Tacoma Vs. Rivian
Discussion in 'General Tacoma Talk' started by mustainefan, Jul 25, 2022.
  1. Nov 6, 2022 at 5:35 AM
    #4301
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    so if it wasn't ugly would it not be a POS?
  2. Nov 6, 2022 at 5:53 AM
    #4302
    Cpl. Punishment
    Cpl. Punishment Young men never die.
    Neil
    Alberta, Canada
    2020 MGM Tundra SR5
    I heard a story about that a while back. Can't remember all the details but one of the challenges for most brands is having to be compatible with every manufacturers' vehicles.
  3. Nov 6, 2022 at 6:00 AM
    #4303
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    People have asked me about EVs. I don't know why, maybe I have expressed my opion on them. They ask if the chargers, and charging cables are universal. I tell them, far as I know every manufacturer is different. They all agree that is dumb.
    The industry should have agreed to all use the same type of charger. Instead time and money will be wasted drafting legislation to solve the problem of non standard EV charging hardware.
  4. Nov 6, 2022 at 6:11 AM
    #4304
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Everyone in the US with the exception of Tesla and the Nissan Leaf use a CCS/SAE plug.
  5. Nov 6, 2022 at 6:14 AM
    #4305
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    They include one if you want one. Probably decided on that as a weight savings and cost cutting measure for those who won’t actually take the truck off-road ever. It might be marketed as off-road ready but much like the Tacoma most of the Rivians will just go back and forth to work and the grocery store and never see dirt.
  6. Nov 6, 2022 at 6:18 AM
    #4306
    stevesnj
    But that doesn't work with their narrative. How dare you! :p
    dumontrider likes this.
  7. Nov 6, 2022 at 6:20 AM
    #4307
    batacoma
    batacoma Truck Wars
    Thanks for that information.
    Tesla is the dominant EV brand in the US, and everyone else uses CCS/SAE. Great two choices. Can't even own a Tesla, and an EV pick up Rivian or Ford and use the same charger for both vehicles.
  8. Nov 6, 2022 at 6:31 AM
    #4308
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    I got a flat in my Tacoma a year or so ago on my way to work. It was a sawzall blade in the sidewall. How the hell does that happen?
  9. Nov 6, 2022 at 6:44 AM
    #4309
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Important to note you can charge a tesla on any ccs charger with an adapter.
    stevesnj likes this.
  10. Nov 6, 2022 at 6:44 AM
    #4310
    Cpl. Punishment
    Neil
    Alberta, Canada
    2020 MGM Tundra SR5
    Is the adapter included with the car?
  11. Nov 6, 2022 at 6:45 AM
    #4311
    maxmk8
    No
  12. Nov 6, 2022 at 6:46 AM
    #4312
    Cpl. Punishment
    Neil
    Alberta, Canada
    2020 MGM Tundra SR5
    :spending:
  13. Nov 6, 2022 at 6:47 AM
    #4313
    Turd Ferguson
    Taxachusetts
    It seems most of these charging problems aren’t due the plug/adapter it’s the charger being broken or not providing enough power. Plus you don’t know this until you have already driven to the charger and wasted time and range.
    Cpl. Punishment likes this.
  14. Nov 6, 2022 at 7:02 AM
    #4314
    batacoma
    batacoma Truck Wars
    Tesla is the chosen EV for a reason.
    Is just the Tesla superchargers that have the Tesla only outlet?
    Presumably the Tesla outlet is also the one used for charging the Tesla at home.
    Does CSS charge at a slower rate than the Tesla charger at home.
    I still think a simple onesize fits all approach would simplify the charging process, and that should be the best option that is available.
    I have never seen an ice that you could pump gas into the tank no matter what variable there was between vehicle brand and gas station.
    Edit
    You still need the adapter to charge the Tesla?
    Tesla should have a 2nd CCS outlet on the car cmon Elon.
    Tesla chargers should work on the other brand. I presume Tesla chargers are better, provide faster charge times, and have a wider network of charging stations.
  15. Nov 6, 2022 at 7:06 AM
    #4315
    maxmk8
    Plugs have no bearing on charging speeds. Charging at home is just about 5-7kwh depending on your electrical system.
    Charging at public chargers is dictated by both your car and the maximum output of a charger… for example the highest possible ccs output is 350kw which is insane …. That’s like running 70 home ac units at once. Most cars top out at 150 or so… teslas take about 200-250kw… which is the fastest in the biz
    batacoma[QUOTED] likes this.
  16. Nov 6, 2022 at 7:10 AM
    #4316
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    One of the problems I’ve seen is the direct result of people being sloppy and careless. The plugs are heavy duty plastic but people manage to drop and break them. Self induced problems unrelated to the charging infrastructure.
  17. Nov 6, 2022 at 7:11 AM
    #4317
    batacoma
    batacoma Truck Wars
    Where is all of that electricity going to come from?
  18. Nov 6, 2022 at 7:13 AM
    #4318
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    The same place it comes from right now.
  19. Nov 6, 2022 at 7:14 AM
    #4319
    maxmk8
    Not sure I understand your question.
  20. Nov 6, 2022 at 7:16 AM
    #4320
    batacoma
    batacoma Truck Wars
    Gas station construction companies can build a new gas station. From the tanks up to the canopy in 30 days or less.
    SH10151 likes this.
