Tacomas burn oil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Operator7373, Feb 16, 2022.
  1. Feb 16, 2022 at 10:39 AM
    Operator7373
    Operator7373 [OP] Member
    17 tacoma
    Hello everybody I'm new here. I recently bought a 2017 Tacoma and noticed that on start up it seems to burn oil. is it normal for Tacoma's to burn oil? is it gonna be an issue? Any help is greatly appreciated.
    CygnusX191 likes this.
  2. Feb 16, 2022 at 10:47 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    How do you know its burning oil?
    I have been here awhile and yours would be the first I have read about here. They can burn oil but only in super steep conditions offroad.
    CygnusX191, JoeCOVA and Skydvrr like this.
  3. Feb 16, 2022 at 10:48 AM
    Operator7373
    17 tacoma
    The Problem is when I start it and for about 30 seconds after words little puffs of white smoke come out. Is it normal for that to happen? Weather is about 60° so it's not that.
  4. Feb 16, 2022 at 10:50 AM
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
    Did you recently have an oil change done?
    Sounds like maybe residual oil burning off. Have you checked for fluid leaks? Can / have you smelled the smoke and can you describe it to us?
  5. Feb 16, 2022 at 10:50 AM
    Operator7373
    17 tacoma
    Also it only does it when the engine is cold.
  6. Feb 16, 2022 at 10:54 AM
    Operator7373
    17 tacoma
    The dealership supposedly did a oil change before I bought it. I've only put 200 miles on it. The smell of the exhaust Smells kind of rich but then again all I owned was Chevy's before now.
  7. Feb 16, 2022 at 10:54 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You have port and direct injection going on the startup. You may see the same during the cleaning cycle of direct injectors
  8. Feb 16, 2022 at 10:55 AM
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    Lol. Normal. Condensation in the exhaust system burning off on a cold start. All vehicles do this... Burning oil would be blueish smoke & you'd smell it.
  9. Feb 16, 2022 at 10:55 AM
    ironhead181
    ironhead181 Well-Known Member
    2021 Tacoma DBL Cab
    none
    Blue smoke is oil and will hang around after you start the truck. If it's white and it goes away it's usually condensation.
  10. Feb 16, 2022 at 11:01 AM
    Operator7373
    17 tacoma
    Thanks for the quick responses.
  11. Feb 16, 2022 at 11:05 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    White smoke that disapates quickly is water condensation, a normal byproduct of internal combustion. It is more noticeable on coolers days and after a cold start up. On cooler days, the condensation can form larger clouds, especially during acceleration.
    Blue smoke that hangs in the air after start up would be oil burning.
    White smoke that hangs in the air and smells sweet is coolant burning.
    And grey to black smoke that hangs in the air is unburnt fuel.
  12. Feb 16, 2022 at 11:11 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    White smoke is generally coolant getting in the combustion chamber. usually if coolant it will have a sweet smell. Blue smoke can be oil, or the engine is running rich. I'd keep an eye on the level for both.
  13. Feb 16, 2022 at 11:19 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    it is normal. That is not oil that is simply condensation from your exhaust. oil burns bluish smoke.
  14. Feb 16, 2022 at 11:21 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    And invisible smoke in the hall that smells like sulfur is me crop dusting the office...
  15. Feb 16, 2022 at 11:32 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    And pure black sooty smoke is an indicator to get the fire extinguisher ready, or run like hell!!
  16. Feb 16, 2022 at 11:36 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    ^^ This.
  17. Feb 16, 2022 at 11:39 AM
    Vlady
    Issy, WA
    OP, look for a pdf somewhere in stickies and learn all about your engine and systems.
    This will calm you down..
  18. Feb 16, 2022 at 11:44 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    used with unquantifiable factors
    total miles ( ???????) .....................type of usage
    mostly bump/grind commuter...................or hi-way
    type oil used from break in to date
    all could contribute to start up oil smoke
    look at plugs in proper order their condition tells much
    while they are out cold leak down test.......cold compression test will tell more
    label/number plugs
    write down data for both tests
  19. Feb 16, 2022 at 11:50 AM
    Operator7373
    17 tacoma
    After much research and your responses, I've decided it's definitely condensation. What type of 0w20 do you guys like the most?
    CygnusX191, aggr0crag and Speedfreak like this.
  20. Feb 16, 2022 at 11:52 AM
    18CHUÑO
    18CHUÑO Well-Known Member
    Antoine
    2016 Tacoma SR5 i4 AC 4x4 Super White
    My old Jetta had a leaking oil pan and on start up would release a cloud of blueish white smoke that would linger for a bit. Was even worse in summer heat after the car sat for a day or two.
    Neighbors hated it
    CygnusX191 and ConantTaco like this.
