Tacoma world
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Harley SG, Feb 12, 2018.
  1. Feb 12, 2018 at 5:34 PM
    Harley SG
    Harley SG [OP] Member
    Dan
    2015 4wd double white Tacoma
    Lift, tires, winch, lights, flares ect.,
    Thanks for the welcomes and no do the tires (no they dont) rub! Lol
    BlueFalconActual likes this.
  2. Feb 12, 2018 at 5:36 PM
    Tigerian
    Tigerian Well-Known Member
    Iowa, unfortunately
    2024 GR Corolla
    If they don't rub you clearly don't have big enough tires. o_O
    Boyk1182 and DrFunker like this.
  3. Feb 12, 2018 at 7:34 PM
    Pigpen
    Dan
    Northwest Montana
    ^^this^^
  4. Feb 17, 2018 at 9:49 AM
    Harley SG
    Dan
    thanks for the welcome!
  5. Feb 17, 2018 at 9:52 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    First rule of tire buying
    Boyk1182 likes this.
