Tacoma World for Foresters?
Discussion in 'Off-Topic Discussion' started by sullivan4987, Jul 4, 2016.
  1. Jul 4, 2016 at 1:36 PM
    sullivan4987
    sullivan4987 [OP] Well-Known Member
    Boulder
    09 Tacoma TRD OFF ROAD v6 4x4 access cab
    OME 3.5 inch Heavy Duty lift, BFG T/A 285 75 16, on board ARB compressor, ARB bumper with fogs and drive lights, custom on board switches, Line X flares, grill, rear bumper, body frame cat back exhaust
    Anyone know of a radical forum for the subraru forester?
  2. Jul 6, 2016 at 4:04 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    A friend of mine swears by hers and I'm considering a Forester to replace my wife's SUV. I'm not sure if there is a Forester version of TW, good luck with your search.
  3. Jul 6, 2016 at 4:10 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  4. Jul 6, 2016 at 4:18 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Our "Family" vehicle is a Forester. Great little car, tons of room, got the 6spd manual instead of the CVT, AWESOME AWD.
    Still...doesn't put a smile on my face like driving my taco does.....
    1Shifter likes this.
  5. Jul 6, 2016 at 4:24 PM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    I agree with what @KenLyns said, tons of info there that I'll go to for our 09 xt
  6. Jul 6, 2016 at 4:48 PM
    KenLyns
    Belly of the Beast
    If you are in the market for a used Forester, avoid 2011 models with the naturally-aspirated engine. It was the debut year for the FB25 engine, and roughly one in ten burns more than a quart of oil between oil changes.
  7. Jul 11, 2016 at 3:46 PM
    rvrats2
    rvrats2 Member
    Tim
    Carbondale, CO
    2011 Tundra SR5. Will again have a Tacoma...love em.
    5100's
    True story! We're going through that issue right now. It didn't consume enough oil during the "consumption test". The engine throws cyl 3/4 misfire codes if you get too close to redline (we live in the mountains, sometimes you gotta pass, on a pass...yaknow) Trying to work with corporate as the Subaru stealership is just that. Lied to her about brake pad thickness when she had tires mounted...grrr :evil::facepalm: I like my Toyota Dealer for the things I don't do myself...:notsure: we went and drove the new Rav4's. I like those a lot better than the Subaru.
    as far as forester forums...I was pretty unimpressed when I was researching subaru issues...
  8. Jul 11, 2016 at 10:18 PM
    Pigpen
    Dan
    Northwest Montana
    I work in forestry and hoped this was going a different direction...:pout:
