Tacoma Vs. Rivian
Discussion in 'General Tacoma Talk' started by mustainefan, Jul 25, 2022.
  1. Oct 3, 2022 at 8:23 PM
    #3181
    Taco X
    Taco X Man of almost frightening genius
    James
    Midwest and Southwest
    2022 SR 4x4 V6
    lift, 255/85r16, 5.29 gears
    It is very significantly more. Did you read his comment? The Rivian weighs 2500lbs (maybe 3000 with a bigger battery) more than a taco. That has major implications for a great number of things. That's why my stance is that for common people, a small EV for around the city is great, but for towing, overlanding, trails etc, they're not a good solution
    MR E30 and Turd Ferguson like this.
  2. Oct 3, 2022 at 9:29 PM
    #3182
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The R1T curb weight of 5840lbs is roughly 1300lbs heavier than a DCSB Tacoma at 4500lbs. It’s in the same window as a F150, Ram 1500 or Chevy/GMC 1500. The Rivian isn’t light but it’s not heavier than other trucks that still tow, overland, off-road, etc.
    It weighs about 600lbs less than my TRX and I do all of that without problems.
  3. Oct 3, 2022 at 10:40 PM
    #3183
    Taco X
    James
    2022 SR 4x4 V6
    You might wanna let them know to edit their wikipedia page. The curb weight is 7,148lbs. That would be obnoxiously heavy
    MR E30 likes this.
  4. Oct 3, 2022 at 10:47 PM
    #3184
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    If you zoom in you can see the GVWR on this R1T is 65xx pounds with a payload of 1419lbs. That math works out to about a 5100lb curb weight. Google said 5840lbs curb weight and 7148lbs GVWR. I completely forgot to check these stickers on the one I test drove a while back.
    shakerhood likes this.
  5. Oct 3, 2022 at 10:48 PM
    #3185
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I imagine you would probably wear thru tires at a much faster rate also.
  6. Oct 4, 2022 at 4:53 AM
    #3186
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    7000+ is what I see everywhere online.
  7. Oct 4, 2022 at 7:31 AM
    #3187
    Turd Ferguson
    Taxachusetts
    Are you sure that’s not an “8” in the start of the GVWR?
  8. Oct 4, 2022 at 7:56 AM
    #3188
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    No, I’m not sure but I thought it looked like a 6. It’s not a very good picture but it’s the only one I found quickly last night. Wanted the actual numbers not Wikipedia numbers.
  9. Oct 4, 2022 at 7:57 AM
    #3189
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    He doesn't do accuracy or actual.
  10. Oct 4, 2022 at 7:57 AM
    #3190
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Those are surprisingly close to the numbers on my 2002 K2500 Suburban that I used to have. I had a travel trailer then.
  11. Oct 4, 2022 at 8:01 AM
    #3191
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    @Turd Ferguson a better picture, it is an 8 not a 6. Maths out to a 7100lb curb weight so another number that doesn’t match any of the others we’ve found so far.
    shakerhood, JoeCOVA and stevesnj like this.
  12. Oct 4, 2022 at 8:03 AM
    #3192
    stevesnj
    I think my numbers i found from EVspecs.com may have been for the dual motor, is this from a quad?
  13. Oct 4, 2022 at 8:04 AM
    #3193
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I wonder if they played legal games and upped the GVWR to above 8500lbs to take advantage of the more relaxed regulations for heavy duty trucks.
  14. Oct 4, 2022 at 8:04 AM
    #3194
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Yes, that sticker is off a Launch Efition R1T according to the source.
  15. Oct 4, 2022 at 8:05 AM
    #3195
    stevesnj
    I deleted my posts. Just so many numbers floating around and can't seem to find them on Rivians site.
  16. Oct 4, 2022 at 8:12 AM
    #3196
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    What could we add to add weight??? Another battery in a bluetooth speaker! /s
  17. Oct 4, 2022 at 8:14 AM
    #3197
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Nah, the GVWR is just a rating, not an actual weight. In theory it could have a 5800lb curb weight, 1400lb payload rating and a 8500lb gross weight and be legal. I should have mine in the next few weeks and will go over the scales and find out for sure.
  18. Oct 4, 2022 at 8:16 AM
    #3198
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Just makin fun of the gimmicks, thats all.
    crazysccrmd[QUOTED] likes this.
  19. Oct 4, 2022 at 8:35 AM
    #3199
    stevesnj
    Happen to get in quick on a chat with Rivian....here's what they say on weights.
    No separate sheet breakdown for weights on drivetrains or MaxPacks. I would think the dual and quad motor weights would be different with or without MAxPAcks and model types R1T and R1S.
    crazysccrmd likes this.
  20. Oct 4, 2022 at 9:06 AM
    #3200
    Taco X
    James
    2022 SR 4x4 V6
    Looks like Rivian told Edmund on their review that the curb weight was the same is on the wiki. Leads me to believe this is accurate
    MR E30 likes this.
