Tacoma Vs. Rivian
Discussion in 'General Tacoma Talk' started by mustainefan, Jul 25, 2022.
  1. Oct 31, 2022 at 4:22 PM
    #4021
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Makes you wonder if EVs made cooler noises would they be on board with switching from ICE?
  2. Oct 31, 2022 at 4:23 PM
    #4022
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Like this? SOLD!!!!
    https://youtu.be/4NgSZ8sjDgU
    chuam and WaitingOnMyR1T[QUOTED] like this.
  3. Oct 31, 2022 at 4:25 PM
    #4023
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    stevesnj[QUOTED] likes this.
  4. Oct 31, 2022 at 4:54 PM
    #4024
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    Pic of said Outback. It’s a total sleeper.
  5. Oct 31, 2022 at 4:55 PM
    #4025
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I want my diesel vacuum cleaner back
    Malvolio likes this.
  6. Oct 31, 2022 at 4:56 PM
    #4026
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    sleepers are the best
  7. Oct 31, 2022 at 5:47 PM
    #4027
    crazeflier007
    crazeflier007 Well-Known Member
    2019 Cement Tacoma TRD-Off Road 4x4
    Old Man Emu lift, TRD PRO rims with BFG All-Terrains, ARB Front Bumper with Warn Winch, Baja Designs LP6 lights and S2 Pro spots, TRD Intake, Prinsu Roof Rack, ARE Topper with Yakima Crossbars, lots more to come.
    Do like that side slideout/stowage area if it is like the ones I've seen in pics. See one running around in the morning on the way to drop my son off at school. Front is a little funky but the truck overall doesn't look bad. Have to agree if you are just looking for a vehicle to drive around and not do any truck stuff with but want to have a "truck" it fits the bill. I would probably take a Maverick or Santa Cruz over it if I was going to need to haul anything in the bed.
  8. Oct 31, 2022 at 5:55 PM
    #4028
    erok81
    erok81 Well-Known Member
    Imposter
    Ah got it. That makes sense.
    I don’t have EV-Phobia by the way. They have their place. I don’t have any plans to get one anytime soon. Although would be nice for commenting.
    Speaking of trailhead fuel ups (I’ve also never started a trail at a gas station) one big advantage ICE has is being able to easily carry extra fuel. Something you can’t do with an EV unless you sit for x time with a Solar panel. I’m sure that’s already been covered in the 200 pages. Just crossed my mind after reading your post.
    DRAWN and dumontrider[QUOTED] like this.
  9. Oct 31, 2022 at 6:13 PM
    #4029
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You could charge with a generator at the trailhead. A Predator 9500 inverter generator ($2400) burning about 1.5gal/hr at full output can provide 7kw output. The 6.8gal tank lasts about 4.5hrs and would deliver ~32kw to the truck on one tank. That’s ~70 miles range or 10mpg. Not practical at all but totally doable if needed.
    e6400ultra and erok81 like this.
  10. Oct 31, 2022 at 6:16 PM
    #4030
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Those are both way, way, way cheaper but still have the same size bed and nearly identical payload ratings. The Rivian more than double les their towing capacity though.
    crazeflier007[QUOTED] likes this.
  11. Oct 31, 2022 at 6:17 PM
    #4031
    crazeflier007
    True but what do you lose on the overall mileage range under load?
  12. Oct 31, 2022 at 6:21 PM
    #4032
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    I’m sure the R1T is at least 10x more fun to drive though.
  13. Oct 31, 2022 at 6:22 PM
    #4033
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    A guy that tested it at full payload capacity had a 7% range decrease. Not a lot of other data to compare with but the testing was done pretty well.
    https://youtu.be/LFT08sFOtcw
  14. Oct 31, 2022 at 6:48 PM
    #4034
    erok81
    Imposter
    I’m not going to lie, if I saw a Rivian pulled over on a trail hauling gas and a generator to charge I’d laugh a little.
    But realistically it’s going to have enough range for pretty much any trail a normal person is going to do.
  15. Oct 31, 2022 at 7:12 PM
    #4035
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I’ve driven a couple of Model 3’s, the R1T, an i3 and a Leaf, and to me one cool thing about EV’s is the quiet acceleration. I like the scream, thump, or growl of an ICE as much as the next guy … for about 30 seconds. I haven’t had a modified an exhaust system since the Seventies. As they used to say, “Less sound, more ground”.
  16. Oct 31, 2022 at 7:15 PM
    #4036
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    For fun I hooked up the truck to my trailer to see if it would charge. My trailer has a built in Onan 3.6kw propane generator that burns .5gal/hr at half output. The truck wouldn’t let me increase above 12 amp charge rate which should equal 1.44kw but the truck showed 2kw charge rate. It can’t display decimal places so I’m guessing it just rounds up. Regardless, it works.
    Generator burn solely for charging the truck should have been about .4gal/hr and I just paid $3.69/gal to fill the 30lb/7.4gal propane tank. A full tank would charge for 18.5hrs, provide 26.6kw of charge or 55 miles at a cost of ~$27. Not worth it except in the most extreme cases.
  17. Oct 31, 2022 at 7:16 PM
    #4037
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    That’s the thing about a typical modified ICE car, you can be going the speed limit or slower and people get angry at you because you need to “slow down!” (because they equate noise and speed). In an EV, you’ll never have those issues.
    DRAWN and erok81 like this.
  18. Oct 31, 2022 at 7:36 PM
    #4038
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Are you calling me batshit stupid? People that call others stupid generally aren’t the smartest themselves. Do some research. People are not getting 300 mile range while loaded with gear or anything other than perfect driving conditions.
    MR E30 likes this.
  19. Oct 31, 2022 at 8:34 PM
    #4039
    Turd Ferguson
    Taxachusetts
    Why do you even want a Rivian? It seems like you already have 3 perfect vehicles. You have a truck for truck stuff and no worry about range. The Tesla for saving gas and going fast and the wagon for hauling stuff under a roof and also going fast.
  20. Oct 31, 2022 at 9:53 PM
    #4040
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    It’s not about saving gas and I don’t drive the Subarus, although both were my daily drivers at one point. Both? Sorry forgot to mention the WRX.
    hack4875 and doublethebass like this.
