Tacoma Vulnerable Electronics During H2O Crossing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrbadwrench, Dec 27, 2011.
  1. Dec 27, 2011 at 2:34 PM
    mrbadwrench
    mrbadwrench [OP] Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    Hoping someone here has any insight.
    1) I'm aware there are several electronic components in the Tacoma which are "essential" to keep the vehicle operational, and could be compromised in an extremely deep water crossing. Does anyone know specifically which components, and their location on the vehicle?
    2) Would you considered bulb/electrical plug grease to be a sufficient water sealer for the plugs and electrical connections throughout the vehicle (notably those at the cab floor level)?
    Kind regards
  2. Dec 27, 2011 at 2:43 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    dielectric grease every single plug you can reach and and silicon the living shit out of your fuse box basically grease and silicon to seal also i painted every single plug i could reach in the engine bay with a few coats of liquid electrical tape its not permanent and can easily be removed if the need arises it also doesn't degrade also a few coats of the tape ensures a fairly decent barrier against moisture.
    this is what i did but, i would be open to any other suggestions as well or any parts that should absolutely be weather proofed to avoid any problems.
    thanks and great idea for a thread op :)
  3. Dec 27, 2011 at 2:43 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    on these trucks it seems to be the alternator(drivers side) which is located on top the a/c compresser
  4. Dec 27, 2011 at 2:49 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    this is going to be on my list of things to do.
    a high dollar alternator swap and an aux fuse panel and breaker system to handle some of the electronic things i have bolted on the truck in the last year.
  5. Dec 27, 2011 at 4:18 PM
    Large
    Large Red
    Use a snorkel.
  6. Dec 27, 2011 at 4:21 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    dont go in deep puddles that is all
  7. Dec 27, 2011 at 8:01 PM
    mrbadwrench
    Cleveland Ohio area
    So the alternator, fuse box, and plugs for vital engine wires are the only weaknesses?
    And technically, you can continue to drive without the alternator for some time. So it's really not an "essential" component.
