Tacoma Vs. Rivian
Discussion in 'General Tacoma Talk' started by mustainefan, Jul 25, 2022.
  1. Aug 31, 2022 at 11:43 AM
    #2341
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
  2. Aug 31, 2022 at 11:44 AM
    #2342
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    even with the actual bulletin linked you still call it fake news?
    o_O
    how dense are you?
  3. Aug 31, 2022 at 11:45 AM
    #2343
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Is it really just one adapter? Have you seen TFLs Alaska trip? Also they didn’t forget to bring the adapter. They didn’t even own one. There’s that reading comprehension stuff again.
    MR E30 likes this.
  4. Aug 31, 2022 at 11:49 AM
    #2344
    uurx
    '12 t|x pro
    can you say....
    Lithium-Ion
    :hattip:
  5. Aug 31, 2022 at 11:53 AM
    #2345
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    The "should have" is for a reason. The problems these people encountered aren't new. Most people know about them. EVs have limitations. This isn't news.
    Where I live airports have plugs already mainly for block heaters. You can plug an EV into that for the week or two. My old gas truck wouldn't stand a chance of starting after sitting for a week in the winter.
    These are known issues. The article, to me, shows how dumb the people are. They should have read some more articles on EVs before they set out to write this one. Though I suppose, just maybe, they went out looking for a story.
  6. Aug 31, 2022 at 11:53 AM
    #2346
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If you want to cover all your charge station bases I think you’d only need two adapters. One to chademo and one for the Tesla plug. For added capability out away from built up areas having a 50 amp and 30 amp RV adapters would be a decent idea and not take up much space.
  7. Aug 31, 2022 at 11:59 AM
    #2347
    Turd Ferguson
    Taxachusetts
    You guys are insane. They planned the trip out and should have had plenty of range to get there and back without charging. No one knew they would lose that much charge just sitting there, not even Rivian.
    Here in the US we don’t have outlets for block heaters at the airport. There may be a couple spots with EV chargers but you shouldn’t be a douche and leave your car parked at one for your entire trip.
    .劉煒, 99TacoDriver and MR E30 like this.
  8. Aug 31, 2022 at 12:02 PM
    #2348
    uurx
    '12 t|x pro
    "shouldn't" be a douche
    now that is a wild and revolutionary concept
  9. Aug 31, 2022 at 12:03 PM
    #2349
    Turd Ferguson
    Taxachusetts
    You should try it sometime. :D
    44-16 Taco and 99TacoDriver like this.
  10. Aug 31, 2022 at 12:08 PM
    #2350
    uurx
    '12 t|x pro
    Malvolio and stevesnj like this.
  11. Aug 31, 2022 at 12:08 PM
    #2351
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    Eh, I have a tesla adapter for L2, it's basically the only one you 'need'. Kinda tiny and fits underneath the drivers seat. Used it yesterday (was down to about 5 miles of range, J1772 charger was in use so I just used the tesla one. :p I think I pissed off a tesla owner or two)
    It's a pretty bad drain, though, definitely a problem if your onboard systems are using that much electricity when idle.
    stevesnj likes this.
  12. Aug 31, 2022 at 12:11 PM
    #2352
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    If they knew they were losing range overnight, and knew it could get cold, and didn't bring the correct gear, then I don't know what to say. This is a case where an EV is obviously not the best use. Loss of range in cold is something that has been know for a long time. It's the reason I didn't use lithium-ion drill batteries at work for the longest time. I knew this a decade ago. Smarter people have known it for longer.
    I'm not "insane." I'm not the one posting articles on the issues of EVs like no one knows about them.
    Seems like an issue with the truck, an issue with planning, and not knowing your equipment were to blame here.
    I know I've had some dumb moments in a gas vehicle out in the woods hoping I'd get back. Though the gas truck admittedly becomes less of a brick when it runs out of fuel than an EV.
    The US definitely has airports with plugs... But its obviously a northern thing. They are only 120v but every stall has one. You're not blocking anyone by using them. It would be enough juice to maintain your battery level at least.
  13. Aug 31, 2022 at 12:18 PM
    #2353
    Turd Ferguson
    Taxachusetts
    I’m pretty confident that no one here knew you would lose 121 miles of range just parked. That’s crazy. Is the Rivian a warm weather vehicle only. It’s an adventure vehicle that fails at adventure. In regards to your lithium drill batteries not working in the cold, I use them on my auger for ice fishing without any problems.
    MR E30 likes this.
  14. Aug 31, 2022 at 12:20 PM
    #2354
    uurx
    '12 t|x pro
    just dont forget to plug it in though... right??
  15. Aug 31, 2022 at 12:26 PM
    #2355
    Turd Ferguson
    Taxachusetts
    No outlets out on the lake.
  16. Aug 31, 2022 at 12:27 PM
    #2356
    uurx
    '12 t|x pro
  17. Aug 31, 2022 at 12:28 PM
    #2357
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Have you heard of the Donner Party?
  18. Aug 31, 2022 at 12:28 PM
    #2358
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    In reality the Rivian is an adventure vehicle in marketing mostly. I personally wouldn't do much adventuring with it. I agree it mostly fails at adventure.
    If you read on real-world usage of EVs you can find plenty of cases where the vehicles lose a ton of range in the cold. Sure they didn't know exactly how many miles but they went off into the mountains anyway without testing it. The amount is probably higher than I would have guessed but it's not shocking. Thinking they'd get "most" of it back with regenerative braking was foolish too. Seems they knew nothing about the vehicle they were driving.
    In regards to your ice auger... I bet it does work. The lithium ion batteries today are better than the old ones. My drills are all lithium ion. But just because it "works" doesn't mean it doesn't lose capacity. It doesn't shock me when my drills are dead in the morning in the winter or that I can drill half the holes that I would in the summer.
    The guys that wrote this article seem like the ones that would go ice fishing, with a battery with a half charge they took out of a warm garage, and then be shocked when they can't go fishing on day four. There's a reason why, where I live at least, most of us use gas augers still. But happily drilling holes with no issues doesn't make for a good story.
  19. Aug 31, 2022 at 12:42 PM
    #2359
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Up in Alaska we have plug ins at all the airports and for most employees at businesses. Obviously a different world compared to the lower 48 but that’s still the US.
    I won’t blame the guys for not knowing they’d loose 75% of the battery sitting still and not using it. That’s a definite problem that Rivian needs to address.
  20. Aug 31, 2022 at 1:01 PM
    #2360
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    I think you're really batacoma . You know it's okay to be wrong. When I'm wrong I admit it. You can't stand to be wrong. I see they bought one. If they test electric vehicles they should have been prepared. BUt no one is perfect. Just poor planers.
