Tacoma vs Hilux
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JimmyRiddle, May 24, 2013.
  1. May 27, 2013 at 8:46 AM
    #41
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Just listen to the diesels in the beginning!
  2. May 27, 2013 at 9:07 AM
    #42
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Cold, 33 to 50 degrees .
  3. May 27, 2013 at 9:14 AM
    #43
    CrAiG
    CrAiG Well-Known Member
    Tacoma889
    2010 toyota tacoma TRD
    Three inch spacer lift
    I love my Tacoma but i came across this in Moab this weekend..
    F0B32736-59BF-4818-80FD-22D5291D8EEE-221_b6d86901814eecc112ffdb0a8e39334fae8c371d.jpgDAA477D3-86BD-4FD1-B8B6-B517DE435E80-221_635189c3fa18efc9f4ce4977486e247f07589dd5.jpg
  4. May 27, 2013 at 9:17 AM
    #44
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Not true. Suspension, driveline and brakes of the Hilux and Taco are basically the same except for stiffer leaf springs on the Hilux.
    If the Hilux were sold in the US, it likely won't be able to maintain its 1-ton payload rating when subjected to US test standards.
  5. May 27, 2013 at 9:53 AM
    #45
    Seer
    Seer Well-Known Member
    Tom
    Bayfield, CO
    13 Double Cab 4x4 stock
    I was lusting after seeing it on Top Gear [​IMG]
    After seeing this,
    I'll stick with the Taco... even stock.
  6. May 27, 2013 at 12:17 PM
    #46
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    I've been wondering this for a while BUT....is that Hilux rocking an Avid Off Road light bar? I love the look of that light bar
  7. May 27, 2013 at 1:09 PM
    #47
    Seer
    Tom
    Bayfield, CO
    From what I remember about the truck was that it was customized in Canada. An Avid would be totally available up there. It was the tires and fenders that got me.
  8. May 27, 2013 at 1:21 PM
    #48
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    comparing stock to stock..the tacoma looks better.
    modified? all bets are off.
  9. May 27, 2013 at 1:37 PM
    #49
    AFZ
    AFZ Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    I believe those are Iceland Arctic trucks. The huge tires are so they float on the packed snow.
  10. May 27, 2013 at 1:41 PM
    #50
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    Hilux Access Cab 4x4's payload is 2,500lb. Tacoma AC is 1,600lbs.
  11. May 27, 2013 at 1:42 PM
    #51
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    But what makes the Tacoma better in your opinion? Are you driving a current model Hilux, or an older generation?
  12. May 27, 2013 at 1:44 PM
    #52
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    isnt the tacoma rated to tow more and has a higher payload? i dont really understand that since it has about the same torque at a lower rpm show it should have no problem pulling and if all things else are pretty similar i would think so would weight ratings, unless the hilux just weights that much more.
  13. May 27, 2013 at 1:45 PM
    #53
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    My understanding is that the Tacoma is cheaper to manufacture and has a wider profit margin. The Hilux is has to deal with more fierce competition globally from the Ranger.
  14. May 27, 2013 at 1:48 PM
    #54
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    Tow ratings have more to do with transmission cooling, hitch rating and braking ability.
    Hilux is rated to tow 5,500lb compared to the Tacoma's 6,500lbs.
    As I stated in a previous post, the Hilux has a higher payload capacity.
  15. May 27, 2013 at 1:58 PM
    #55
    yota243
    E.J.
    north Alabama
    i see now on the payload i look it up. so the tacoma has a better hitch rating? that seem illogical. and the hilux doesnt come with a tranny cooler. just doesnt seem like its really set up to be the "work horse" that they advertise it to be. so as everyone would agree the best thing would be a tacoma with the 3.0 D4D in it and a tundra 10.5 rearend?
  16. May 27, 2013 at 1:59 PM
    #56
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    I don't know if they "ride" more like a car. A Tacoma is certainly car feeling when compared to my 3rd Gen 4runner.
    The reason for the exterior being more rounded and modern is the safety standards of the world. Europe adopted the "French Pedestrian Law" which is basically any car sold in Europe has to be tested with pedestrian impacts. So I doubt a Tacoma would pass the test with the flat broad front. You can see the trend for "rounded" fronts from all the European and global makes these days. Look how VWs went from a flat front to a round nose, ect.
    The interior being more refined and car like... well when you are dropping $40k on a truck you don't want a tractor with a sheet metal dash. The Hilux has received 2-3 face lifts in the last few years. Toyota has certainly put more effort in to it.
    2013 Ranger
    2013 Aramok
  17. May 27, 2013 at 2:09 PM
    #57
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    Meh. You have to remember the Hilux is sold in a 100+ markets with a dozen power-train configurations and trim levels. I'm sure most "work-horse" trucks are stripper diesel single cabs with a manual.
    I'd rather have a Tacoma Body, Hilux chassis, Ranger Interior and Ford 9" rear. :p
  18. May 27, 2013 at 2:10 PM
    #58
    bolio
    bolio Well-Known Member
    San Antonio
    08 trd OR 4x4
    i have driven both, but only the 2wd gas version of the Hilux in Mexico. The Hilux is tougher and rides more like an old school truck, less refined ride and steering. IMO my Taco looks better stock, but modified they both look good. For me the Taco with the D4D would be perfect, 32mpg+ hw and low range torque, one can dream.
  19. May 27, 2013 at 2:10 PM
    #59
    taco terror
    USA
    I'd take that V-dub over the ranger any day.
  20. May 27, 2013 at 2:22 PM
    #60
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    I drove the VW AMAROK the other day. Turbo diesel. Had about 1600lbs in the bed -- was doing fine. Drives very nice and it seems a bit bigger than the Tacoma. The seats were way better than the Tacomas. Fully adjustable
