Tacomas in Minnesota?
Discussion in 'Mid West' started by LonghornTaco, Oct 9, 2008.
  1. Mar 16, 2021 at 7:57 PM
    #3061
    Tigerian
    Tigerian Well-Known Member
    Iowa, unfortunately
    2024 GR Corolla
    I don't exactly see fun in destroying people's property. Digging massive ruts into the ground causes a lot of damage and is a pain in the ass to fix.
    You plan on pulling to the side and behind you with a bumper winch?
  2. Mar 16, 2021 at 7:59 PM
    #3062
    Shellshock
    Iowa
    Good luck
  3. Mar 16, 2021 at 8:00 PM
    #3063
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It's an unfinished road that they still need to grade, cover in sand, and then pave. Before they even get to that, some enormous earth movers will likely create much bigger ruts in it.
  4. Mar 16, 2021 at 8:03 PM
    #3064
    Tigerian
    Iowa, unfortunately
    2024 GR Corolla
    You clearly know nothing about road construction if you think they operate in rutting conditions.
  5. Mar 16, 2021 at 8:08 PM
    #3065
    gudujarlson
    Minnesota
    I don't know much at all about road construction, but I have seen plenty of ruts (maybe rut in the wrong word; giant depressions in the earth?) created by earth movers. They are all over that area.
  6. Mar 16, 2021 at 8:16 PM
    #3066
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    Looking cool AF?
    Shellshock likes this.
  7. Mar 16, 2021 at 8:20 PM
    #3067
    gudujarlson
    Minnesota
    Ya I even had a bit of anxiety about winching it because it seemed so stuck in the ground. The hi-lift jack refused to overcome the suction and partial frozen ground. I wanted to jack it up and put it on traction boards. It came right out without making any terrible noises. They used the stock recovery hook and it didn't break.
  8. Mar 16, 2021 at 8:22 PM
    #3068
    Tigerian
    Iowa, unfortunately
    2024 GR Corolla
    Rutting is deep tire tracks that causes severe compaction and is always a result of soft/wet ground. What you're talking about is seeing tire tracks from large machinery driving over loose soil. Compaction is a pain to fix. That is why you don't see construction/farming/logging happening in really wet and soggy conditions.
  9. Mar 16, 2021 at 8:23 PM
    #3069
    gudujarlson
    Minnesota
    Oh and actually there was an excavator working that afternoon to dig a basement; granted it looked like they might have put down some gravel for it to sit on.
  10. Mar 16, 2021 at 8:28 PM
    #3070
    Tigerian
    Iowa, unfortunately
    2024 GR Corolla
    Sitting in a mostly stationary spot digging is not the same thing as driving around.
  11. Mar 16, 2021 at 8:33 PM
    #3071
    gudujarlson
    Minnesota
    Can you explain to me then why I have seen them out there working on numerous occasions after a rain or snow (driving around in big earth movers)? I was actually surprised the first time I saw it. I figured they would take a day off if it was super wet (I avoided it those days) . The soil itself seems to have a high percentage of clay and not much organic matter. It was easy to tell that it had been moved around when wet and then allowed to dry.
  12. Mar 16, 2021 at 8:47 PM
    #3072
    Tigerian
    Iowa, unfortunately
    2024 GR Corolla
    Rain or snow doesn't always make the conditions bad enough to warrant halting work. It is dependent on the soil type, the amount of precipitation, how much moisture is already in the soil, the temperature, and a number of other things. Some soils hold on to water for long periods of time while others it goes right through. Also keep in mind most of the large machinery are running with large floatation tires or tracks that are designed to spread the weight out across large areas. A lot of the machinery I work with will drive right over stuff without sinking in at all where a mid or full-size truck would bury itself.
  13. Mar 16, 2021 at 9:14 PM
    #3073
    Shellshock
    Iowa
    Heavy machinery runs tracks or multiple large tires. This distributes the weight over a much much larger surface area and reduces the pressure per inch
    that’s why a snowmobile or snowcat can drive over powder and everything else sinks like a rock. Or walking and post holing vs snowshoes.
  14. Mar 16, 2021 at 9:39 PM
    #3074
    gudujarlson
    Minnesota
    Well yes obviously, but are you saying that those very heavy machines do not compact the soil more than my 4600 lb truck?
  15. Mar 16, 2021 at 9:40 PM
    #3075
    Shellshock
    Iowa
    That’s exactly what I’m saying. Even though it weighs much more, the surface pressure is much less than the 4 tires on your truck exert on the ground below.
  16. Mar 16, 2021 at 9:48 PM
    #3076
    gudujarlson
    Minnesota
    Ok yes that makes sense. Most of that is quite obvious in fact. However I'm not sure how it is applicable to soil compaction, which I think is your concern. Let me ask you this... Why worry about soil compaction of soil that is going to have pavement on top of it with storm drains? When I hear about the problem soil compaction its usually in the context of a trail through the forest (foot or wheeled). This land has been stripped clean of top soil and completely remolded to make an another section of a city. I assume they will dump a bunch top soil on it eventually to make it easier to grow grass on.
  17. Mar 16, 2021 at 9:52 PM
    #3077
    gudujarlson
    Minnesota
    Ok, yes a truck might sink in more because of the lower surface area, but does a 4600 pound truck result in more square area of soil compaction than a ??? lb earth mover?
    I think we might off in the weeds here a bit. We are talking about the compaction of soil that will be under pavement with storm drains (I think).
  18. Mar 16, 2021 at 9:56 PM
    #3078
    Shellshock
    Iowa
    No we were walking about why your truck gets stuck in the mud and the heavy machinery can drive right over it and not get stuck.
  19. Mar 16, 2021 at 9:58 PM
    #3079
    gudujarlson
    Minnesota
    I was referring to the storm drain buried (guessing) 6-10' in the ground. You can just see the top 12-24" of it in the photo. I don't think that's going to move easily.
    I agree the pipes sitting on top of the ground might not work. Maybe if I used 5 of them; especially the really big ones?
  20. Mar 16, 2021 at 10:01 PM
    #3080
    gudujarlson
    Minnesota
    Oh that's not what I was talking about. Tigerian raised the issue that driving my truck on the unfinished road when it is wet causes soil compaction and that is why you don't see construction when it is wet. I asked him to explain why I have seen construction on wet ground numerous times. That lead to the discussion of tracks vs wheels and I thought you will implying that large tracked vehicles cause less soli compaction than small wheeled vehicles.
