Tacoma Trd Pro With Wheel Spacers (Stock)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ArmyGreenTaco15, Jan 12, 2020.
  1. Jan 13, 2020 at 2:18 AM
    #41
    ll1l2l1l2lll
    ll1l2l1l2lll Well-Known Member
    Orange County
    2019 Tacoma Pro
    tensile
    Hmm, I wouldn't base my opinion on just that person's photos/story. Spacers are safe.
    One thing that people forget is that wheels rely on the friction of the clamping force between the wheel/spacer/hub.
    The studs do not touch the sidewalls of the spacer/wheel.
    The cone/ball of the nut centers the stud between the hole and screwing it together creates a clamping effect, this is what keeps the wheel on your car - rather than the vehicle being 'carried' or 'sitting on' the studs and it taking all the load.
    So if a nut is over torqued, it'll stretch/elongate the stud to where it can fail - tensile deformation. When you see a failure in spacers, it's in wrong equipment or poor design. IE: not enough material between the cone and back pad of the wheel/spacer causing a blow out. However, it is likely most people over torque their nuts than under torque, as many people don't own these tools they are done often by hand. Also, using ball nuts instead of cone nuts - or vice versa.
    Torque wrenches can be considered expensive and possibly they don't know the physics and material properties causing something that is safe, very unsafe.
    So get a torque wrench that's calibrated and always go back to re-torque after a few miles. Make sure you're using the right nuts for your configuration. Race cars, drifters, trophy trucks use spacers all day so don't think of it as aftermarket modding hype.
    Too tight, stretch stud - tensile deformation. Uneven torque, more stress on other studs. Too loose, and you'll get slippage between the surfaces - loss of clamping force. Wrong nuts, not seated.
  2. Jan 13, 2020 at 4:45 AM
    #42
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    The blue one was from a guy that tightened them with out a torque wrench, that said " I was tightening one of the lugnuts to the stud that is preinstalled on the wheel spacer and it wasnt really getting tight so i kept tightening it and the stud actually broke and is now stuck in my factory lugnut!!!"
    The tightening and "never getting tight" thing is a dead give away that the nut has crossed a thread. I can tell in an instant when it's occurring, others just keep going. If you do, it pretty much always results in a sheared bolt.
    He never even suggested guilt on the manufacturer, more so on his own part by not checking or being careful with his tightening.
    https://www.tacomaworld.com/threads/broke-my-spidertrax-wheel-spacers.49273/
    rbowe21 and Grindstone like this.
  3. Jan 13, 2020 at 5:55 AM
    #43
    Texas
    Texas Well-Known Member
    I have seen spacers and/or adapters failure enough times on various vehicles to not want them, even if I followed the instructions and used proper torque settings for that vehicle. I worked at a tire shop for a long time which is how I was exposed to what spacers/adapters can do.
    I like to keep things OEM as Mr. T intended when it comes to tires/wheels.
    Superdave1.0 likes this.
  4. Jan 13, 2020 at 7:47 AM
    #44
    ArmyGreenTaco15
    ArmyGreenTaco15 [OP] Member
    2020 Manual TRD Pro Army Green
    Thanks for all the good info guys. Still not sure what Im going to do. Of course there are better and maybe safer alternatives to obtain the stance and look I'm going for, but as I stated earlier I am trying to keep me stock wheels. I don't necessarily want to gain width by just getting a wider tire and risking rub.
    Its funny how people always throw up their arms when it comes to spacers. I figure if properly installed and if I purchase a quality product I dont see the issue.
    I've even heard of some brands running spacers on their performance vehicles right from stock, Mercedes being an example. Cant be that bad.
    Slavi-Rosomakov and bzzr2 like this.
  5. Jan 13, 2020 at 8:01 AM
    #45
    LaggyEvo
    LaggyEvo Well-Known Member
    Gainesville, FL
    2018 Cavalry Blue TRD PRO MT
    285/75r16 BFG KO2
    OP just get spacers, you will be fine. I ran spacers on my Evo for 4 years DD and autocross. Just torque them down to spec and check them after driving a few hundred miles to make sure they are still torqued properly. As far as rubbing, I cant vouch for that. My guess is will stock tires you will be ok.
  6. Jan 13, 2020 at 3:51 PM
    #46
    ll1l2l1l2lll
    Orange County
    2019 Tacoma Pro
    I agree with you and I'm all about leaving things OEM, I don't plan on adding spacers to my Pro wheels either. The ideal thing to do is get a wheel in the specs you'd like rather than adding an adapter - but that's not always an option.
    I've worked for several wheel manufacturers and spacers for many years. There are a reason that you'll see guys run to a tire shop to have things fixed - they probably don't know about the things I posted previously.
    Obviously there is inherent risk by going with spacers over a stock setup. But I hope people can look over images of mangled wheels/spacers and treating it like all spacers are dangerous and you shouldn't run them.
    I'd rather post about what I know about the topic to weed away the misconceptions of what is likely user error - not the fault of the spacer
    Texas[QUOTED] likes this.
  7. Jan 14, 2020 at 8:23 AM
    #47
    Texas
    Good way to put it. I always tell people it is your truck to do with as you please.
    Bob may tell you that he never had any problem with spacers on his EVO and Bill may say that his wheel flew off his STi because of spacers but it is up to you to do your own research and make the decision.
    ll1l2l1l2lll[QUOTED] likes this.
  8. Mar 15, 2021 at 7:21 AM
    #48
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    The problem with some of those "spacers broke by lugs!1!" pictures are that the installers didn't properly (re)torque after run in.
    Just for an additional data point.. many aerobatic aircraft aircraft have spacers between the propellers and crankshaft (the G forces are huge and a failure can be fatal.) The key is proper torque and maintenance. So if someone isn't willing to perform proper maintenance or doesn't have access to a calibrated torque wrench then they probably shouldn't use hub-centric spacers and should purchase different wheels (the KISS approach.)
    Edit: softened the language.
  9. Dec 26, 2022 at 9:05 AM
    #49
    Slavi-Rosomakov
    Slavi-Rosomakov Active Member
    Slavi
    OP, I have same AG TRD PRO 2020.
    I also coming to this same topic and question. What did you end up doing? Any issues, etc.
    I will likely go to 265/75/16 with Mud Terrain (probably BFG KM3s).... Leave suspension stock for the Pro, but was considering 1.25 or 1.5 spacers.
    Thoughts ...
