Tacoma upgrades
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2001_tacoma, Dec 1, 2019.
  1. Dec 1, 2019 at 9:21 PM
    2001_tacoma
    2001_tacoma [OP] New Member
    Luke
    2001 single cab Tacoma
    Hello, just got my 2001 tacoma and looking to for new ideas to modify it! Any suggestions help! Thanks!
    Taco critter, Fuergrissa and Hobbs like this.
  2. Dec 1, 2019 at 9:23 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  3. Dec 1, 2019 at 9:25 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum! :woot:
    GQ7227 and Taco critter like this.
  4. Dec 1, 2019 at 9:52 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Welcome to TW!
    What sort of things do you like to do with your truck?
    Personally I think the best mod for your truck is a daily driver.
  5. Dec 2, 2019 at 3:09 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It all comes down to your planned use!
    Myself I would make sure the maintenance is all up to speed some areas always neglected
    frame /Brakes/ Suspension / Fluids / Belts / hoses
    Taco critter likes this.
  6. Dec 2, 2019 at 3:50 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Welcome to TW! . Tell us about your truck location, mileage, engine, and transmission.
  7. Dec 2, 2019 at 4:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    Have you baselined all maintenance items so it's in a 'needs nothing' mode? Most used vehicles don't come that way.
    For example, if you have no records for fluid changes, do them all. Etc etc. Most full baselining projects will run a few hundred bucks. If tires/brakes/suspension are needed, $2-3k, depending on your product choices.
    Mods either start after that's done or as part of that process (ie there can be things to upgrade while performing PM)
  8. Dec 2, 2019 at 5:07 AM
    Indy
    Indy Master of all I survey.
    1st buy a train horn, mount it at your rear bumper. Put the switch under your brake pedal. Now you have an be audible warning to the people behind you that you're stopping.
    Then you want to mount an aircraft strobe light to the roof. That will keep small aircraft from accidentally landing on you at night.
    Duct tape old mattresses to either side of the truck, you'll get fewer small dents in parking lots.
    Lastly get about 200 bicycle horns with the squeeze bulbs. Mount them to your tires so you're always driving over the bulbs, because that would be hilarious.
  9. Dec 2, 2019 at 10:34 AM
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    There is a sticky at the top of the first gen thread of diy mods. Mostly little stuff and I definitely recommend the grey wire mod if you have a elocker.
  10. Dec 2, 2019 at 11:05 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    As others said, make sure the truck is up to snuff on its maintenance FIRST. Doesn't do you any good if you got some sweet mods but now you can't drive it because your ball joints failed and it doesn't run because you didn't clean the MAF and you've got a bad up stream cat sensor.
    Then drive it around for a while. See what YOU need/want. What are your plans for it? Where will you drive it? Is this a daily driver or an off-road play truck? Or are you just trying to impress your fraternity brothers or go viral on instagram?
    Don't just copy other people. It's almost guaranteed they don't use the truck just like you do, so you'll just be spending money to solve a problem you don't have.
    If you have a particular problem, look to other people's builds and how they solved that particular problem. Don't just throw a snorkel and diff breathers at your truck because you saw someone else do it.
    skeezix likes this.
  11. Dec 2, 2019 at 12:04 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Area51Runner, _chris and OneWheelPeel like this.
