Tacoma V6 versus 4Runner V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by collinkonow, Oct 29, 2010.
  1. Oct 29, 2010 at 11:40 AM
    collinkonow
    collinkonow [OP] Member
    CT
    2011 Tacoma DC LB
    Does anyone know why the 4Runner V6 is a 4.0, the same as the Tacoma, but has over 40 more horsepower and 10 ft lbs of torque? Is there a cheap mod or any other mods you can do to get this much. I have a brand new 2011 DC LB V6 auto. Thanks. Tried looking at the threds for this info with no luck
  2. Oct 29, 2010 at 11:41 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
  3. Oct 29, 2010 at 11:44 AM
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    I'd imagine DT headers, URD intake, and straight dual pipes could get you a pretty good boost up there. Yeah its def the variable valve timing though on the 'runner engine giving it so much more power.
    Both the 4runner and FJ cruiser get DUAL VVTI, instead of just the standard VVTI on the Tacoma engine. No idea why they don't offer this on the the Tacoma. I'd guess to keep prices down since 4runners start at like 29k with no options, although FJs are in the 25k range so that doesn't totally make sense either.
  4. Oct 29, 2010 at 11:46 AM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    dual vvti
  5. Oct 29, 2010 at 12:26 PM
    JB3CK24
    JB3CK24 Return to the 36 Chambers
    Jeff
    SD, CA
    2001 4x4 TRD, 2003 BMW 330i ZHP
    It's because they are way heavier than a Tacoma :)
  6. Oct 29, 2010 at 12:56 PM
    collinkonow
    CT
    2011 Tacoma DC LB
    Thanks for all the quick replys. I'm new to the site as I just bought my first Taco. 2011 DC LB Magnetic Gray. Only issue so far is a SLIGHT shudder when punching it from a stop. After research i determined that it's probably due to the two mpiece driveshaft wobbling at the carrier bearing. sounds like a lot of others have this issue, although it is minor. Just figured Toyota would have figured this out after 6 years of the GEN 2.
  7. Oct 29, 2010 at 1:18 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    They sold a lot of Tacoma's over the pass 5 year so I don't really want to change something that's been selling, (that's what I think)
  8. Oct 29, 2010 at 2:03 PM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    It could be the driveshaft issue, which some have fixed with the tom woods single piece driveshaft. But since your totally stock, it might also be that the transmission reflash TSB could fix this. My dad's 08 had the shudder til he got the fix. Not sure if this affects '11 tacomas though. My '10 hasn't had the shudder so far.
  9. Oct 29, 2010 at 2:27 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    And 'tuning'...computer mappings will have a major influence on power output.
  10. Oct 29, 2010 at 2:32 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I would not straight dual this truck unless you are going to forced induction. Exhaust scavenging is far more important than outflow for an NA engine. If you separate the two banks...You mess with 1/2 of each pulse per side...
  11. Oct 29, 2010 at 2:49 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    U.S.A.
    2023 RAV4 XLE Premium
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... ^^^ ... this was exactly the problem that was happening when the OEM TRD Duals were being put on the 5.7 Tundras by the dealers.
    It happened to my 2007 5.7 ... a loss of power (primarily on lower end) with the TRD duals.
    However, my "butt dyno" overruled that, especially with the better muscle car exhaust notes :D (not too loud and not too soft, just right in sound & DBs).
    Yep, these newer engines (especially the NAs) need to scavenge that back pressure, unlike the exhaust of old.
    Disclaimer ... I am sure that there are some exceptions to the "exhaust scavenging rule" ... :confused:
  12. Oct 29, 2010 at 2:52 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    We have a 2010 4Runner and a 2011 Tacoma. I believe Toyota left the Tacoma engine the way it is because the torque comes in a little earlier than the 4Runner/FJ but not by much. (300-400rmps)
  13. Oct 29, 2010 at 7:43 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    As previously stated you will probably see dual VVTi on the redesigned Tacoma. The current Tacoma 4.0 has a fair amount of torque and that is a pretty significant thing when you are talking about trucks.
