Tacoma Work Edition?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by megamole, Sep 1, 2011.
  1. Sep 2, 2011 at 5:42 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Cut 2x6's to fit in the notches in the bed so you can fit full sheets of plywood or drywall in the bed on top of the wheel wells.
    OP, rather than try to make the Tacoma something it's not, buy a full size. They already do everything you've listed.
  2. Sep 2, 2011 at 7:35 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Hilux would be nice. I agree with OP current setup is too weak and not everybody want fullsize. Small truck the can carry a lot is better deal for most people.
    Only way to get that with our truck is to toss axles and suspension from Tundra in that thing and box the frame as much as possible
  3. Sep 2, 2011 at 7:41 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I've got that set up right now in my truck.
    They weren't stupid when they made the Tacoma. Just drunk when they designed the disposable wheel bearings and fucked from factory Front Diff Bearing.
  4. Sep 2, 2011 at 7:43 AM
    Pugga
    Massachusetts
    Even then, you're still not legally able to haul any more than a stock Tacoma...
    I don't get why people buy a small or mid-sized truck then complain because it doesn't have the capabilities of a full sized. If you need a heavy hauler, get something that's built for it. It's not Toyota's fault you bought the wrong truck. No small or mid sized truck has ever been able to fit full sheets of plywood or drywall between the wheel wells. Mid sized trucks have grown up a lot in the last 10 years and that's why they're dying out. They've encroached on full size territory both in capacity and price. Your better off buying a stripped down full size work truck if that's what you need. They're not that much bigger than the Tacoma.
  5. Sep 2, 2011 at 7:49 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    /closed thread
  6. Sep 2, 2011 at 9:40 AM
    Pugga
    Massachusetts
    Why? I haul plywood and drywall laying flat all the time... throw a strap around the back edge so it can't slide backwards and you're good to go. I lay them flat because when hauling drywall I don't want that much of it upsupported hanging off the tailgate and the tailgate can dent the drywall also. I know you can put a piece of plywood under them but why haul extra materials when you don't have to?
  7. Sep 2, 2011 at 10:02 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I just replaced my stock crap suspension with the OME one , all good now .
  8. Sep 2, 2011 at 10:32 AM
    joes06tacoma
    Joe
    Central Coast, CA
    What springs do you have in the back? Our stock 5lug regular cabs at work sag like crazy with a similar shell and tools in them.
  9. Sep 2, 2011 at 4:35 PM
    baja820
    baja820 Well-Known Member
    pacific northwest mountains
    '11 SR5 Tacoma V6 6MT 4x4
    Bone stock.
  10. Sep 2, 2011 at 4:37 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Our local LOWES has a work outfitted Tundra on display right outside the contractors entrance. Too bad it is there from a DB dealership.
  11. Sep 2, 2011 at 4:44 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    also, the op stated putting the plywood flat between the wheel wells. you would need to widen the truck to do that. a wider more proportional truck would be a tundra as well..
  12. Sep 2, 2011 at 6:26 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    On the 2nd gen Tacomas if you put a 2X6 in the side bed indents across the bed you can lay a sheet of plywood flat in the truck. It will be above the wheel wells. I do it all the time.
  13. Sep 2, 2011 at 8:50 PM
    OZ-T
    Peter North
    British Columbia
  14. Sep 6, 2011 at 9:55 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Mmm...cedar.
  15. Sep 6, 2011 at 9:58 AM
    #35
    OZ-T
    Peter North
    British Columbia
    Old growth Douglas Fir
  16. Sep 7, 2011 at 8:12 AM
    #36
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Quiet heathen!
