Tacoma won't start
Discussion in '1st Gen. Tacomas (1995-2004)' started by BlueGrouse, Mar 6, 2016.
  1. Mar 6, 2016 at 6:33 AM
    BlueGrouse
    BlueGrouse [OP] Active Member
    1999 3.4 4x4 tacoma
    Went to start my truck yesterday and couldn't.
    I'm pretty sure the battery is good. Lights come on, get a 12.6 voltage reading on it.
    However the radio doesn't come on and the clutch start cancel button (which I've had to use for a few years) won't engage. Turn the key and nothing happens.
    Any suggestions? Thanks
  2. Mar 6, 2016 at 6:35 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    is it cold where you are> 12.6 isnt all that great of a reading. starter relay gone bad?
  3. Mar 6, 2016 at 6:45 AM
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    - Will your winshield wipers turn on?
    - Honk your horn and hold it down for a bit. Does the sound start to get quieter?
    If your answer is Yes to both of those then I'd say it's the battery. Especially since the radio won't even turn on.
    You can also check all the sides of the battery. If any of them are not flat and are slightly bulging out then you have a blown cell in your battery.
  4. Mar 6, 2016 at 6:52 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How did you get the 12.6 reading? You need to take a reading with a load on the battery. Turn on the lights then check you multi meter reading. I bet its a lot less than 12.6v.
  5. Mar 6, 2016 at 7:04 AM
    BlueGrouse
    1999 3.4 4x4 tacoma
    Thanks checking all that now
  6. Mar 6, 2016 at 7:09 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    My guess...
    Bad battery:annoyed:
    I could be wrong. It's happened a couple times:rolleyes:
  7. Mar 6, 2016 at 7:14 AM
    BlueGrouse
    1999 3.4 4x4 tacoma
    Whoa dang, voltage goes down to 11.9 with lights on. It's a nice interstate battery that's supposed to last 6 years and it's only three years old. I'll go get a new battery.
    Is it wierd it just up and quit?
  8. Mar 6, 2016 at 7:18 AM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    No, a 6 year battery sometimes lasts 3 years. Where do you live? If it's the hot desert 3 years is pretty decent.
  9. Mar 6, 2016 at 7:22 AM
    robssol
    Rob
    S. Wisconsin
    They do that nowadays, no warning!
    Might have something to do with all the electronics in cars now. Power vampires and microdraws when the car is shut down.
  10. Mar 6, 2016 at 7:33 AM
    BlueGrouse
    1999 3.4 4x4 tacoma
    I'm in gunnison Colorado. So, generally real cold, unseasonably warm now but still cold compared to most places. Probably 30 f now. Which is warm. So does interstate have a 6 year warranty usually or should I just go get a oreilly battery as oreilly is the only place open on Sunday's or try and warratee the interstate tomorrow?
  11. Mar 6, 2016 at 7:35 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Red Stick, Louisiana
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I'd get interstate to warranty the battery.
    What's voltage when you try cranking?
  12. Mar 6, 2016 at 7:36 AM
    koditten
    Kirk
    Central Michigan
    Tough call. I'm a fan of Interstate as well. The lack of dealers open on a Sunday makes it less attractive. I like the Walmart batteries for just this reason. Open all the time and they are very good about warren tee on the batteries. The batteries are pretty good too.
  13. Mar 6, 2016 at 7:42 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug
    Stonewall is the fattest 5 lug slug ever
    Definitely sounds like the battery. :( Unfortunately, you can't trust what they say about battery life any more- gone are the days where a battery might last you eight to ten years.
    If you can wait, and don't have a pressing need to get the truck back on the road today, I would definitely try to check into that warranty on the interstate battery when your local supplier is open.
  14. Mar 6, 2016 at 7:48 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Did you try pushing in the clutch and starting, Maybe the cancel switch took crap
  15. Mar 6, 2016 at 8:00 AM
    BlueGrouse
    1999 3.4 4x4 tacoma
    Put the battery from the wife's tundra in and nothing. That battery read 11.5 on the voltage when in the Tacoma. If it's not the battery what could it be?
  16. Mar 6, 2016 at 8:03 AM
    sawed off
    Randy
    Idaho
    Check all your fuses, I have automatic but theres got to be one for starting
  17. Mar 6, 2016 at 8:10 AM
    BlueGrouse
    1999 3.4 4x4 tacoma
    Now the tundra battery is reading low and the tundra which was running great starts and died. Oh no...
  18. Mar 6, 2016 at 8:13 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    A battery for a vehicle should read anywhere between 13.7 and 14.2
    Fenwick1993 likes this.
  19. Mar 6, 2016 at 8:15 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Starts and then dies with a different battery? Something electrical is what it sounds like now... Maybe the alternator...
  20. Mar 6, 2016 at 8:19 AM
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug
    That sounds like the alternator, then... Both batteries may very well be okay- you'll want to hook them to a charger, of course, and hopefully they will be fine.
    The Hunter likes this.
