Tacoma TRD seat covers? and..Mine are for sale!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skweezal, Jul 14, 2007.
  1. Jul 14, 2007 at 6:06 AM
    skweezal
    skweezal [OP] Well-Known Member
    I purchased the ones from Toyota and they fit like a glove BUT the black rubber strip down the middle gets crazy hot and fries my back on hot days. Does anyone know another manufacturer for custom covers??? The seat is odd in that there is no real separation (in the back ) between the seat-back and seat-bottom, so a traditional two part seat cover doesnt work(I got one from California Car Covers and had to send it back for that reason). The one from toyota had sort of a dowel sewn in to a piece in the cover and you tucked that in between the seatback and seat bottom to secure the cover. It worked great but the cover itself was too hot for me.
    BTW...if anyone wants to buy mine, I am selling them (like new!)
    Suggestions???
    Many thanks
    sk
  2. Jul 14, 2007 at 7:49 AM
    stratton
    stratton Well-Known Member
    i have the same seat covers. i havent parked the truck yet in the sun. but i cant seem to tuck the dowel in far enough. it keeps popping out. annoying!
  3. Jul 14, 2007 at 8:20 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Try Wet Okole seat covers. They're really pricey, but every owner that has them loves them.
    http://www.wetokole.com/
  4. Jul 14, 2007 at 12:37 PM
    skweezal
    Website looks great!! do you have these, and if so, do they accomodate the issue of the attached seat bottom and seat back??
    Many thanks!!
  5. Jul 14, 2007 at 12:39 PM
    skweezal
    hmmmm, i didnt have that problem but then, I had my husband put the covers on !!
    thanks for the post
    sk
  6. Jul 14, 2007 at 12:48 PM
    stratton
    haha is your husband up for a drive. i am about ready to throw the things to the curb.
  7. Jul 14, 2007 at 6:43 PM
    Panama Red
    Panama Red Well-Known Member
    All it takes to correctly install the TRD covers is:
    A. socket (14 mm IIRC) and wrench
    B. wire cutters
    C. four zip ties
    What you do is:
    1. Unbolt the seat from the floor and disconnect the electrical connection under the seat.
    2. Turn seat over and cut the two hog rings holding the lower rear flap to the underside of the seat.
    3. Remove the plastic dowel from the loop in the center of the TRD seats.
    4. Slide the center of the TRD seatcover through the joint between the seat back and seat bottom. You need to slide the loop through far enough that you can re-install the plastic dowel into the loop after pulling it through the joint.
    5. Remove the head rest and stretch the top of the seatcover over the seat back (you will have to work at it, but it is doable)
    6. Stretch the seatcover bottom over the bottom of the seat bottom.
    7. Fold the rear seat flap back under the seat (the one you cut free up in item 2) and zip tie it back to the same underwire that you removed it from up in item 2.
    8. Re-attach the electrical connection under the seat and re-bolt the seat back onto the floor.
    9. Cover the headrest and put back onto seat.
    10. Do second seat.
    When you do as above, the cover will not come off or even come loose because the loop with plastic dowel is on the backside of the joint and it will not come back through since it is to large. This is why it is so difficult to push it through that seat joint in the first place. When I installed my TRD seatcovers this way (after trying to first install them like you did), my seatcovers are so tight, that I can flip a quarter on them.
  8. Jul 14, 2007 at 7:25 PM
    skweezal
    wow....Panama Red really went all out!! My huband said the key is to put the back on first (taking off the headrest) and then tuck in the dowel, one side at a time. Then the bottom gets pulled tight over the seat bottom. He did it in about 15 minutes and it fit very tight (like it should). When I tried to do it first, it was saggy and lame and the dowel was nowhere near tucked in!! Try this method and let us know how it goes!!
  9. Jul 14, 2007 at 7:28 PM
    skweezal
    BTW...my hubby said you really have to STUFF the the dowel way in and it isnt easy. You have to keep stuffing it in till you feel it get by the seat parts. No wonder I couldnt do it...gotta have some muscle to get that dern thing seated (no pun intended) correctly!!
    sk
  10. Jul 14, 2007 at 7:41 PM
    stratton
    Thanks people. Lots of great info. I will tackle this tomorrow morning.
  11. Jul 14, 2007 at 7:44 PM
    skweezal
    Good luck Stratton....have some Wheaties for breakfast :)
    sk
  12. Jul 15, 2007 at 8:28 AM
    brant_trd
    brant_trd Well-Known Member
    Jasper, Indiana
    05 TRD Tacoma
    Black Headlight Mod, Nightshaded Taillights, Grillcraft Speed Grille, Revtec 3 inch leveling lift kit, 2-tone Coverking seatcovers, TRD intake and exhaust, back cats removed, secondary air filter removed, custom TRD stripes down the sides of tacoma, debadged, and H.I.D. 10,000 degrees headlights and foglights
    how much, I'd like to buy them maybe
  13. Jul 15, 2007 at 12:56 PM
    skweezal
    Ok....I sent you a private message thru this website.
    sk
  14. Aug 2, 2008 at 3:17 PM
    06WHITETRD
    06WHITETRD Gotta Love my Taco!!!!
    So Cal
    06 Toyota Tacoma OFF-ROAD
    Tinted windows, window visors, XDI True Flow intake, White Devil Emblem, sport white grill, stubbie 6' antenna, TRD license plate frame,TRD Exhaust, weathertech floor front & rear, LED map/dome & license plate lights,Black Grille,T-Rex eyebrows,black Skid Plate,Lower bumper cover,Black emblems,white TRD Emblem,lamin-x yellow,Slotted & Cross Drilled rotors,Redline shocks(hood),HID 6k,more to come
    did u end up selling the seat covers?? if not, i want to see. how much? i want pictures?
  15. Aug 2, 2008 at 3:22 PM
    skweezal
    yes, they sold quickly. i bought the wet okole ones instead...like em much better.
