Tacoma vs. 10-foot yew
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ScienceTruck, Jul 27, 2011.
  1. Jul 27, 2011 at 1:18 PM
    ScienceTruck
    ScienceTruck [OP] Member
    Massachusetts
    09 Double Cab Long Bed
    I have some very large, overgrown shrubs (mostly yews) that I want to remove from my front yard. The previous owners must never have down any pruning because these things are gigantic. Being a new truck owner, I would love to rip these out myself but I want to make sure that I do it smart. The actual dimensions are something like 7' tall by 10' by 10'. Is it a simple matter of digging around the base of the shrub, throwing on some tow straps and putting it into reverse? Or is it worth it having the landscaper from across the street do it for $70? Any and all advice is welcome. Thanks!
  2. Jul 27, 2011 at 1:21 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    i thing it would work better in drive not reverse. do you not have a tow package? we have dune allot of stuff like this over the years with dads tundra. and i have used 4 wheelers before too.
  3. Jul 27, 2011 at 1:22 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Don't chain it to your truck... that will most likely not work, roots are strong and holding a lot of earth. Dig down around the base, cut them off as close to the ground (or below the ground surface) as possible and either let the stump rot out, dig it out, or grind it out with a stump grinder.
    For $70, if that's cutting the tree down, removing the stump and re-leveling where the tree was, that's not a bad deal.
  4. Jul 27, 2011 at 1:27 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's, Pioner AVH-2300NEX w/backup camera, SCT X4 Tuner.
    If you are going to pull them out with your truck, go to Harbor Freight and get a tow/recovery strap that is rated for 6,000lbs or so. It will brake long before you damage the tow hitch on your truck...assuming you have the tow package.
  5. Jul 27, 2011 at 1:29 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    comparative advantage. For the time it takes that person to earn that $70, can you use that time to earn more? If so, then its a good deal. If not, then do it yourself.
  6. Jul 27, 2011 at 1:31 PM
    Pugga
    Massachusetts
    Because stump removal is a biotch! :)
  7. Jul 27, 2011 at 1:34 PM
    Maticuno
    03 F250 CCSB
    Step 1) Cut down tree
    Step 2) Spread thick layer of thermite over stump
    Step 3) Light with magnesium strip
    Step 4) Watch from safe distance...with welding goggles
    Step 5) Sell "glassed" dirt as folk art
  8. Jul 27, 2011 at 1:40 PM
    Pugga
    Massachusetts
    The stump burning part is actually very effective. Just depends on where in MA the OP is located. I wouldn't be able to get away with that where I live... Too many nosey neighbors and the fire department is a block away.
  9. Jul 27, 2011 at 2:10 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
  10. Jul 27, 2011 at 2:18 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    idiots. cant believe no one thought to say, "hey, i think the tree may fall on the truck."
