Tacoma won't rev up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bowtech4, Jul 3, 2022.
  1. Jul 3, 2022 at 4:51 PM
    Bowtech4
    Bowtech4 [OP] New Member
    2012 Tacoma 2008 forrunner
    I have 2012 Tacoma great condition 105347 miles garage kept. I got home from work after being gone for 3 weeks. Tried to start it battery seemed dead. Replaced the 140 amp fuse with a 120 cause could find a 140 not trucks but will not go above 1500 rpm and check engine light is on and trac off light is on and radio not working any suggestions
  2. Jul 3, 2022 at 5:46 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Was the main fuse blown?, if so any idea what blew it?
    What code(s) do you have?
  3. Jul 3, 2022 at 6:12 PM
    Waasheem
    Waasheem
    2007 xrunner
    You need to elaborate what happened between these sentences. Jump started? Connected jumper cables incorrectly? Positive jumper cable touched something before connecting to the battery?
    wilcam47 likes this.
  4. Jul 3, 2022 at 6:13 PM
    Bishop84
    Bishop84 Well-Known Member
    Backwards boosted, you need to replace more fuses.
    b_r_o likes this.
  5. Jul 3, 2022 at 6:34 PM
    Bowtech4
    Everything was connected correctly unless my son did something. I've got it back to normal except radio still won't turn on. I've checked all fuses with voltmeter.
  6. Jul 3, 2022 at 6:38 PM
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    What did you do to fix it? Don't leave us hanging.
  7. Jul 3, 2022 at 6:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    :popcorn:
    wilcam47 and nd4spdbh like this.
  8. Jul 4, 2022 at 6:24 AM
    Bowtech4
    I had some other stuff come up. Sorry about the wait. I un hooked battery for third time to let everything reset. After replacing main fuse. (The 140) and now seems to be good. Only issue I have now is the radio will not turn on. So when I get a chance I'll try and see if there's a fuse I missed. This is first issue I have had with it.
    Otterstuff likes this.
  9. Jul 4, 2022 at 6:31 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Fuses, especially the main 120 amp fuse don’t just blow for no reason. He likely put the cables on reversed or arced it in someway.
    wilcam47 and Otterstuff like this.
  10. Jul 4, 2022 at 11:30 AM
    Waasheem
    Waasheem
    2007 xrunner
    I suggest to not be too hard on the kid, if you suspect he made the mistake mentioned. At some point, we were all young and hadn’t learned yet. I did it a few years ago, because someone put the green and red felt pads on reversed, threw me off.
