TacomaBeast Headlight Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RickC239, Jul 5, 2019.
  1. Jul 5, 2019 at 10:51 PM
    RickC239
    RickC239 [OP] New Member
    2008 Blue Tacoma DCLB
    Hey everyone! I am new here and just got done installing my new TacomaBeast
    05-11 TOYOTA TACOMA PROJECTOR HEADLIGHTS LIGHT BAR DRL headlights.
    The instructions say simple plug and play, but once I connected the Low beam headlights, the right side headlight made a burn out sound and now doesn't work, so i believe the bulb inside must have burnt out?
    The second issue is getting the DRL Light bar to turn on, I connected everything just like you are suppose to, but the Light Bar does not turn on.
    Has anyone else had an issue with the Tacombeast Headlights like this? very frustrating when it's suppose to be a simple plug and go.
    Should I replace the low beam bulb?
  2. Jul 6, 2019 at 6:01 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Do you have pics of the install? It should be fairly straight forward unless you received a faulty unit. Check the fuses under the hood regarding the low beam issues, likely burnt during the install. You can also check the led by hooking 12v to it but I would suggest checking voltage at the factory plug to confirm you have power at both headlight and parking light connectors with light switch on. The small plug on the Tacoma beast HL with the green / black wire powers the LED and it plugs into the factory connector where the oem amber bulb was.
