Tacomas in Minnesota?
Discussion in 'Mid West' started by LonghornTaco, Oct 9, 2008.
  1. Oct 20, 2020 at 4:55 PM
    #2721
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Big Horns are awesome. Totally different feel to me than the Rockies. Rockies are bigger, obviously, but in the Big Horns you feel closer to the mountains. It’s like you’re right IN them and up close instead of looking at them. Hard to explain.
    But if you guys have the opportunity, check them out. So many cool campgrounds, lakes, rivers, steams, trails. And you’ll often find yourself very alone there.
  2. Oct 20, 2020 at 11:24 PM
    #2722
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I got my taco stuck tonight. My buddy with a Jeep Wrangler couldn’t get it out, but we lacked a kinetic strap or winch. I only had a static strap and traction boards. I called a towing company, but their 4x4 wrecker kept getting stuck trying to get to my taco. The driver suggested I call a towing company in Rogers, MN saying they are the only ones he knows that could help me. The truck is in Washington county. Ouch!
    I’ve been stuck many times, but not this stuck. The truck is resting on the front cross member, mid-frame, and rock sliders and the front wheels are about 1 foot off the ground. The rear wheels are sitting on level ground, but getting almost zero traction. The whole area has about 6” of snow on top of tacky mud.
    Anyone looking for a challenge or a good laugh?
    BSFord likes this.
  3. Oct 21, 2020 at 4:20 AM
    #2723
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Aw yikes man, on the first real snow too. What are you dangling over? Looks like some sort of ditch?
  4. Oct 21, 2020 at 5:53 AM
    #2724
    northwoods_
    northwoods_ Well-Known Member
    cole
    2020 DCSB
    Oof, where are you at?
  5. Oct 21, 2020 at 6:50 AM
    #2725
    Shellshock
    Iowa
    You could just wait a couple days until the snow melts lol then it’ll be easy
    BSFord likes this.
  6. Oct 21, 2020 at 6:58 AM
    #2726
    gudujarlson
    Minnesota
    And then wait for the mud to dry. ;)
  7. Oct 21, 2020 at 6:59 AM
    #2727
    gudujarlson
    Minnesota
    Ya it’s a 4 foot deep crevice that was dug by a back hoe or something.
    doublethebass[QUOTED] likes this.
  8. Oct 21, 2020 at 7:01 AM
    #2728
    gudujarlson
    Minnesota
    Washington county near Woodbury
  9. Oct 21, 2020 at 7:04 AM
    #2729
    gudujarlson
    Minnesota
    I don’t see much way to jack it up and put something under the front wheels. I think it has to be winched backwards. There is a flat area behind it, but getting to it was too tricky for the 4x4 wrecker. I think the main issue was the street tires. I’ve got a good recovery point in the rear. I just need to find a towing company with a better wrecker. Matt’s off-road recovery?
  10. Oct 21, 2020 at 7:10 AM
    #2730
    Shellshock
    Iowa
    Is this a field or what? Not sure where you are stuck.
  11. Oct 21, 2020 at 7:10 AM
    #2731
    Shellshock
    Iowa
    @uploadadventure time to put your winch to work!
  12. Oct 21, 2020 at 7:43 AM
    #2732
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    You got pictures?
  13. Oct 21, 2020 at 7:44 AM
    #2733
    uploadadventure
    Dixon, Mo
    Oi.
  14. Oct 21, 2020 at 7:57 AM
    #2734
    gudujarlson
    Minnesota
    I posted one above and here is another.
  15. Oct 21, 2020 at 8:03 AM
    #2735
    gudujarlson
    Minnesota
    I took a shortcut through a large construction site on my way to my girlfriends. It’s 300 or so yards from the road on top of a small hill. Getting to it and maneuvering around it is tricky due to the snow, mud, and slopes. My truck was not having a lot of trouble (until it fell into the crevice), but the 4x4 wrecker was having a hell of time due to having streets tires, long wheel base, and possibly also because of weight.
    Amazingly, the front bumper doesn’t appear to be damaged beyond what it was already. I’m a little concerned it might get damaged during recovery, but I plan to install an aftermarket high clearance bumper, so as long the damage is limited to the bumper I won’t be too sad. The rock sliders did their job for the rocker panels
    doublethebass likes this.
  16. Oct 21, 2020 at 8:07 AM
    #2736
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Looks like a big board on the bottom of the trench, couple bottles jacks with another board under the tires. Maybe, but maybe not :eek:
  17. Oct 21, 2020 at 8:16 AM
    #2737
    gudujarlson
    Minnesota
    Something like that has occurred to me, but the wheels are at least a foot off the ground and the ground is really mushy. So I think it would require something taller than a single board on the ground. And then I worry what would happen when I tried to drive off the top board.
    Another option is to jack it up using the rock sliders and then build a makeshift bridge across the crevice. Would a pair of 2x12 planks be strong enough? I know they make steel planks for this purpose as well.
    I decided to call another wrecker. ;)
  18. Oct 21, 2020 at 8:18 AM
    #2738
    Shellshock
    Iowa
    Oof
    uploadadventure likes this.
  19. Oct 21, 2020 at 8:20 AM
    #2739
    Iwilltaco
    Under development
    Probably a good idea. I guess if you did get it lifted on the board, being pulled backwards would be better than trying to drive. But a wrecker should work. I nice heavy duty front bumper with a jack attachment would work :thumbsup:
  20. Oct 21, 2020 at 8:23 AM
    #2740
    Shellshock
    Iowa
    Looks like its time for some 40s on the taco so it could clear the gap lol
