Changed fluid, was OK for a thousand miles, started slipping and died shortly thereafter.
    Ritchie likes this.
  10. Dec 28, 2019 at 8:55 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
  11. Dec 28, 2019 at 2:24 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Personally I would take it to a shop with a machine and do a real flush if it was working fine before the "incident". I'm going to guess you were not the one that drove it across the river so the actual details are probably a bit sketchy. The water has to be pretty high to get into the transmission. If it was driven in deep water it probably would be a good thing to have someone drain and refill the read diff too.
  12. Dec 28, 2019 at 5:30 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Someday.
    Wyoming09 likes this.
  13. Dec 29, 2019 at 1:06 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just How did we get to this point?
    Just what vehicle are we dealing with? 4x4 or 2WD?
    Not only the Transmission transfer case and differentials might need looked at
    Someone Drove the Truck across a river??
    The truck went into the water without help? Early Ice exploring ??
    It got out under it`s own power ??
    The water was so deep it had to be winched out a few hours days later??
