Tacoma TRD Wheels on First Gen Tundra
Discussion in 'Wheels & Tires' started by Shoez, Sep 8, 2015.
  1. Sep 8, 2015 at 12:24 PM
    Shoez
    Shoez [OP] Member
    Martin
    Canton, GA
    2000 Tundra 4x4 Ivan Stewart
    Bilstein 5100
    Hello everyone!
    Long time lurker here, I have a question about my Tacoma wheel swap. I went from the original Tundra stamped wheels to the 2012 Tacoma TRD off road 5 spoke wheels. This changed my offset from 30mm(Tundra) to 15mm(Tacoma). This sucked the wheels in 15mm. I then added 2" 6061 aluminum hub-centric spacers. This is approximately 50mm. This pushed the wheels back out approximately 35mm past the stock position. With that being said here are my specs;
    65mm "Offset" from the hub
    Bilstein 1" leveling suspension lift (adjustable front shocks)
    What is the largest size tire I could run? First gen tundra's can run a maximum of 285/75/16 with the bilsteins. Could I get a 295/75/16 under there given that I am running a 2" spacer?
    I appreciate it!
