Tacoma vibrates when turning only when Cold
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lordviews, Aug 17, 2023.
  1. Aug 17, 2023 at 5:03 PM
    lordviews
    lordviews [OP] Well-Known Member
    07 TRD Sport
    So basically, when pulling out from where I am parked and turning my wheel all the way left, my truck vibrates only at slow speeds and dead stops. It doesn't do this when speeding. I am almost positive it is coming from the rear of the truck. It even goes away If I use it throughout the whole day.
    It is most notable first thing in the morning when heading out and when turning. If I use the truck the whole day, the problem goes away but comes back first thing in the morning.
    I have already put two tubes of lsd additive fluid as well as replaced and drained everything and it went away for maybe a couple days and came back. I am convinced it has to be something else but I am completely lost.
    Any ideas or feedback will be appreciated. Thank you.
    I own an 07 TRD Sport with 128k miles
  2. Aug 17, 2023 at 6:52 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    The additive you use can make a difference. I am told Sta-Lube Equa-Torque Friction Modifier is better than most others, maybe worth a try. Also, use dino instead of synthetic, which is too slippery.
