Tacoma's AUX Sound Problem
Discussion in 'Audio & Video' started by HawaiiTRD, May 26, 2015.
  1. May 26, 2015 at 6:35 PM
    HawaiiTRD
    HawaiiTRD [OP] "Some people feel the rain, others just get wet"
    Hawaii
    2022 MGM DCSB TRDOR
    Diamondback SE, FITCAMX
    I recently figured out why my sound and connection when playing music through the AUX was so bad. I have a 2010 and the AUX option was pretty much unusable for me. Sometime it wouldn't work at all, and the rest of the time it would be only playing through the passenger side. It turns out that the plug cover would lean down on the cable and cause the issues. I'm probably going to cut the cover off.
    Sorry if this has already been discussed, but I've had my truck for over 5 years and only now figured this out. I figured it was worth posting in case it helps any one else with this same issue.
  2. May 27, 2015 at 10:05 AM
    Aw9d
    Aw9d That one guy
    Have you tried a better 3.5mm cable? The cheap ones will flex.
  3. May 27, 2015 at 11:01 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  4. May 28, 2015 at 1:04 AM
    HawaiiTRD
    Hawaii
    2022 MGM DCSB TRDOR
    I did buy one because I thought my old cord was no good. The problem persisted which clued me in to checking the plug. That's when it occurred to me that the cover leans down on the cord. Once I lifted the cover up, all the sound problems went away. I suppose a cord with a longer male connector might work fine as well.
    I originally wanted to upgrade the whole sound system and get a double DIN, but opted to save the money.
  5. May 28, 2015 at 9:00 AM
    OZ-T
    Peter North
    British Columbia
    The USA Specs come up for sale every so often in the BST , that's where I got mine
  6. Jun 2, 2015 at 11:14 AM
    TuffRuffDangerous
    TuffRuffDangerous Well-Known Member
    San Diego, CA
    2011 TRD Off Road 4x4 DCSB
    Salex glovebox/console organizers, Philips H4 MotoVision headlight bulbs, Optilux H10 Extreme Yellow XY foglight bulbs, csjumper2003 LED domelight & license plate bulbs
    I thought AUX sounded like crap too til I found out that each function (AM, FM1, FM2, Disc, and AUX) has their own sound profile setting. I'd set the stereo (2011 JBL 6 CD changer with XM) to BAS 0, MID 5 and TRE 5 while in Disc mode, thinking this setting will stay this way even if I select another source. Then I discovered FM 2's settings were all at 0. Checked AUX and it was the same thing. So I changed the settings while in AUX and now it sounds a lot better than before.
  7. Jun 7, 2015 at 10:03 PM
    HawaiiTRD
    Hawaii
    2022 MGM DCSB TRDOR
    I didn't realize the settings were unique to each mode. Thanks for the info.
  8. Jun 13, 2015 at 6:14 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    I did not know this either. I will have to check this tomorrow. my problem is AUX sounds good but FM sounds like the speakers are blown.
