tacoma under wash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki111, Oct 27, 2020.
  1. Oct 27, 2020 at 4:40 AM
    kiki111
    kiki111 [OP] MENTALLY DISTURBED MEMBER
    Tacoma 2.7L SR
    how often should you clean (pressure wash) the bottom of your truck?
    gonna wash and touch up small rust spots....
    MtnFisher likes this.
  2. Oct 27, 2020 at 4:42 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Wash it after off-roading ... playing in sand .if you do street driving then just wash it when u do your normal car wash . No special attention needed .
    Malvolio, jetfishn and Chew like this.
  3. Oct 27, 2020 at 4:44 AM
    smithr1730
    smithr1730 Well-Known Member
    Rob
    Columbus, Ohio
    '15 TX Pro
    Offroad parts and such
  4. Oct 27, 2020 at 4:47 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Junkhead likes this.
  5. Oct 27, 2020 at 4:48 AM
    kiki111
    Tacoma 2.7L SR
    i have a regular 2000 psi pressure washer i wash the truck with...no problem spraying under or lying under truck since lifted to wash.....wanna touch up some rust spots before the get worse
  6. Oct 27, 2020 at 4:56 AM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Strive to keep mud outta the frame etc. Caked mud especially in crevices holds moisture =rust.
    Chew likes this.
  7. Oct 27, 2020 at 5:28 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Be careful with high pressure water, you can force water where you don't want it too.
    Junkhead, jmneill and GarlicFarts like this.
  8. Oct 27, 2020 at 5:35 AM
    BlkTaco47
    BlkTaco47 Unhinged
    this is exactly why I chose the hose variant
    Chew[QUOTED] likes this.
  9. Oct 27, 2020 at 5:55 AM
    Steve2122
    Steve2122 New Member
    2021 TRD OR DCSB
    Do you have a link to where you got the hose version of this?
  10. Oct 27, 2020 at 6:06 AM
    BlkTaco47
    BlkTaco47 Unhinged
    I do not, it was quite a while ago - maybe they make a pressure fitting to hose adapter?
  11. Oct 27, 2020 at 6:25 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    You won't have to worry about this in Florida, but others in the salt belt would benefit from regular underbody washes during the winter.
  12. Oct 27, 2020 at 3:38 PM
    Haust
    Haust New Member
    I just toss a yard sprinkler underneath. Leave it a while and it does a pretty good job of cleaning.
  13. Oct 27, 2020 at 3:59 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Thats what I would do too. Since the OP is in florida, unless he is driving through the ocean a simple sprinkler will do the trick.
  14. Oct 27, 2020 at 4:33 PM
    kiki111
    Tacoma 2.7L SR
    we all know that the tacomas get rust by just looking at the frame so I'm going to clean it and touch up with paint a couple of areas that's all...but you guys convinced me just to use a water hose I'm not going to use the pressure cleaner on the bottom
  15. Oct 27, 2020 at 4:40 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Everytime after wheeling or after visiting the northern states in the winter. I put my swimsuit on and lay on the ground, spray everything with a pressurized hose nozzle. If it’s cold outside, I’ll get cold but I’ll jump in the HOT TUB afterwards and it’s all better
    Haust likes this.
