Tacoma v Tundra off road
Discussion in 'Off-Roading & Trails' started by diver110, Feb 22, 2011.
  1. Feb 22, 2011 at 9:04 AM
    diver110
    diver110 [OP] Member
    Initially I was going to get not a Tundra but a 3/4 ton which Toyota alas does not make. But then it turned out a full size truck would not be allowed into the parking garage at work, so I bagged that idea. I have modest off road experience (though I enjoy it). I was told that a Tacoma would be able to go more places than a Tundra anyway off road. I am not getting a full size truck anyway, but am curious, for someone interested in moderate off roading, how big a limitation is stepping up to a full size truck from a mid sized (that are both otherwise off road ready)?
  2. Feb 22, 2011 at 9:06 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    High centering and sinking down in the mud are some of the limitations associated with 1/2-3/4 tons
  3. Feb 22, 2011 at 9:11 AM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    The bigger the tires compared to the vehicle size and weight is typically better for off roading. Seemingly large tires for a Tacoma will seem not as large on a full sized truck. So it's much cheaper to go with a Tacoma. Tacos can squeeze past rocks, branches and trees better than a larger truck. Plus, if you get stuck and need pulled out, you'll weigh less and getting pulled out is potentially easier
  4. Feb 22, 2011 at 9:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    Depends on which Tundra you get. ;)
  5. Feb 22, 2011 at 9:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Physical size. The smaller truck is easier to maneuver.
  6. Feb 22, 2011 at 9:16 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The second generation Tacoma is almost too big... almost. The first generation fit better on 'Jeep' trails! A Tundra... specially the second generation (full size) Tundra would be more difficult and get more body damage from trailing!
  7. Feb 22, 2011 at 9:34 AM
    diver110
    Thanks for all of the feedback! Being an off road newbie, I almost missed this issue. Lucky, someone alerted me to it.
  8. Feb 22, 2011 at 9:47 AM
    jandrews
    '09 FourDubDee TRD OR
    One word: Angles.
    Fullsizes don't have a prayer in hell on real trails.
  9. Feb 22, 2011 at 11:41 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    you should see all the scratches on my 1st gen tacoma from all the narrow trails! Meh, its only paint, it will buff out lol.
    Mostly its an issue about size and wheel placement.
  10. Feb 22, 2011 at 12:25 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    full sizes trucks will hurt your wallet more than mid size trucks.
