Tacoma TRD Pro 2020 vs 2021
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bicyclenut, Oct 4, 2021.
  1. Oct 4, 2021 at 10:34 AM
    bicyclenut
    bicyclenut [OP] Member
    Dave
    Hello everyone. New to this forum so forgive me if this has been asked before.
    Im looking at buying a Tacoma TRD pro. Is there any big differences between 2020 and 2021? I cant find anything other than color options.
    Thank you for any help
  2. Oct 4, 2021 at 10:44 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    No difference
    Chew likes this.
  3. Oct 4, 2021 at 10:49 AM
    bicyclenut
    Dave
    thank you
  4. Oct 4, 2021 at 1:43 PM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    Late 2020 and all 2021 Pros no longer have the auxiliary transmission cooler that was previously part of the tow package on V6 Tacomas. So if a 2020 has the cooler, than it was built early in the year before Toyota started omitting it.
  5. Oct 4, 2021 at 1:45 PM
    YMMPRO
    YMMPRO Well-Known Member
    Northern Alberta, Canada
    2018 Super White Tacoma Pro
    TRD Intake / Falken Wildpeak AT3W
    Where did you hear this ?
  6. Oct 4, 2021 at 1:48 PM
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
    It has been posted many times on other threads. I purchased an Sr5 4x4 V6 with the tow package and it had the aux transmission cooler (built in march 2020), sold it and purchased a trd OR 4x4 V6 with tow package and it does not have the aux cooler.
  7. Oct 4, 2021 at 1:53 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    It’s been talked about here. I can confirm my ‘21 OR does not have the aux. trans cooler. It still has a trans cooler built into the radiator, but not the extra external one that would hang in front of the radiator. It’s lame of Toyota to do that, but at least external coolers aren’t too expensive and very easy to install. I put one in my ‘97 4Runner and I wanna say it was <$100 and took maybe 30 or 40 minutes to put in.
  8. Oct 4, 2021 at 2:00 PM
    maxmk8
    Before someone goes out and starts freaking out about the trans cooler. Feel free to use an app based aux gauge. My trans is perfectly fine at 185f even in 100f weather. However I can’t speak to towing over 3000lbs… in high heat.
  9. Oct 4, 2021 at 2:01 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    They said their transmission is more efficient now with something they did so its not needed
  10. Oct 4, 2021 at 3:36 PM
    Laelius
    Laelius Well-Known Member
    Chicago
    2021 TRD PRO LR
    Leitner ACS, Decked, CBI Sliders, Skids, Air Bags, Gizmos
    Well I just got my 2021 Pro (August build) and I DO have the little black trans cooler in front of the radiator, so maybe they brought them back?
  11. Oct 4, 2021 at 3:44 PM
    maxmk8
    That’s the PS cooler
    Chew likes this.
  12. Oct 4, 2021 at 8:12 PM
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    And I think Toyota just put out a TSB for
    They said the same thing about getting rid of it on the tundra, and now they have a TSB that addresses the fact that the truck are showing extreme trans temps...lol
    RedWings44 likes this.
  13. Oct 4, 2021 at 8:14 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    TFL also had a towing video with the Tundra which showed very high temps after the cooler was removed.
  14. Oct 4, 2021 at 8:50 PM
    Summitroad
    Summitroad Well-Known Member
    Northen CA
    TRD OR 4X4
    BS, They did it to improve profits, just like the grab handle, the rail behind the cab, the storages compartment in the bed, Thanks Mike Sweers
  15. Oct 5, 2021 at 4:37 AM
    ryanvar42
    None
    Yeah, I figured as much. Just like their BS reason for drum brakes in the back. Idc what anyone says they aren’t better
  16. Oct 5, 2021 at 4:57 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Look at what Toyota did with the Army Green paint on the Pro, it's barely green any more. Now it's almost Cement.
  17. Oct 5, 2021 at 6:01 AM
    rasber3140
    rasber3140 Well-Known Member
    2021 TRDOR Barcelona Red
    Except for new rims and TRD UCA's. But none of those count as differences.
  18. Oct 5, 2021 at 6:38 AM
    Grindstone
    Grindstone Requires Adult Supervision
    My September 2019 born Pro has the cooler.
    There was also mention of the shark fin being moved.
    No new UCAs on the 2021, you're talking about the 22.
    Biggest difference is the Pro-exclusive color for the model year. Army Green for the 20 and Lunar Rock for the 21.
    rasber3140[QUOTED] likes this.
  19. Oct 5, 2021 at 7:16 AM
    maxmk8
    No that’s a 2022 difference. 21 and 20 are the same
  20. Oct 5, 2021 at 10:58 AM
    BTL Y-Wing
    I drive a 2017 V6 for work and own a late 2020 Pro myself. Didn't figure it out until I noticed the absence of the aux trans cooler while working on the 2017 and noticed it had a radiator up front that my 2020 didn't.
    My assumption as well. Toyota will tend to delete things if they think people aren't using them, I assume this is why stuff like the Go Pro mount and driver side bed cubby have disappeared as well. For those things it makes sense because most people won't miss them, but deleting the trans cooler is a functional difference that I do take issue with.
