Tacoma vs. Full Size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lucky7, Apr 17, 2011.
  1. Apr 17, 2011 at 6:30 PM
    Lucky7
    Lucky7 [OP] Member
    Hello all! I have lurked on the forum a while and have found the information shared to be very informative. I'm in the market for a new truck, and would like your help weighing the pros and cons of a Tacoma vs. A full size truck. Currently I own an F-150 lariat, and love it. I'm just looking to get into something newer. I own a building materials supply company, and log anywhere between 20-25k miles a year mixed city/highway. I don't tow often, but I do haul heavy material (between 500-2000 lbs)a few times a month. I drove a new Tacoma double cab, TRD and liked it. My only concern is that I might regret going from a full size truck to a midsize truck. I don't want to get caught in a jam and not be able to haul if needed. On the plus side the Tacoma sips gas just a bit better than a full size F-150 or Tundra, not drastically better mpg, but still more efficient. Price isn't a major concern, but the Tacoma new is approximately $30k vs a full size Tundra or F-150 with a few more options getting me into the $40's very easily. Also, on the highway i found the Tundra/F-150 to have less road noise Any advice or opinions would be greatly appreciated.
  2. Apr 17, 2011 at 6:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A Tacoma will NOT haul 2000# in the bed. If you require that kinda payload, then a Full size is on order.
  3. Apr 17, 2011 at 6:38 PM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    Tundra long bed of Sierra Duramax would be the 2 I would be looking at if i were you. I left a Silverado Z71 for the Tacoma because I needed to come down in size. Sounds like you need the bed too much to get a smallish truck.
  4. Apr 17, 2011 at 6:40 PM
    Lucky7
    Lucky7 [OP] Member
    Chris,
    I have gotten conflicting answers in reference to what the Tacoma can carry in the bed. I know 2,000 is def out of the question, but what about 1,000-1,500?
  5. Apr 17, 2011 at 6:42 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Yea definitely sounds like you need a full size. I went with the Tacoma because I only tow about 2000lbs and never have anything heavy in the bed. Obviously if the Tacoma offers what you need beside that you'd probably be okay not checking off all the option boxes on a full size I'm sure you can get a nice Tundra with the 5.7L for low-mid 30s rather than optioning all the way up into the 40s,
    And I think the payload rating for the Tacoma is less than 1000lbs. Not sure though.
  6. Apr 17, 2011 at 6:45 PM
    jking3002
    jking3002 Well-Known Member
    Jonathan
    Kentucky
    Scion tC
    Ricer muffler, window tent, trd shift knob.
    My Tacoma's payload is 1350. Says so right on the door... Anything more than that is silly... I wouldn't do more than 800 or so on a regular basis.
    Tacomas are nice trucks, and they can do some work, but they cannot do the work it looks like you need without some issues...
  7. Apr 17, 2011 at 6:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    1000 is doable, but more is pushing it. 1500# nope.
  8. Apr 17, 2011 at 6:46 PM
    Lucky7
    Lucky7 [OP] Member
    Thanks J,
    It sounds like I need full size. Looks like back to the drawing board!
  9. Apr 17, 2011 at 6:47 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2, plus the Tacoma isn't all that much better than the full sized trucks on gas. It's better than the Tundra just because that one sucks gas but it's not far off the from F-150 or the Silverado. Plus the Tacoma will not safely haul that kind of weight unless it's in a trailer. If you need a full size, a Tacoma is not a substitute. If you need a mid-size truck, the Tacoma is a great choice.
  10. Apr 17, 2011 at 6:49 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    The 4 cylinder Tacoma's have a higher payload than the V6. 1000-1500+ lbs....no problem. But if were to do it on a regular basis, I would skip the V6 Tacoma and jump into a V8 in a heartbeat.
  11. Apr 17, 2011 at 7:00 PM
    USA
    USA Member
    You definitely need a full size. I checked out the F-150 with its twin-turbo EcoBoost 3.5L V6 engine, developing 362 hp. That was phenomenal. EPA mileage rating is 16 city and 22 highway, not bad for a full-size truck. The new Ford 3.7L V6 engine develops 302 hp with the EPA mileage rating of 17 city and 23 highway, that's better than the Tacoma 4.0L V6 engine rating of 17/21.
    I am comparing midsize vs fullsize. I like the full size truck bed to haul many bikes and bulky (but not very heavy) things. A long bed Tacoma might work for me.
  12. Apr 18, 2011 at 7:32 AM
    Sleeper362
    Sleeper362 One Convenient Locations ......In Africa
    Corporal
    K-Vegas NC
    06 SR5 4X4 DC Shortbed
    Stick with the 150 and get the eco boost six that is coming out. It gets better mileage than a Tacoma and is a more proven platform than the Tundra or GMs. You need a 2500 GM to hang with a 150(0) Ford.
  13. Apr 18, 2011 at 7:49 AM
    nhgranite
    nhgranite Well-Known Member
    N.H
    fisher plow
    stock leafs on tacoma's are a joke. i just put in dakars and my payload went way up. i'm out of warrenty so it didn't matter.
  14. Apr 18, 2011 at 5:33 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    x2, you'd be lucky to not hit the bumper stops with 600 lbs. OP, do a search for rear spring TSB and you'll get plenty of info on the inferior stock springs used in these 2nd gen trucks...
  15. Apr 18, 2011 at 5:44 PM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I have to agree with most everyone here that the Tacoma is great of mild towing and hauling in the bed. I am mostly disturbed at how the mpg isn't better than a fullsize truck. While I enjoy my Tacoma - I am looking forward to my next truck; most likely a 4x4 F-150. I like my Tacoma - but she isn't a fullsize truck that I really needed and I realize that.
  16. Apr 18, 2011 at 6:05 PM
    Lucky7
    Lucky7 [OP] Member
    I am definitely looking into the F-150 ecoboost. I really appreciate all the helpful advice and honesty. I will keep you informed when I make the purchase.
  17. Apr 18, 2011 at 7:11 PM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    Sold my 02 F150 S/Crew and bought a 2010 Tacoma Nov. 09. The Tacoma gets a bit better gas mileage than my old truck. Not huge difference, maybe a couple mpg better in town. On highway I have actually gotten almost identical mileage at speeds of 70 mph. The F150 being bigger is way more comfortable. The Taco looks prettier. Price for my Tacoma was just over 30K before tax. I did recently drive a a new eco-boost F150 crew. If it gets the mileage they say it's gonna be a sweet one. I might just have to go have another look.
    If towing regularly is your thing, go big or stay home. K
  18. Apr 18, 2011 at 7:43 PM
    saumon
    saumon Well-Known Member
    Montreal, Qc, Canada
    2015 DC LB 4x4 SR5 SSM
    If you haul bulding supplies on a regular basis, forget it. Sheets of plywood and drywall doesn't fit between the fenders...
  19. Apr 18, 2011 at 8:06 PM
    tx_shooter
    Exactly. The Tacoma is a great fun truck - it isn't a daily work truck.
  20. Apr 18, 2011 at 8:10 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    I had about 2300 on my first gen
    No problems at all
