Tacoma vs. Full Size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lucky7, Apr 17, 2011.
  1. Apr 18, 2011 at 8:43 PM
    BarefootBandit
    BarefootBandit Well-Known Member
    06 Double-Cab TRD Sport 6-Speed
    Keep in mind 4 adult passengers can put you at 800lb.
  2. Apr 18, 2011 at 8:50 PM
    S.B.
    S.B. Well-Known Member
    Sean
    SD, CA Now in Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    SAW 2.0s, Wheeler's 3-leaf AAL, On Board Air, 255/85/16 Cooper Discover S/T, CBI Sliders, Built right UCAs, 6" Harbor Freight Lights (converted to HIDs), KC Slim Lights.
    OZ-T would disagree.
  3. Apr 18, 2011 at 8:57 PM
    Sleeper362
    Sleeper362 One Convenient Locations ......In Africa
    Corporal
    K-Vegas NC
    06 SR5 4X4 DC Shortbed
    Doesn't OZ-T Offroad for a living though?
  4. Apr 18, 2011 at 9:06 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    You need a real truck, not a Toy.
    I'd look at the F150 with the turbo 6 cyl.
    Or a used diesel.
    Tacos are sport trucks, more about styling than function.
  5. Apr 18, 2011 at 9:19 PM
    USA
    USA Member
    Yep, I've just checked the F150 spec: the length between the fenders is 50 inches, that means that 8x4 feet sheets of plywood will lay flat on the bed. The Tacoma's distance between the fenders is 41.5"
  6. Apr 18, 2011 at 10:53 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    A chevy 3/4 hauls 2200lb,( model/pkg /yr dependant), in a 4x4 and crew cab, I doubt any 1/2 ton 4x4 can carry 1800lb unless its a reg cab or 2wd. Simply put, if you want to haul 2000 lb , list a given model and check its payload,open 2-3 explorer tabs even to flip quicker between models/brand.Also know that some options/fuel/passengers ALL take from the payload. As far as building supplies go , its comparable to some of the work I do. A diesel ,3/4ton,2wd ,perhaps extended cab is a great setup for good mpg empty , and 2000lb range payload.
  7. Apr 19, 2011 at 3:46 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    F150 Ecoboost V6 has a 3k payload.
  8. Apr 19, 2011 at 6:28 AM
    Tacoyota
    08 4wd
    http://www.ford.com/trucks/f150/specifications/payload/
    Now thats something new,nice, available early 2011.
    As a whole among all brands,the 1/2 ton catagory is...or was characterized by 1800lb range 4x2 or reg cabs , and anorexic access and crew cabs with 1300lb payloads.
    With that new data, OP could just opt for one of the listed choices,now i wonder what dodge/chevy/toyota have new for payloads.
  9. Apr 19, 2011 at 7:14 PM
    Dustyroades
    Dustyroades Well-Known Member
    Ontario
    '09 MGM AC 4x4 SR5 2.7L 5spd
    Front Bilstein 5100s at 1.75", rear 1.5" AAL w/ TSB and OME N182s, P265/75R16 Hankook A/Ts
    Why is Ford not shouting this number from the rooftops? When you take into account a ~200lb driver this means you can now carry just about twice as much stuff in a half-ton.
    Isn't it also ironic a half-ton can now haul 1.5 tons?
  10. Apr 19, 2011 at 7:30 PM
    Tacoyota
    08 4wd
    I thought about that today at work. I suspect they just stopped making 1/2 ton frames totally, ran with a 3/4 ton frame with the appropriate axles.Really.....8200lb and calling it a half ton, 10 years ago,a light 3/4 ton was around 7200 lbs. That implies the truck weighs around 5000lb curb weight.
    Maybe the ol "one ton" toyota small truck will return, remember them in the late 70s/early 80s?:D
  11. Apr 20, 2011 at 4:49 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    x2.
  12. Apr 20, 2011 at 5:22 AM
    MSCOFF
    MSCOFF Well-Known Member
    Mark
    CT
    2017 SR5 AC 4WD
    I looked at a Nissan Frontier but bought the Tacoma. However the Frontier is listed (V6) with a bit mor HP, torque, and a higher payload weight by about 150 pounds.
  13. Apr 20, 2011 at 5:28 AM
    MGH-PA
    MGH-PA Well-Known Member
    Northcentral, PA
    05 Tacoma TRD AC 4x4
    265/75/16 Nitto Terra Grapplers, Bestop
    To this day I regret not getting a fullsize. If you're not offroading, or for whatever reason you don't like parking something bigger, there is no reason not to get a modern fullsize. MPG is better in the Tacoma, but imho (based on friends around me driving various late model 1/2 tons), this difference is negligible.
    I load my truck a lot (firewood, pavers, lumber, scrap metal, etc), and I'm just an average homeowner. This truck wasn't built for this. Do I still like it? Of course. It's a great truck. It's just a niche truck, imho.
  14. Apr 20, 2011 at 5:42 AM
    paul's08
    paul's08 Active Member
    Paul
    indiana
    08 TRD Sport
    Here is a picture of my 2008 with TSP springs loaded with 1100 lbs of 4X8 and 4X10 sheets of drywall.
  15. Apr 20, 2011 at 6:35 AM
    #35
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I agree with you. There are some things that Tacoma's simply can't do as well as a full size truck. That's why I have a 5.4 F-150 for pulling stumps and 4x4 for winter, etc. But I love my gas mileage and I've been able to haul pretty much everything I wanted to so far with my little 4 banger. I'm hauling a load of outdoor furniture to South Carolina on Friday...should be about 600 miles.
  16. Apr 20, 2011 at 4:15 PM
    #36
    Tacoyota
    08 4wd
    That ecoboost engine and whopping payload are quite impressive. I tend to be whatever you want to call me , cynical,jaded, heard all that etc, usually I'm sick of hearing the newest 1 up game for towing stats.I hope that eco boost translates into some good competition between truck makers. Imagine that 3.5L twin turbo 360 hp 400 ft/lb engine in a tacoma!
  17. Apr 20, 2011 at 8:31 PM
    #37
    USA
    USA Member
    Agreed, don't take my words for it. Go and test drive that twin turbo engine on a F-150 to see what it's like. And if possible, start a company to fit that engine in the Tacoma ;)
  18. Apr 20, 2011 at 8:42 PM
    #38
    Sleeper362
    Corporal
    K-Vegas NC
    A friend of mine just picked one up today, he said laying into it the whole way home from the dealership, he still pulled down 18mpg (all city driving), no shit. When he says he laid into it I know how he drives, it was at WOT the whole time. Here is a pick.
  19. Apr 20, 2011 at 8:43 PM
    #39
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Or get a trailer and just pull your shit around. The Taco's too sexy to mess up from throwing work loads in there. It's easy/cheap to increase the load capacity on the Taco, it has the power, but why get shit all over your truck... get a trailer for work, unhook it on the weekend, enjoy your sweet new truck.
    But seeing as I regularly drive full-sized Chevy, Dodge, and Fords at work: go with Ford.
  20. Apr 20, 2011 at 8:46 PM
    #40
    Sleeper362
    Corporal
    K-Vegas NC
    Storing a trailer can be a bitch though. And why have a bed if your never going to use it?
