Tacoma won't go into gear without pressing shift release
Discussion in '1st Gen. Tacomas (1995-2004)' started by mjbuffa28, Mar 21, 2017.
  1. Mar 21, 2017 at 6:25 PM
    mjbuffa28
    mjbuffa28 [OP] Member
    mike
    2004 toyota tacoma 4wheel drive extended cab v6 prerunner
    My 2004 tacoma won't go into gear without pressing the shift release. It's not the break fuse. I've already changed it. Any ideas?
  2. Mar 21, 2017 at 6:42 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    The break release?
  3. Mar 21, 2017 at 7:10 PM
    mjbuffa28
    mike
    Sorry, typo!! Shift release
  4. Mar 22, 2017 at 5:40 PM
    wht95scort
    wht95scort Well-Known Member
    NJ
    2001 3.4 gas guzzler
    IMG_3656.jpg Could be a bad shift lock solenoid. You may be able to hear a slight click noise when in park and stepping on the brake pedal near the shifter. This is the solenoid activating. Here's a diagram. Check the cig fuse as well as the stop.
  5. Mar 22, 2017 at 5:47 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Possible bad brake light switch.
  6. Mar 22, 2017 at 5:53 PM
    mjbuffa28
    mike
    If that's the case then do I have to get into the transmission box to change the bad solenoid? The cig lighter works fine but what is the stop?
  7. Mar 22, 2017 at 5:54 PM
    mjbuffa28
    mike
    And where is that located?
  8. Mar 22, 2017 at 5:55 PM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    Right behind the brake pedal.
    mjbuffa28[QUOTED][OP] likes this.
  9. Mar 22, 2017 at 6:00 PM
    mjbuffa28
    mike
    Awesome thanks y'all! I'll take a look and see what I can do
  10. Mar 22, 2017 at 8:43 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    yall are way over thinking this, the 10 amp brake light fuse in the dash fuse panel is just blown. when that happens the shift lock will not release because the signal isn't there to go through the brake switch to disengage the shift lock.
    its a designed safety device in order to prevent you from unknowingly driving the truck without any brake lights
    replace fuse and all will be good, if it blows again check for a shorted trailer light converter or the brake light wire or one of the brake lights bulb socket is shorting out to ground.
    gearcruncher likes this.
  11. Mar 26, 2017 at 9:51 AM
    mjbuffa28
    mike
    I changed the break light fuse which oddly enough fixed my dash lights.....
    DustStorm4x4 likes this.
