Tacoma will not idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tbauer332, Oct 30, 2024.
  1. Oct 30, 2024 at 1:13 PM
    Tbauer332
    Tbauer332 [OP] New Member
    Thomas
    2001 Tacoma xtended cab base 2.7 Manual Transmission
    2001 tacoma 2.7 liter 4wd manual trans. I recently bought this truck from a friend, it originally had an idle issue, idling as high as 2,500 rpm he had the throttle body replaced which seemed to mostly fix the issue, idling at about 950-1000 after. However it will not start now without pushing on the gas peddle. It does not idle at all you need to continuously press on the peddle to keep it going shows no sign of trying to idle if you release rpm’s go straight to zero. I’d appreciate any ideas on what it could be, the iac was not replaced with the throttle body so that was my first thought or a vacuum leak but all the hoses look fine.
    FixMyTaco likes this.
  2. Oct 30, 2024 at 1:15 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW...
  3. Oct 30, 2024 at 1:48 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Pretty much any original rubber component on a 23 year old truck is due for replacement, vacuum hoses included.
    Get yourself some EFI safe cleaner or propane and spray/release it around the various hoses and see if the idle goes up. The brake booster can fail as well, resulting in an internal vacuum leak that's hard to detect.
    Have you done any other diagnostic, or just been focused on the idle? Changed out the fuel filter, etc?
    JustADriver and THatt like this.
  4. Oct 30, 2024 at 3:04 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    What Andy said and you can also use water to check for vac leaks, misting lightly around hoses etc to see if rpm retards. But you will prob need someone to hold the throttle open at a consistent level since you said it won’t idle. IAC is a definite culprit but even if its stuck fully closed you should idle fine when the engine is up to op temp, with no other demands on like AC on etc. It’s worth the effort to chase it as those engines run great when all is in working order. Good luck to you.
  5. Oct 31, 2024 at 9:46 AM
    Tbauer332
    Thomas
    Thanks guys, I’ve got a fuel filter I’m replacing today, and I’ll check for vacuum leaks with some EFI safe cleaner. The hard part is just getting someone to hold the throttle in while I do it!
