Tacoma Virgin
Discussion in 'New Members' started by Cali2012 4x4, Sep 1, 2015.
  1. Sep 1, 2015 at 11:15 AM
    Cali2012 4x4
    Cali2012 4x4 [OP] New Member
    2012 Tacoma TRD O/R V6 4x4
    hello all I'm new to the Toyotaworld. So let me just jump on in. Owner of a 2012 Tacoma access cab 4x4 trd off-road V6 stock suspension tire size are 265/70r16. Now I really don't want a taller tire just would like a tire that will stick out past the fender alittle to give it a beefy look. Any suggestions on how to make this happen without changing wheels?
  2. Sep 1, 2015 at 4:13 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Welcome!Stick with the same size tire and run a wheel spacer such as Spidertrax ¼ inch.Use the search engine on the forum for some better info/thread feedback.
    Cali2012 4x4[OP] likes this.
  3. Sep 1, 2015 at 4:17 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    this
  4. Sep 1, 2015 at 4:17 PM
    tacomatt602
    tacomatt602 Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    Yeah, that would be the most cost efficient way to go. Or if you want to shell out a grand, buy wider tires but use a ratio so that the tires have the same height.
  5. Sep 1, 2015 at 4:17 PM
    ramonortiz55
    Ramon
    Texas
    stock
    welcome onboard tacoma virgin.
    time to pop that cherrie
  6. Sep 1, 2015 at 4:20 PM
    tacomatt602
    Phoenix, AZ
    This is getting too X-rated, I think I'm gonna be.. :puke:
  7. Sep 1, 2015 at 4:59 PM
    Cali2012 4x4
    I take it that a 1/4 inch spacer will only put the tire out a 1/4 of inch more correct?
  8. Sep 1, 2015 at 5:24 PM
    tacomatt602
    Phoenix, AZ
    Correct
  9. Sep 1, 2015 at 5:26 PM
    DrFunker
    DrFunker Well-Known Member
    Let the hazing commence
  10. Sep 1, 2015 at 5:27 PM
    ODNAREM
    Ron
    Yes.
  11. Sep 1, 2015 at 5:27 PM
    DrFunker
    oh yeah....Welcome.
    :wave:
  12. Sep 1, 2015 at 5:34 PM
    ramonortiz55
    Ramon
    Texas
    stock
    the funk strikes again
    DrFunker[QUOTED] likes this.
  13. Sep 1, 2015 at 5:34 PM
    DrFunker
  14. Sep 1, 2015 at 5:35 PM
    ramonortiz55
    Ramon
    Texas
    stock
    trust him, he's a doctor.
  15. Sep 1, 2015 at 5:35 PM
    ODNAREM
    Ron
    Wonder if that's cold or hot water!LOL!
  16. Sep 1, 2015 at 7:55 PM
    Bchengy
    Bchengy Well-Known Member
    White 2008 DCLB Trd Offroad Sport Pro 37x12.5r17
    Welcome aboard ! Proper way to go wider is a wider rim and tire combo, or an high offset or backspaced rim. Spacers are a cheaper way to go. Not recommended of course. Or do it like the stance guys, streach a tire on a really wide rim if you want to avoid rubbing issues.
  17. Sep 2, 2015 at 1:56 AM
    DrFunker
    lukewarm of course....not too hot to scald and not too cold to bring on the chills.
    :D
    ODNAREM[QUOTED] likes this.
  18. Sep 2, 2015 at 8:06 AM
    Cali2012 4x4
    I believe I will just get a wheel and tire combo. I am thinking of 265/75r16 on a 16x8 wheel
  19. Sep 2, 2015 at 8:13 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    That will be a nice well filling combo......but it will not stick out any wider. The 75 means the sidewalk is now 75% of the tire width which will remain the same. IMHO though, it is a better looking alternative but it is a taller tire. If this is a non OEM rim and the off set moves the wheel out beyond factory specs, I would check the fitment of the tire first before I bought this combo.
  20. Sep 2, 2015 at 10:14 AM
    Cali2012 4x4
    So what would you think would be a set that I need for wide look but not height? I don't do any off-roading I'm just looking for a wider look.
