Tacoma Tundra Third member swap?
Discussion in '5 Lug' started by carattini, Jul 14, 2011.
  1. Jul 14, 2011 at 12:05 PM
    carattini
    carattini [OP] Well-Known Member
    David
    Puerto Rico
    08 base model
    I Have a 2008 Base model access cab Tacoma. I put 29" toll tires and looking to regear the dif. I'm short on money and my Dad have a Toyota Tundra 2003 2WD rear Diff at his home will the Third member can be swap into my Tacoma? My Tacoma is 3.31 and The Tundra is ether 3.9 or 4.0
    let me know what you think of this?
  2. Jul 19, 2011 at 6:49 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    i would call a shop that specializes in diffs and ask them. im sure most people wouldnt know but im not positive.
  3. Jul 20, 2011 at 5:59 AM
    carattini
    David
    Puerto Rico
    08 base model
    Thanks...
  4. Jul 20, 2011 at 9:12 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    i think you would need to find out the size of the tundra's differential. i think that reagearing is too confusing so hopefully someone else will see this who knows more about regearing
  5. Jul 20, 2011 at 9:16 AM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    older tundra axles and newer tacoma axles are the same.
  6. Jul 20, 2011 at 11:24 AM
    carattini
    David
    Puerto Rico
    08 base model
    That is good to know
    I went to my dad place and did the turn one side to see how many turns the third member does and it did litter over 2 Now I'm confuse the tundras supose to be 3.9 or 4.0
  7. Jul 20, 2011 at 11:43 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    No they're not. The axles are longer on the Tundra.
  8. Jul 20, 2011 at 11:48 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Depends on the year/transmission/features
    They came with 3.91, 4.10, and 4.30
  9. Jul 20, 2011 at 11:50 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    tundras are 8.4 as are the sport tacomas not sure what size diff ur truck has in it
  10. Jul 20, 2011 at 11:52 AM
    113tac
    Stephen
    Northern Virginia
    i think everything but the offroad diff is 8.4
  11. Jul 20, 2011 at 12:08 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Thats correct!
    If the 3rd member from tundra is 8.4" it should fit.
  12. Jul 20, 2011 at 12:11 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Is your truck a 4wd/prerunner or a 5lug? I think the 5lug has a 7.5 rear axle
  13. Jul 20, 2011 at 12:21 PM
    05RedTaco
    Tony
    Scottsdale
    No 5lug has 8.4 axle.
  14. Jul 20, 2011 at 12:39 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Doesn't a 5 lug have a 27 spline count versus the 6 lugs 30 spline count? I'm having a helluva time finding that.
  15. Jul 20, 2011 at 12:57 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Ah, I think that answers my question then.
  16. Jul 20, 2011 at 1:10 PM
    05RedTaco
    Tony
    Scottsdale
    From what I researched the 5lug carrier is different then 6lug carrier so 4.10 gears from 6lug wont fit 5lug without changing the carrier...
  17. Jul 20, 2011 at 1:11 PM
    carattini
    David
    Puerto Rico
    08 base model
    5Lug
  18. Jul 20, 2011 at 1:13 PM
    carattini
    David
    Puerto Rico
    08 base model
    This is bad news but will i still be able to use the pinion an ring?
  19. Jul 20, 2011 at 1:27 PM
    carattini
    David
    Puerto Rico
    08 base model
    rcfreak201 is selling me a 4.10 Ring and pinion for $200. I think this is a good deal. What do you think?
  20. Jul 20, 2011 at 4:14 PM
    05RedTaco
    Tony
    Scottsdale
