Tacoma vibration after putting new tires on it
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Propainterman, Jan 20, 2018.
  1. Jan 20, 2018 at 12:10 PM
    Propainterman
    Propainterman [OP] Member
    2014 black 4 door 4x4 4 door
    I just had new Michelin Defender LTX tires put on my 2014 4 door 4x4 tacoma now I have bad vibration. I went from the 240/75 the 265/70 tires. I have taken it back where I bought the tires 3 days in a row. they have used Road Force balancing 3 times & now say they think i have drivetrain problems causing the vibration. Any Ideas about this.
  2. Jan 20, 2018 at 12:15 PM
    Shikokaon
    Shikokaon Slacker Extraordinaire
    Portland, OR
    2017 Tacoma D-Cab Off Road (MT)
    Alignment? Did your old tires wear out evenly?
    Rambo54 likes this.
  3. Jan 20, 2018 at 12:19 PM
    Propainterman
    yes, They were original tires with 47000 miles
    Rambo54 likes this.
  4. Jan 20, 2018 at 12:26 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Do you feel the vibration in the steering wheel? Rotate the tires, front to rear and rear to front, and take notice to whether the vibration changes. If it changes it’s a tire. If the vibe stays exactly the same, may be driveline. I would suspect tire if it happened as soon as you put the new tires on.
    Some tires just don’t balance perfectly, no matter the amount of rebalancing. Mine have never balanced perfectly.
    Propainterman[OP] likes this.
  5. Jan 20, 2018 at 12:27 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    If you didn’t have a vibration before the new tires and now you do. I would question there theory.
  6. Jan 20, 2018 at 12:31 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Just tell the place that you bought them from that Want a new set of tires, if you bought them new.. Most tire manufactures give you 30 days trail period on a new set of tires..Not uncommon to get a set that won't balance out correctly.
    Rambo54 and Propainterman[OP] like this.
  7. Jan 20, 2018 at 1:47 PM
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    If a tire isn't round they may be able to balance it and it will come out right on the machine, but when you put it on the road it shakes.
    A driveline vibration will be pretty fast, almost a hum at high speed. A tire will be more of a shake, approximately 1/4 or 1/2 the speed, depending on the defect.
  8. Jan 20, 2018 at 3:04 PM
    Mxer4ever
    Mxer4ever Member
    2005 TRD Offroad SWB
    I had the same issue with my 2nd set of tires (BFGs) they put on 4 new sneaks and I noticed it vibrating the minute I left. I took them back for a rebalance and the idiot just counter balanced them with weights on opposite sides.... after making them balance the a 3rd time and rotate them the shake was in the rear.
    I had them change brands of tire to the Bridgestone Deuler AT Revos and the ride was better than it was with the OE BFGs.
    They have been my tire of choice ever since. super stable and never let me down.
    Forgot to mention that excessive runout turned out to be the issue.
  9. Jan 20, 2018 at 5:23 PM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    No doubt about the Bridgestone Deuler AT Revos, can't go wrong with them, excellent in the snow.
  10. Jan 20, 2018 at 5:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    Road Force Balance is an excellent machine.
    Assuming the tech actually 1) knows how to use it 2) makes the effort needed to use it properly.
    It's a two step process. Step one is a normal spin balance. If it works well, Road Force never happens. If it needs Road Force, you'll see bead breaking and shifting of the tire on the wheel to line up wheel/tire sweet spots, then re testing and actual balancing. Good bit of extra labor.
    Did you get to watch the process and see if any of that was happening?
    303tacoma and Propainterman[OP] like this.
  11. Jan 20, 2018 at 6:08 PM
    Zach O
    Zach O Well-Known Member
    Zach
    Texas
    2015 TRD Off-Road SWFTMFW 6 speed
    I bet it is still a tire balance issue. It took me 6 tries at 3 different places, including the dealer, to find someone that could balance mine correctly. Like the others have said, since it started right after the tires were replaced it's highly unlikely to be drive line related.
  12. Jan 20, 2018 at 7:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Plus 1 for the Revos :thumbsup:
  13. Jan 21, 2018 at 5:13 AM
    Propainterman
    No I didn't get to watch them do the tires. Are the Revos a loud tire
  14. Jan 21, 2018 at 5:21 AM
    Pigpen
    Dan
    Northwest Montana
    I didn't read past the first post. I have vibrations every time I go to the tire shop. Your wheels are balanced. They were just put on carelessly. You need to evenly tighten the lugs starting at low torque, using a star pattern. I tighten to 30 pounds, then 70, then final tightness (85 is spec, but I go 100).
    If the first lug is over tightened, the wheel will not be truly centered. No shop will do this properly for you. Heavy tires magnify the problem - mine are 60 pounds each, just the rubber.
  15. Jan 21, 2018 at 5:45 AM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    No there not loud at all
  16. Jan 21, 2018 at 6:47 AM
    Propainterman
    So changing from the 245/75 16to a 265/70 16 wouldn't have anything to do with it
  17. Jan 21, 2018 at 6:50 AM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    Not at all, if I were you I would have went to 265/75/16 instead, the 75 will give you a 1" taller tire and have your speedo reading the correct speed.
  18. Jan 21, 2018 at 7:45 AM
    Pigpen
    Dan
    Northwest Montana
    That's a stock tire size on the TRD models
  19. Jan 21, 2018 at 7:52 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I had a bad vibration around when I changed tires, it turned out I had a bad u joint.
    I did think it was the tires at first, multiple balancing attempts.
  20. Jan 21, 2018 at 11:41 AM
    Propainterman
    I had them checked at Toyota dealer yesterday. They said they were fine just needed grease which they did. Thanks for the suggestion
    DavesTaco68 likes this.
