Tacoma Transmission Flush 80k miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ethan8484, Apr 16, 2024.
  1. Apr 16, 2024 at 9:47 PM
    Ethan8484
    Ethan8484 [OP] Member
    2016 Tacoma Limited
    Do you guys think it is a good idea to flush a transmission at 80k miles? Or would you just recommend a drain and fill? Currently sitting at 83k miles with no transmission fluid work done to it.
    Black97v6MT likes this.
  2. Apr 16, 2024 at 10:08 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    I do a drain an fill every year since I tow during the summers. Cheap insurance. Did the first one at 65k.
    helix66, Chew, Stevie17 and 2 others like this.
  3. Apr 17, 2024 at 4:24 AM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I had dealer flush and fill mine with their fancy machine at 85K. All good.
  4. Apr 17, 2024 at 4:49 AM
    lynyrd3
    Bill
    East Central Upstate NY
    I had mine done at Toyota and luckily it’s ok . The first thing you should do is drop the pan and clean the magnets before a flush . Toyota did not do this even after the service manager told me they would .Gunk and metal filings could be pushed into the valve body and clog things up . Your better of with multiple drain and fills .
  5. Apr 17, 2024 at 4:55 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Classic dealership move…
    22Coma6MT and drizzoh like this.
  6. Apr 17, 2024 at 5:28 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    How is the machine going to dislodge that? I'd like to know why you think that. The flush machine goes inline on the cooler hoses, and the pressure from the pump in the transmission is what moves the fluid through the machine, to exchange the fluid. The machine itself does not produce pressure.
    By your logic, then even the fluid that is already in the transmission, should dislodge it just by the act of driving the truck.
    I've been a tech for 22 years and a master tech for the last 16. I have never seen that happen. And have never seen a transmission failure due to this. I'm sure @Bishop84 can attest to this as well.
    And @Ethan8484, to answer your question. Yes, flush your transmission. I did mine at 80K.
    Rusty66, Gfenza89, TX BAJA1 and 11 others like this.
  7. Apr 17, 2024 at 5:51 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I dropped my pan @ 127K
    There were no "filings" on the magnets, just a meaningless amount of negligible buildup. The screen too, was for all intents and purposes, immaculate.
    Dropping the pan and purchasing the 'filter' was a waste of time and money.
  8. Apr 17, 2024 at 10:34 AM
    lynyrd3
    Bill
    I’m just stating what I have read about auto transmissions . I’m not 100% but I might have gotten my info here on TW :notsure:
    I’m assuming that flushing means all fluid is being pushed out through the transmission including what’s in the pan and clinging to the magnets .When flushing isn’t it at a bit higher pressure than regular driving ? I’m no mechanic :anonymous:
    @gearcruncher
  9. Apr 17, 2024 at 10:46 AM
    jmneill
    SE
    Assuming for a moment you're actually serious, nothing is coming off those magnets in a "flush"
  10. Apr 17, 2024 at 11:05 AM
    rolled93slc
    Jerry
    Lynchburg VA
    TW is full of bad transmission information. And a lot of hate towards "Stealerships". The pressure that is on the trans flush machine is the pressure the transmission pump is producing. Usually in the 20 psi range at idle. There is very little pressure in the pan from the return flow. And the stuff that get stuck to the magnets is hard to get off. It takes some effort to get if off, wiping with a rag.
    The issue people run into, when doing a flush, is on hight mileage transmissions. Like over 150K. Those you run the risk of the flush removing the varnish and build up that's in the drums, and passages. That then gets trapped in the solenoids, and causes shift issues.
    TX BAJA1, kahanabob, bulalo and 3 others like this.
  11. Apr 17, 2024 at 11:18 AM
    rctodd51
    rctodd51 New Member
    Ralph
    2015 Tacoma 4 cylinder
    What’s the average cost to have a Toyota dealer flush the transmission on a 2015 four speed automatic? I just purchased this Tacoma with 48,100 miles and plan on keeping it for a long time.
    thanks
  12. Apr 17, 2024 at 11:19 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    320 was the last time I checked
  13. Apr 17, 2024 at 11:31 AM
    rolled93slc
    Jerry
    Lynchburg VA
    It's really going to depend on where you live. Major metro areas are going to be hight than smaller towns. And some states are higher than others.
    bryank and Chew like this.
  14. Apr 17, 2024 at 11:43 AM
    Tacompa
    Tacompa Well-Known Member
    San Jose, CA
    2019 Toyota Tacoma OR DCSB 4x4
    Any good full flush DIY videos?
  15. Apr 17, 2024 at 2:07 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Xbowguy, baboltin and jdjones like this.
  16. Apr 17, 2024 at 2:12 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    I did a Flush on mine after 4.5 years of driving and about 45-50K miles.
    My mechanic charged me around $130.
  17. Apr 17, 2024 at 2:16 PM
    jmneill
    SE
  18. Apr 17, 2024 at 2:22 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    DIY is not hard but good to have 2 people with one underneath with temp gun to check proper temp. Dealerships did not even do them several years ago as they said were not needed over lifetime of vehicle (hence no dipstick). Had them do mine at about a hundred although did drain and fill myself before. I also added a larger trans cooler so mine takes a bit more fluid.
    lynyrd3 likes this.
  19. Apr 17, 2024 at 2:37 PM
    lynyrd3
    Bill
    Thanks for info . I have heard of not flushing in high mileage autos for the reason you stated :thumbsup:
  20. Apr 17, 2024 at 2:39 PM
    lynyrd3
    Bill
    First thing I would do is put some jack stands underneath ;)
