Tacomas Are GREAT Trucks!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kevin Jones, Dec 24, 2022.
  1. Dec 24, 2022 at 1:30 PM
    #41
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    drove my truck for the first time in sub-zero temperatures. felt a bit rough until it warmed up but still going strong. started right up.
    I've never had a Toyota battery fail.
    snickers[QUOTED] likes this.
  2. Dec 24, 2022 at 1:31 PM
    #42
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    My ‘21 with 8k miles started up right away in my garage, 56 degrees. That is one tough truck. :cookiemonster:
  3. Dec 24, 2022 at 1:39 PM
    #43
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    I think you pissing off the ones that bought into them fancy white cap batteries. Or was it pink? Who remembers?
  4. Dec 24, 2022 at 1:53 PM
    #44
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    are optimas worth the extra money?
  5. Dec 24, 2022 at 2:11 PM
    #45
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    while technically true, the wind chill factor certainly does matter if your truck does not start and you are standing on the side of a logging road
    waiting for your jump. merry christmas to all.
    speaking of cold starts: i was in VT in the 70's and had to drive to MA at 4am. temp was -35F and my little BMW 2002 started. would have been better if it had not. got on the highway and temp gauge indicated overheated. Semis had wind shields over their radiators. I did not. radiator was frozen and not thawing. i knew what was going on but could not stop in that temp (before cell phones). i finally pulled into gas station and SLOWLY poured water over it. radiator thawed and i was able to continue with some cardboard in front of radiator. the engine had overheated due to frozen radiator but fortunately radiator never burst. Engine never the same since. Probably warped head. Never chased it. moral: dose antifreeze for colder than you'd ever expect to need.
  6. Dec 24, 2022 at 3:01 PM
    #46
    Grimble27
    Grimble27 Well-Known Member
    Washington
    '23 White Tacoma TRD OR
    We had sub zero temps hit our area the morning after I got home from the dealership with my new Tacoma. I’m still in that ‘afraid to mess it up’ phase so it just say in my warm garage all week. Finally took it out in the snow last night and it was just fantastic. Absolutely love this truck.
  7. Dec 24, 2022 at 3:04 PM
    #47
    Cribb
    Cribb Once it hits your lips, it’s so good.
    South Carolina
    1996 Tacoma 2.7 XtraCab 4x4 5spd
    2” suspension lift, 2” body lift, 33” tires, K&N intake, LCE header, Alpine head unit, Kicker KS door and pillar speakers, 10” Rockville slim powered subwoofer, red/clear taillights, clear corners, clear turn signals, LED headlights, LED tag bulbs, LED reverse bulbs, LED dome lamp, Husky floor liners
    My 96 2.7 fired right up today with 241K on the clock and no clue how old the battery is. Absolute bullet proof. Love my 1st gen. Was a longtime Jeep guy and these trucks are indeed GREAT!
  8. Dec 24, 2022 at 3:05 PM
    #48
    Cribb
    South Carolina
    And it was -9 with wind chill here this morning.
  9. Dec 24, 2022 at 4:08 PM
    #49
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I'm on year 5 on my battery. I live for danger......
  10. Dec 24, 2022 at 4:57 PM
    #50
    Kevin Jones
    Kevin Jones [OP] Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Not in my opinion and experience considering the higher cost and especially with the quality issues as of late.
    Side note:
    Also, as I stated earlier there's only about seven or eight manufacturers who make most all batteries, however that doesn't mean that they make all batteries the same and just stick different brand stickers on them as they come off the line.
    Batteries are manufactured to the individual's seller/retailer's specification. For example even though the same battery manufacturer may be making both Delco and DieHard batteries, they are not made the same, or even have the same appearance.
    22Coma6MT and auskip07[QUOTED] like this.
  11. Dec 24, 2022 at 5:01 PM
    #51
    auskip07
    Skip
    Atlanta, Ga
    i usually go for walmart everstart max because i can get a pro rated 5 year warranty. Should i look at a better quality battery in your opinion or keep buying those for the warranty?
  12. Dec 24, 2022 at 5:19 PM
    #52
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    sorry if i missed but how often did/do you change the oil in the '96?
  13. Dec 24, 2022 at 5:25 PM
    #53
    Kevin Jones
    Kevin
    Va
    Changed every 5,000 miles since new using Pennzoil 5w-30 non-synthetic oil and a Fram oil filter.
  14. Dec 24, 2022 at 5:31 PM
    #54
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    My 2011 started fine after sitting outside at -40° for two days without being plugged in. Sounded like it was going to eat itself at idle but it still started.
  15. Dec 24, 2022 at 5:55 PM
    #55
    Kevin Jones
    Kevin
    Va
    I don't put much stock in battery warrantee duration in regard to battery quality or how long they will last. I concentrate more on a battery's cold cranking amps, reserve capacity and amp hour ratings. For example, I'm a Corvette enthusiasts (have owned 42 or them) and they are hard on batteries, however even though the below Delco (very high quality batteries) has a 42 month warranty, it will typically last 6-7+ years in a late model Corvette. So IMO quality / CCA / RC / AH are king.
    937ebc78_8ba1_426f_9c62_ef9ae52aa5c5_7b51c52f1d2d4a8ad2ae2d35c2ff837f0149d30e.jpg IMG_0207 (2).jpg
  16. Dec 24, 2022 at 8:45 PM
    #56
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    No matter the battery, two summers and first time it gets cold the battery needs replacing where I live. No matter what vehicle it is in. I did put a lithium battery in my motorcycle this summer so I will report back on that in couple of years.
  17. Dec 24, 2022 at 8:59 PM
    #57
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I've had four Toyota trucks ranging from an 88 SR5, two 1st gen OR's and this third gen now. Never has any of them ever broken down or failed to start and take me where I had to go. They're simply amazing in that respect.
  18. Dec 24, 2022 at 9:56 PM
    #58
    Amorak
    Amorak Well-Known Member
    2021 Magnetic Gray Metallic Tacoma TRD OR DCSB Premium
    Nice condition. You sure can tell you didn't hand over your older tacoma to your teenage son (sports and hunting) all through high school as I did. ;)
    We sold it last year for a nice price back to the original dealer (height of crazy covid prices), 186,000 miles.
