Tacomas in Minnesota?
Discussion in 'Mid West' started by LonghornTaco, Oct 9, 2008.
  1. Mar 16, 2021 at 8:55 AM
    #3041
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    No pics. It was dark out. I’ll snap some today when I get back out there.
  2. Mar 16, 2021 at 8:57 AM
    #3042
    gudujarlson
    Minnesota
    I’ve had trucks in similar circumstances I have gotten them out with a lot digging, jacking, and tugging. A winch would be handy, but I’ve never owned one. I have a hi-lift jack with a winching kit which I have never needed to use (yet).
  3. Mar 16, 2021 at 9:01 AM
    #3043
    gudujarlson
    Minnesota
    The ground around the truck kinda reminds me of a peat bog or maybe one of those dry lake beds they have out west. I can walk around on top of it for the most part, but every once in a while my foot falls through up to my shin. I’m not sure how I didn’t get stuck during the previous 300 yards I drove across it.
    doublethebass likes this.
  4. Mar 16, 2021 at 9:09 AM
    #3044
    corprin
    corprin Well-Known Member
    corprin
    Any anchors in the area from which to attach a winching vehicle to?
  5. Mar 16, 2021 at 10:49 AM
    #3045
    gudujarlson
    Minnesota
    If I remember right, yes, but not super close.
  6. Mar 16, 2021 at 6:51 PM
    #3046
    gudujarlson
    Minnesota
    Here’s some pics of how I spent my afternoon. I was unable to get it out with jacking and digging. The mud on the driver side started as slightly frozen tacky stuff when we arrived and became 6-12” of soup that you couldn’t stand in without worrying about not being able to get out by the time I through in the towel. It was way worse than last night. You could literally see the truck slowly sinking in further. We had two farm jacks and neither was capable of lifting the driver side out of the muck. I ended up calling a tow truck that had 100+ yards of cable. The tug was super simple.
    FYI: hi-lift jacks aren't worth jack after they get muddy.
    I think a winch has gotten higher on my priority list.
  7. Mar 16, 2021 at 7:04 PM
    #3047
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    That's a lot more mud than what I was thinking of.
    JC34X4 likes this.
  8. Mar 16, 2021 at 7:17 PM
    #3048
    Tigerian
    Tigerian Well-Known Member
    Iowa, unfortunately
    2024 GR Corolla
    That looks like a construction area. I’m starting to notice a pattern here.
  9. Mar 16, 2021 at 7:25 PM
    #3049
    gudujarlson
    Minnesota
    I've been taking that route back and forth to my girlfriend's place all winter. It's a "shortcut".
  10. Mar 16, 2021 at 7:27 PM
    #3050
    Shellshock
    Iowa
    It’s a shortcut til you get stuck. Then it’s an expensive long cut
    doublethebass, Tigerian and Aqualoon like this.
  11. Mar 16, 2021 at 7:27 PM
    #3051
    Aqualoon
    Minnesota
    Hmm...
    Tigerian[QUOTED] and Shellshock like this.
  12. Mar 16, 2021 at 7:33 PM
    #3052
    gudujarlson
    Minnesota
    I think I need to go back to 2wd trucks. I got stuck more but it was much easier to get unstuck. It's pretty amazing how much trouble 33" mud terrains, a rear locker, ATRAC and 2" of lift will get me into. I drove through the mud and snow a good 300 yards to get to that spot.
    Aqualoon[QUOTED] likes this.
  13. Mar 16, 2021 at 7:40 PM
    #3053
    gudujarlson
    Minnesota
    The driver said his winch is rated at 20,000 pounds per line. It had no trouble tugging me out. I'm curious if a 8-10k winch mounted to a aftermarket front bumper would have worked as well.
  14. Mar 16, 2021 at 7:42 PM
    #3054
    Tigerian
    Iowa, unfortunately
    2024 GR Corolla
    Or crazy idea here: stop taking shortcuts through construction areas. How many “shortcuts” that you end up stuck in is it going to take for you to figure that one out?
    Rondo_Taco likes this.
  15. Mar 16, 2021 at 7:45 PM
    #3055
    Shellshock
    Iowa
    You could have had a 16k winch on the front and it wouldn’t have mattered. There was no anchor points lol
  16. Mar 16, 2021 at 7:47 PM
    #3056
    gudujarlson
    Minnesota
    What else am I going to use my mud terrains, rear locker, and ATRAC for? Circling the mall? I built the truck to take it off road (and also be a daily driver and tow the boat). There's always a risk of getting stuck and I learn something each time I do get stuck.
    doublethebass and Aqualoon like this.
  17. Mar 16, 2021 at 7:48 PM
    #3057
    gudujarlson
    Minnesota
    There were many anchor points. Look at all the concrete pipes in the photos. Also I think a pull pall might have worked too. The ground in much of the area was quite solid but soft enough to drive an anchor in.
  18. Mar 16, 2021 at 7:52 PM
    #3058
    Shellshock
    Iowa
    Those wouldn’t hold, they would pull right to... and as soft as that ground was, so would a pull pal
    a deadman *might* have held if you got it deep enough but buried to the frame in mud is a heck of a lot of force and you’d just be pulling more into it than back out of it.
  19. Mar 16, 2021 at 7:52 PM
    #3059
    GuacIsExtra
    GuacIsExtra Well-Known Member
    2021 TRD Off-Road 6MT Cement DCSB
    Sure, that's the logical solution. But what fun would that be?
    doublethebass, JC34X4 and Shellshock like this.
  20. Mar 16, 2021 at 7:54 PM
    #3060
    gudujarlson
    Minnesota
    Some of them are buried in the ground as part of the sewer system (e.g. the one to the front and left of the truck). I don't think those are going anywhere. The other ones were in some cases in frozen ground. The ground was very unpredictable between frozen solid and soup.
