Tacomas are not underpowered
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Masonluzzi1, Jun 3, 2023.
  1. Jun 9, 2023 at 7:22 AM
    #141
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've swapped my tires over to the Goodyear adventure with kevlar A/T ones that were suppose to be for my gen1 tundra, but I sold it. There has been some road noise depending on certain road surfaces, but usually it's normal like any other vehicle. Seem when these roads are wet its more common.
  2. Jun 9, 2023 at 7:27 AM
    #142
    Jemm63
    Jemm63 Well-Known Member
    Jeff
    2015 Barcelona Red Tacoma SR5 - 2WD
    Hood deflector, Raptor SS side bars, Fold-A-Cover Hard Cover, Husky X-Act Contour Floor Liners, Touren rims, BFG Radial TA 245/60R15 tires
    Obviously with a statement like that proves you don't know your ass from a hole in the ground !!!
  3. Jun 9, 2023 at 7:29 AM
    #143
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You guys need to switch to an electric truck 0 to 60 in 4 sec. I'm in the wrong group mine is a 4L manual.
  4. Jun 9, 2023 at 7:37 AM
    #144
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It's relative. When I traded my 02 F150 with the 4.6L V8 for my 07 Tacoma I only gave up 10 HP. I also gave up 1500 lbs of weight. Gearing was the same, but the Tacoma easily outperformed the Ford even with towing and was 3-4 mpg better on gas.
    On the other hand, my 2014 F150 with the newer 5.0 easily outperforms my 07 Tacoma in every way and gets the same fuel mileage.
    The problem with Tacoma is that the power is in the wrong place for a truck. Yes, they can be fast if running enough rpm's. But trucks used to tow and haul need that power at lower speeds. Even my 2nd gen gets it's power at 3600 rpm, 3rd gens at 4600. Old school trucks got it at 2500 rpm.
    Dirty Harry and faawrenchbndr like this.
  5. Jun 9, 2023 at 7:40 AM
    #145
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    If you think this truck is “underpowered and slow” for everyday driving then I’m not sure what to tell you.
    What’s the issue with torque? I live in 1.5-2.5k RPM range 90% of time. Im carrying ~650# of constant weight, 33s and lifted. Stock tune, my motor lived in same RPM range.
    What’s your struggles with torque? Please explain.
    BC Hunter and zoo truck like this.
  6. Jun 9, 2023 at 7:52 AM
    #146
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Exactly. Maybe some folks expect stump pulling power out of a v6? It has plenty of power for everyday driving. I barely go over 3k RPMs.
    Everytime I drive it, I try to find a scenario where the truck might be “underpowered and slow” but it just never happens.
    When I’m driving through mountain passes over payload, RTT sticking up and trying to maintain 80 or so uphill fighting a headwind yes, she will be turning 4-4.5k RPMs or so. But that’s completely normal and expected out of a N/A v6 engine.
    Tuned on 94E0, this truck is a little beast.
    zoo truck[QUOTED] likes this.
  7. Jun 9, 2023 at 7:58 AM
    #147
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    In my case yes, 100%. My tune eliminated “Atkinson BS cycle” and it feels like it added about 20-25% more torque down low.
    Premium SFOB on 94E0.
    33yrsoftoys and AusBerg like this.
  8. Jun 9, 2023 at 8:07 AM
    #148
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Has nothing to do with learning to drive. When you mash the pedal, there is simply nothing there unless you're in the high range of the rpm band. I can not possibly fathom how you live in the 1.5-2.5k rpm range.
  9. Jun 9, 2023 at 8:08 AM
    #149
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    So what RPM are you now at when your Taco kicks in most power. Mine kicks in about 2400 RPM which is normal going by what I hear in here.
  10. Jun 9, 2023 at 8:09 AM
    #150
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Ok. So if you mash the pedal at low RPMs on any v6 there will be very little response correct?
    I can take a video for you? My tach doesn’t go over 3k normal driving.
  11. Jun 9, 2023 at 8:10 AM
    #151
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    :deadhorse:
  12. Jun 9, 2023 at 8:13 AM
    #152
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Push it around the block while your wife steers. Then, drive it around the block. I think you will come to find that it has plenty of power.
    Vmax540 and petethemeat like this.
  13. Jun 9, 2023 at 8:13 AM
    #153
    BLtheP
    Plano, TX
    I mean, no engine likes to be lugged at low rpm, but other V6s (Frontier 4.0 for example) pulled out of it immediately and started to ramp up speed quick. The Tacoma just slowly lumbers on and on, bringing up speed slowly. That has not changed no matter what tune I've run, and it's better with gears but it's still there.
    My main problem is comparing this truck to others. It just has nothing compared to others I've driven.
  14. Jun 9, 2023 at 8:14 AM
    #154
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Most power is at 4.5k RPMs+. She flieeees:)
    But seriously ~2300 RPMs is when it starts to feel good.
  15. Jun 9, 2023 at 8:19 AM
    #155
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    So how does that hinder your normal everyday driving? Do you feel unsafe? Can’t merge in time? Have troubles going uphills? I really wanna understand this.:)
    When I’m aired down to 18 psi off-road, over payload and starting uphill in 1st in 2HI, she will struggle a bit. That’s not a problem with the engine though, my truck is heavy and on 33s.
    BC Hunter likes this.
  16. Jun 9, 2023 at 8:22 AM
    #156
    BLtheP
    Plano, TX
    Lol, no, none of that. It's just an annoyance of the truck that I feel every time I drive. Doesn't mean I dislike the truck or want something else, just something I wish was better.
    I don't like when I get slowed down to a crawl for a stop light or whatever else down around 5-10 mph, have to choose between 1st or 2nd, and if I choose 2nd, it literally bogs down for 5 or so seconds before it has finally picked up enough speed to not feel terrible.
    Taco Pirate and Junkhead[QUOTED] like this.
  17. Jun 9, 2023 at 8:22 AM
    #157
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Hook up a trailer and try to start from idle and pull up a hill or boat ramp. It has no low end and makes that a mess. 2LO mod makes it actually usable for low speed towing like that but the engine just doesn’t have the bottom end to be useful for a lot of truck tasks. Couple that with living at 6000’ and it’s simply not adequate in some cases. For normal daily driving it’s really not an issue and the truck does decently well but it’s nothing impressive.
  18. Jun 9, 2023 at 8:24 AM
    #158
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Vmax540 likes this.
  19. Jun 9, 2023 at 8:28 AM
    #159
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Umm any MT v6 truck will do that in 2HI. That’s why 4LOW exists, or better like you mentioned 2Wd low. I have it and used multiple times, lifesaver.
    So you expect a v6 MT truck to pull out a boat off idle in 2HI? :)
  20. Jun 9, 2023 at 8:31 AM
    #160
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yes the 5-10 mph is a bit annoying at times, I agree. 2nd should have been a bit lower.
