Tacoma Vs. Rivian
Discussion in 'General Tacoma Talk' started by mustainefan, Jul 25, 2022.
  1. Sep 30, 2022 at 5:52 PM
    #3121
    McGillz
    McGillz “It’s not accessorizing... It’s a BUILD!”
    New Jersey
    '19 TRD Sport Barcelona Red
    KMC Grenade wheels / BFG KO2 305/65/17 E rated, ECGS clamshell bushing, CMC, ARB Old Man Emu 2.5" lift- ARB 90000 OME Nitrocharger Sport Strut, ARB OME - 2886 Coil Springs (heavy), ARB OME Leaf Springs - EL111R (medium), SPC Specialty Products Upper Control Arms, Retrax One XR Tonneau Cover, Rhino Rack Vortex rails, Rago Fabrication Bed Stiffener, Tacomabeast- Spyder headlights /sequential LED DRL, Rigid driving/fog lightbar, RCI steel Skid Plate, Fab Fours Vengeance front bumper- High Pre Runner Guard, Fab Fours rear bumper, MillerCAT stainless Cat Shield, FEND-X wheel liners, Protec splash guards, Bushwhacker flares (Rhinoliner painted). For now…. Wife cut me off!!!
    Wasn't that the DeLorean commercial?
  2. Oct 1, 2022 at 12:53 AM
    #3122
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
  3. Oct 1, 2022 at 12:59 AM
    #3123
    Deacon Blues
    Colorado
    2017 SR5
  4. Oct 1, 2022 at 1:22 AM
    #3124
    GrandTheftAngel
    GrandTheftAngel Well-Known Member
    Angel
    perhaps a better comparison is a 2nd gen to a rivian in terms of aesthetic. I feel like the 2nd gens have a similar look that is less aggressive looking compared to the 3rd gens that really make it look good and less toony
  5. Oct 1, 2022 at 1:26 AM
    #3125
    GrandTheftAngel
    Angel
    stevesnj likes this.
  6. Oct 1, 2022 at 6:26 AM
    #3126
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Neither of those worry me in the least. The harassment issue will be sorted out and likely settled out of court - it’s unfortunately a fairly common complaint these days in all business sectors. It’s also unfortunately an easy way for disgruntled employees to make a big public stink and get paid off to make it go away.
    The stock price is just an investor salty about losing a little bit of money. That’s how gambling in the stock market works. I’m down more than that on Rivian and not crying about it. The lawsuit was filed six months ago and I haven’t seen an update since.
  7. Oct 1, 2022 at 2:54 PM
    #3127
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    So I noticed that today the closest charging station to my house was been removed. About 6 charging stations were removed and capped. Good news is there are no longer teslas perma-parked in them.
    What’s the reasoning for removals like this?
  8. Oct 1, 2022 at 4:04 PM
    #3128
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Upgrades maybe?
  9. Oct 1, 2022 at 4:25 PM
    #3129
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Are they EVGo? They are doing the same near me. They are installing higher efficiency stations with better cross manufacturer charging abilities and I believe Tesla adaptation.
  10. Oct 1, 2022 at 5:07 PM
    #3130
    JoeCOVA
    Joe
    Colorado Springs
    Could be. I guess I’ll see if anything goes back in.
    stevesnj[QUOTED] likes this.
  11. Oct 1, 2022 at 5:49 PM
    #3131
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Could also be Electrified America. I just saw a video with them upgrading the chargers at another Colorado location.
  12. Oct 1, 2022 at 6:00 PM
    #3132
    Taco X
    Taco X Man of almost frightening genius
    James
    Midwest and Southwest
    2022 SR 4x4 V6
    lift, 255/85r16, 5.29 gears
    The problem is the weight with such a small sidewall. I went with 33" on a 16" wheel, which, correct me if I'm wrong, is like 3" more sidewall and thousands of pounds lighter than a rivian. I'm guessing I'll be pulling a lot of these out of the sand pretty often
  13. Oct 1, 2022 at 6:04 PM
    #3133
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    https://stories.rivian.com/software-update-soft-sand-mode
    Also, every Rivian has an air compressor so they are all capable of airing down and then airing back up.
  14. Oct 1, 2022 at 6:11 PM
    #3134
    Taco X
    James
    2022 SR 4x4 V6
    Modes are nice but you can't beat physics. When you air down with a larger sidewall you get a tank track effect that keeps the vehicle from sinking. Rivian will be notorious for getting stuck
    Onboard air compressors are cool though. I carry four 20Vs with me
    MR E30 likes this.
  15. Oct 1, 2022 at 6:11 PM
    #3135
    stevesnj
  16. Oct 1, 2022 at 6:19 PM
    #3136
    Taco X
    James
    2022 SR 4x4 V6
    MR E30 and .劉煒 like this.
  17. Oct 1, 2022 at 6:21 PM
    #3137
    stevesnj
    Well it's a soft sand mode. Doesn't say how deep of sand it will work in
  18. Oct 1, 2022 at 6:25 PM
    #3138
    Taco X
    James
    2022 SR 4x4 V6
    True. I'm guessing it just lessons the torque and keeps the driver from making sudden starts and stops. I'm sure it can help an unexperienced driver somewhat. It can't make you reverse if you are stopped by the sand building up in front of you etc, so plenty of mistakes will be available for the driver
  19. Oct 1, 2022 at 6:30 PM
    #3139
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    The problem is the weight with so much sidewall actually. A lot of sidewall leads to sloppy handling which is even worse when you have a heavy truck with a lot of sidewall. A heavy Tacoma on 33's wallows around the road compared to a stock truck on the factory 31s. Sand performance might suffer but I'd bet on the much better 4wd drivetrain of the Rivian being an advantage over a Tacoma with open diffs in the sand.
  20. Oct 1, 2022 at 6:40 PM
    #3140
    stevesnj
    Just like every other vehicle.
