Tacoma won't start...help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vacin97, Mar 5, 2016.
  1. Mar 5, 2016 at 10:37 AM
    vacin97
    vacin97 [OP] New Member
    Kyle
    2008 black Tacoma 4x4 4cl
    guys i have a 08 tacoma wont start ive replaced the clutch, starter and now just did the spark plugs. it turns like it is going to start but wont start, any ideas.
  2. Mar 5, 2016 at 10:39 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Alternator? Battery? Battery terminals?
  3. Mar 5, 2016 at 10:39 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    when did it stop starting? did you do all that work at once?
  4. Mar 5, 2016 at 10:40 AM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    have you done plugs before? plugs done wrong would absolutely cause that problem.
    DustStorm4x4 likes this.
  5. Mar 5, 2016 at 10:43 AM
    vacin97
    Kyle
    buddy of mine said it might be the alternator but im thinking he is wrong and no never really done plugs but its still doing the same thing it was doing before i changed the plugs.
  6. Mar 5, 2016 at 10:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    Run ok prior to clutch work?
    Clutch interlock switch messed up
    Why did you swap the starter?
    Starter not properly installed?
    Out of gas
    dead fuel pump or fuel pump relay
  7. Mar 5, 2016 at 10:46 AM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    so it wasn't starting before plugs either?
    bad alternator means the engine doesn't charge the battery. click click click no start. boost. runs for a bit and dies. your buddy sounds like my sister... "might be the alternator" (only vehicle part I think she can name)
    Could even be bad gas. Hard to say without knowing more.
    paint a better picture of what has happened and in what order and I bet you get it sorted out here.
  8. Mar 5, 2016 at 10:47 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    :rofl: Me :bananadead:
  9. Mar 5, 2016 at 10:52 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Knowing at which point the truck would not start - before, during, after, etc. each of the 'fixes' you did is needed to help pinpoint why it might not be starting.
  10. Mar 5, 2016 at 10:52 AM
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    crank and no fire is either spark or fuel. One or the other . Sometimes no spark because the engine is not sensing rotation.
  11. Mar 5, 2016 at 10:58 AM
    zonian
    zonian Well-Known Member
    Paul
    Knee Deep in the Hoopla.
    2012 TRD Sport 4X4 - Pyrite Mica
    Raptor 4" Black Oval Nerf Bars, Hard-Wired Uniden RD9XL Radar Detector, Anytime Fog Light Mod, 12V Power outlet in Bed, Tailgate Anti-theft Mod, Distinct Offroad lightbar, 2 Hella Micro FF Driving Lights, 2 Hella Micro FF Fog Lights, Rear Slider Window Opener
    Starter Fluid sprayed into the air intake will determine which.
  12. Mar 5, 2016 at 11:33 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Why would you suspect the clutch? That seems......................interesting.
