Tacoma Vs Frontier
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OldManTacoFeels, Nov 17, 2019.
  1. Nov 18, 2019 at 12:17 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The main differences are:
    build quality
    durability
    resale value
    customer satisfaction
  2. Nov 18, 2019 at 12:32 PM
    96carboard
    96carboard Well-Known Member
    You must enjoy rust, because that's about the only "advantage" a fully boxed frame has over a c-channel frame.
    Really just look at all the frame failures on Tacoma -- happens in the boxed section, not the open section.
    Had an '88 Nissan. Frame (and body) all rotted really bad. Then it sat a couple of years and when we finally got rid of it, whole thing snapped in half (both sides frame broke).
  3. Nov 18, 2019 at 2:46 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    I had an 08 frontier, made it to 170,000 miles before the strawberry milkshake of death...the radiator was already replaced cause of recall and it still happened to me. Cost me $5000 for a new transmission...i ended up putting n an external transmission cooler after that. Then a few months later, my gf slide it into a guard rail and totals it....thats how i ended up with a 07 Taco. I personally think the taco has a lot more balls motor wise and a lot more aftermarket parts for it, which is surprising cause the frontier is pretty much unchanged for so many years.
  4. Nov 18, 2019 at 5:40 PM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    True it has the potential to rust, but rust is also common near the leaf spring mounts where the bed and cab meet, (c channel) which is why you see those pictures of trucks on lifts with the bed folded right off. It’s common up front where you mention because it takes such a blast from road salt splashing right off the front wheels, but they need the strength of the boxed frame there for the weight of the engine, transmission, and passengers. I think the Tacoma frame rust issue is more a manufacturing/ laminating steel issue than a boxed vs unboxed frame thing. The fact that it’s recognized as a manufacturing defect and not just a fact of metal boxed frames being prone to rust is why theres the whole lawsuit thing resulting in all the recalls. Plenty of full sized trucks and other vehicles with boxed frames rust, but don’t rust in half in so prematurely. This isn’t all just Toyota being the nice guy company that’s going to keep their customers happy even when things go wrong. They were presented with a class action lawsuit, it was proven their frames were defective, and they needed to rectify the situation.
    No matter the make though, rust is prevalent in my area so it’s smart to take precautions like fluid film whether it’s boxed or not, and I wouldn’t mind having the increased strength of a boxed frame. There’s a video somewhere that tests the full sized trucks against each other on a bumpy test road and watches how they each flex. The tundra loses this test horribly and looks like it’s made of cardboard and flexes like crazy, about destroys itself. Boxed frame domestics handle it much better. Seems to me a strong frame would be a given on a truck, a truck is primarily a tool to do work and haul loads, but then much of the Tacoma demographic buys it because it’s a Tacoma, for recreation, looks, reliability, any number of reasons, but generally not primarily something to do work with, so Toyota designs it accordingly, and makes the frame weaker where they feel they can afford to.
    in any case i still love and prefer the Tacoma overall, there’s just a short list of things I’d change about it, like the frame.
    Taco*Sauce06 likes this.
  5. Nov 18, 2019 at 7:34 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    TFL did a long term review on a base Frontier. Maybe give it a watch.
  6. Nov 18, 2019 at 7:46 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The difference is the frontier is cheaper, has a wider turning radius, and is made by Nissan. It has things that are better than the tacoma, and things that are worse. Zero regrets owning one.
  7. Nov 18, 2019 at 8:50 PM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    yeah except you can only get it with the tiny eco boost engine. turbo has its benefits but i wouldnt want it offroad.
  8. Nov 19, 2019 at 6:25 AM
    Reddy
    Reddy Well-Known Member
    Scott
    Ohio
    '11 TRD OR AC
    OME 885's/Dakars/265's/belly skid
    That's funny, because when I was having some welding done on my first gen, we got to talking about plating frames and such and the guy said "I've done 'em all. Except Nissans." He elaborating a little more and talked about common spots for one brand or another to rust, but said he didn't see Nissans coming in for that type of repair like Toyotas. Not that that's a definitive answer, but it does indicate that they don't rust out as bad as some of the others. Make of it what you will.
