Tacoma work truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lightsped, Aug 2, 2014.
  1. Aug 2, 2014 at 9:39 PM
    Lightsped
    Lightsped [OP] Well-Known Member
    David
    Acworth/Kennesaw, Georgia
    Basic 2wd RC 5 speed
    I am considering buying a 09 2wd regular cab. Just a base model 4 cylinder - manual tranny. White with the black bumpers and grille, roll up windows, etc...
    I am wanting to get something to drive back and forth to work, and something I don't have to put premium gas in.
    I don't see much discussed here about the base 2wd regular cab models. Are these reliable? Anything I should look for? This particular one I am looking at has 68k miles.
  2. Aug 2, 2014 at 9:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Great truck you will love it. Everyone in here is going to try and talk you into a V6 4X4. Ignore them and get what you need / want. The 2.7 I4 engine is bullet proof and is more than what I need on a daily basis. Any specific reason you are going manual trans? I really like the 4 speed automatic, It also has a level dipstick for the transmission fluid level.
  3. Aug 2, 2014 at 10:03 PM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    Go for it alot of us have 4wd but there are alot of 2wd people on here also get what serves your needs ..
  4. Aug 2, 2014 at 10:41 PM
    smithr1730
    smithr1730 Well-Known Member
    Rob
    Columbus, Ohio
    '15 TX Pro
    Offroad parts and such
    I have always said go for wht your needs are. Who care wht everyone else thinks. The 4 cylinder is a great truck!
  5. Aug 2, 2014 at 11:49 PM
    Lightsped
    David
    Thanks for feedback.
    Main reason I am going for the base 2wd 4 cylinder is for gas mileage, reliablity, and no way to haul anything now. I have three other vehicles that all take premium gas and that I am trying to keep the mileage down on (S2000, Evo, and Civic Si).
    When I was growing up my dad bought a new 1985 2wd SR5 5 speed "xtra cab" with the then new EFI motor. That thing never gave us any problems. I was hoping a repeat performance from this 09 base model I am looking at.
  6. Aug 2, 2014 at 11:50 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    If you even might need 4x4 it is great to have but if there is no chance you will ever need it then what you are suggesting should be fine.
  7. Aug 3, 2014 at 12:25 AM
    SWOreBowHunter
    SWOreBowHunter Well-Known Member
    Oregon
    '14 AC 4x4
    Front: 5100s and 884x Rear: Dakars and OME Nitrochargers
    2wd will be just fine. Keep a set of chains in it if it snows where you live/travel.
  8. Aug 3, 2014 at 5:56 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    2WD regular cab with I4 as a daily driver is a great choice ... I had an '06 and the only reason I moved up was the need for more interior storage ... the AT got me about 23 mpg around town ... HIGH 20's on the highway ... if i recall correctly the AT got better mileage (rear end ratio) than the manual ...you may want to consider that ... good luck and let us know.
  9. Aug 3, 2014 at 6:03 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Is it reliable? It is a Toyota! Case closed!:thumbsup:
    Welcome to TW!:wave:
  10. Aug 3, 2014 at 6:10 AM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    My father used to work for the ny state DOT. Over 2 decades he had 2 base 2wd stick shift 4cyl toyota trucks that he drove all over the place... On the roads for work, back and forth from ny to penna, (where he lived part time)... Each of those trucks went 200k+ with literally little more than oil changes every 3000 miles or so and new tires as needed. He ran snows in the winter, of course. I honestly done even know if he ever replaced the brakes in those trucks... It was A LOT of highway miles.
    So yea, you'll be fine. Those trucks are amazing.
  11. Aug 3, 2014 at 6:16 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    That is the perfect little truck for trips to work.
