Tacomas in Minnesota?
Discussion in 'Mid West' started by LonghornTaco, Oct 9, 2008.
  1. Jan 19, 2020 at 11:35 AM
    #2341
    USDashCamera
    USDashCamera Put it in H
    2017 Quicksand TRD OR
    none that I have seen. I have a wireless back up camera in my work truck and even tho its one of the better brands it still sucks haha. gets the job done but I couldn't imagine 1080p or 1440p rear cams would be very good wireless.
    It's not too hard to install the rear cams tho, you can pretty much get by just using your fingers to push the wire into the soft headboard above the doors. I had zero experience before I installed my first dual channel dash cam and it was easy.
    Even with my current setup with a topper, i had no problem pulling off a few plastic trim pieces, finding the hole in the floor that other wires went thru, wiring the cable to the back of the truck, and installing the rear cam in my toppers rear window.
    you really don't need to take anything apart other than in my case the floor/door sill, but my install was more complex.
  2. Jan 19, 2020 at 11:36 AM
    #2342
    GQ7227
    GQ7227 mw survivor
    J A Y
    my headliner is super tight!
  3. Jan 19, 2020 at 11:40 AM
    #2343
    USDashCamera
    GQ7227[QUOTED] likes this.
  4. Jan 19, 2020 at 11:45 AM
    #2344
    GQ7227
    GQ7227 mw survivor
    J A Y
    i picked up one of those sets of nylon pry tools from harbor freight recently
    recently I read on TW that if the headliner is disturbed in the back it will probably droop :(
    maybe along the bottom floor would work better, that paneling has to come out eventually
  5. Jan 19, 2020 at 11:54 AM
    #2345
    USDashCamera
    I guess I never had to install to the back of my cab, but installed rear cams in my prius and previous civic. When I got my tacoma I didn't install the rear cam because I knew I was getting a topper a few weeks after I got the truck.
  6. Jan 19, 2020 at 12:01 PM
    #2346
    GQ7227
    GQ7227 mw survivor
    J A Y
    not the exact picture of my rear interior, but is the same set up
  7. Jan 19, 2020 at 12:08 PM
    #2347
    Shellshock
    Iowa
    You can just shove it in there. It’s easy.
    usually I pull out the A pillar but you can tuck wire behind that too if you don’t want to pull it out
  8. Jan 19, 2020 at 12:33 PM
    #2348
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    Battery is In the cab
  9. Jan 19, 2020 at 12:37 PM
    #2349
    GQ7227
    GQ7227 mw survivor
    J A Y
    its too Cold to shove anything!
  10. Jan 19, 2020 at 12:41 PM
    #2350
    Shellshock
    Iowa
    Turn your heat on in the truck
  11. Jan 19, 2020 at 12:44 PM
    #2351
    GQ7227
    GQ7227 mw survivor
    J A Y
    :facepalm:
  12. Jan 19, 2020 at 1:01 PM
    #2352
    USDashCamera
    My big goal is to keep my interior stock looking as possible, where on the cab did you put it?
    GQ7227 likes this.
  13. Jan 19, 2020 at 2:01 PM
    #2353
    DCLBFTW
    Minnesota
    06 dclb
    Behind the rear seats I have 2 group 31agms
  14. Jan 21, 2020 at 12:36 PM
    #2354
    Tigerian
    Tigerian Well-Known Member
    Iowa, unfortunately
    2024 GR Corolla
    I know I’m several days late to your question but it because of the lake. Superior has a massive impact on temperatures. Any time there is a sudden temperature change like that places like Duluth aren’t going to see it as quick.
  15. Jan 21, 2020 at 12:58 PM
    #2355
    Shellshock
    Iowa
    BuT oMaHa Is By A bIg RiVEr
    :duh:
    GQ7227 and corprin like this.
  16. Jan 21, 2020 at 2:10 PM
    #2356
    GQ7227
    GQ7227 mw survivor
    J A Y
    its the longest river in the USA, i cross it 4 times on my usual way to St Louis, where i am still on banishment the last time i checked
    google says... Thus measured to its highest headwaters, the Missouri River stretches for 2,639 miles (4,247 km). When combined with the lower Mississippi, the Missouri and its headwaters form part of the fourth-longest river system in the world, at 3,745 miles
    that Alberta Clipper is a cruel monster, it should be lifting later today here though so it can snow
  17. Jan 23, 2020 at 1:19 PM
    #2357
    JC34X4
    JC34X4 Well-Known Member
    J
    Minneapolis
    96 Tacoma 5spd 4x4 single cab.
    2WD or 4x4 today???
  18. Jan 23, 2020 at 1:31 PM
    #2358
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you have an e-locker?
    i could've used it today on a couple of slushy residential hills
  19. Jan 23, 2020 at 1:39 PM
    #2359
    mattehww
    mattehww Well-Known Member
    Minneapolis, MN
    2018 SR5 Access Cab 4x4
    2WD, but then again I have snow tires and run a couple sand bags in the back as well
  20. Jan 23, 2020 at 2:32 PM
    #2360
    JC34X4
    J
    Minneapolis
    No locker. U have one?