  9. Nov 19, 2019 at 6:29 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    It's just not a Tacoma !
  10. Nov 19, 2019 at 6:29 AM
    96carboard
    That guy was definitely on crack. Rustiest rust buckets going. Even all the nuts and bolts -- every single one, you had to whack it several times with a hammer and then use a socket 2 sizes too small to fit.
  11. Nov 19, 2019 at 6:41 AM
    0xDEADBEEF
    Huh. Must have to wait longer than 12 years. Or maybe blanket generalizations are bullshit?
  12. Nov 19, 2019 at 6:52 AM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    I think all vehicles will rust if exposed to a salty environment. But some truck designs may have areas that trap that salt more than others.
    l don't think the experience of one automotive welder is absolutely definitive. But it is worth something. It's his experience for his area and his shop during his career. You'd think that during that time he would have seen some Frontiers, but he didn't.
    I love my Tacoma, and I wouldn't trade it for anything. But l just don't hear or read of other trucks having this severe of an issue.
    l know the numbers of sales year after year after year increases the chance of seeing this issue and others arise.
    But l still winder if there is an design issue considering it is still happening in trucks only 2 years old??
    Just my thoughts.
  13. Nov 19, 2019 at 7:53 AM
    OldManTacoFeels
    OldManTacoFeels [OP] The bells of tacos
    Billy Jr.
    2012 DCLB SR5
    Bilstein 5100s, AFE dry intake, Icon AAL pack, Bed stiffeners, and ideally some UCAs soon
    I thought tacomas (1st gen and early second gen) were the kings of rust on the road? There was a fucking frame recall right?
    SportsmanJake likes this.
  14. Nov 19, 2019 at 7:56 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Come on....the Taco ain't that bad. o_O
    TacomaMike37[QUOTED] likes this.
  15. Nov 19, 2019 at 7:56 AM
    #35
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    Thats really what it sounds like, is that it's just preference. I talked to my buddy lastnight and hes pretty sure hes going with the frontier because he feels like its so much more bang for his buck which I understand. He can get one with 50k on the odo, a canopy, lift, and after markets wheels for less than 19k. Base model Tacomas with 100k in this area go for that every 5mins lol.
  16. Nov 19, 2019 at 8:12 AM
    #36
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    My first truck was a 2000 Frontier, forest green. Loved that truck. It was the slowest dog to climb a hill, was horrendously under-powered, had an interior like a sardine can, and got terrible mileage, but I loved it. I gave up my bubble-gen mustang for it and never looked back.
    That said, I hesitate to buy a new one. Nissan currently has major issues on the corporate level, and that gives me pause. As they attempt to restructure and right the ship, who knows what may roll downhill into their product line. Will there be quality issues, service issues, will they start shutting down dealerships like Dodge did in 2008? I dunno. It's too much of a gamble for me at the minute.
  17. Nov 19, 2019 at 8:30 AM
    #37
    herektir
    herektir Member
    2009 silver access cab prerunner 2.7l i4 manual
    I had a 98 Frontier for 19 years in north Texas and not one spot of rust on frame, bolts , or springs. Bought an 09 Tacoma north Texas truck with 100k on it, minor surface rust on it 4 or 6 sq inches total. Nissan was one layer full box frame. It’s that 2 layer frame with bad sealing on Tacoma’s that is the problem.
  18. Nov 19, 2019 at 8:41 AM
    #38
    mray
    mray Well-Known Member
    Colorado
    2011 4cyl Base Access Cab 4x4
    More than just a preference, it's intelligent buying...there's a reason why the Tacoma outsells the Frontier 3 to 1
    https://www.tfltruck.com/2018/10/toyota-tacoma-chevy-colorado-nissan-frontier-september-2018-sales/
  19. Nov 19, 2019 at 8:44 AM
    #39
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    Solid truck. Much more affordable than Tacoma. Older design with less bells and whistles.
    Can look just as badass.
  20. Nov 19, 2019 at 8:46 AM
    #40
    virvak2
    virvak2 Well-Known Member
    Kyle
    Castle Rock
    '13 TRD Off-Road
    My brother has a 2015 Frontier base 4x4 model. He has not modified anything on the vehicle. Its comfortable on the freeway, but offroad it really lacks. He joined me on an easy trail, the Frontier sits much lower than the tacoma and the rear bumper sits farther out. We both decided the tacoma was the better all around vehicle.
    OldManTacoFeels[OP] likes this.
