TacomaWillow's camper build, camper done! (for now) dog bonus
Discussion in '3rd Gen. Builds (2016-2023)' started by TacomaWillow, Aug 24, 2022.
  1. Sep 14, 2022 at 7:02 PM
    TacomaWillow
    TacomaWillow [OP] Well-Known Member
    Catherine
    2022 4WD 6 cyl SR5
    Thanks! The battery is a Vestwoods, 250 ah with a 200 amp charge/discharge capacity. Will Prouse took one apart and said it had good build quality and a very high quality BMS. It has under and overtemp cutoffs and it also has a bluetooth monitoring app, so I don't have to have a shunt in the system.
    I got the Renogy 30 amp DC-DC / MPPT charge controller, Victron 15 amp shore power charger, and Renogy 2000 watt inverter. Haven't tested the Renogy charge controller yet but the Victron charger, the battery and the inverter all work great together. The battery is a killer value.
    I used FarOutRide to guide my electrical system design, their plans have really detailed information.
  2. Sep 14, 2022 at 7:19 PM
    Dynactus
    Dynactus Member
    2015 TRD Off Road
    Ella is a pretty dog. Congrats on your new truck.
    BigEasy and TacomaWillow[OP] like this.
  3. Sep 14, 2022 at 7:42 PM
    Mbn1972
    Mbn1972 Member
    Martin
    2017 Tacoma DCSB 4X4 TRD Offroad
    Will Prouse's recommendations are rock solid. Sounds like you are building a killer system that will last. It's a very wise choice that you chose a DC to DC charger that has integrated mppt for solar. 30 amps dumping back into your battery is huge. I got a 25 amp redarc DC to DC and it charges my 100 amp hour LiFePo battery so quickly. Love the blue tooth for the BMS
  4. Sep 15, 2022 at 5:28 PM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    Thanks! She's such a sweetie.
  5. Sep 15, 2022 at 5:32 PM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    Honestly I'm a little worried my stock alternator is going to be taxed by the 30 amp - do you have the stock 125 amp (I think) alternator? Im going to make sure not to run a lot of accessories in the cab when I'm charging, especially if I'm also running the AC.
  6. Sep 15, 2022 at 7:41 PM
    Mbn1972
    Mbn1972 Member
    Martin
    I have the stock alternator on my 2017 DCSB. I only have a ICECO VL 45 fridge and LED lights in the back of my camper. The fridge is very efficient. How many watts and amps is your AC going to be pulling?
  7. Sep 16, 2022 at 2:43 PM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    I just mean the factory cabin AC, which also takes a lot of alternator juice. Continually drawing heavy total amps off an alternator can cause it to fail, so if Im drawing 30 to charge I dont want to max out every other draw to tax it. So not run the cabin ac while wearing two heating blankets plugged into the cigarette lighter and blasting the stereo. Maybe I'm being overly cautious.
  8. Sep 16, 2022 at 11:51 PM
    Mbn1972
    Mbn1972 Member
    Martin
    Ahhh.. I understand. Always smart to err on the side of caution
  9. Sep 17, 2022 at 7:08 AM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    Camper electrical setup done.
    NOTE: I am aware my wiring looks like mom's spaghetti. Now that everything is working I will work on repositioning a few things.
    Here are two screenshots from the battery BMS bluetooth app showing what I see when I am charging from shore power or from the alternator. Fortunately the DCDC renogy charger is defaulting to charge at 15 amps instead of 30, which given the stock alternator I am more comfortable with. This was tested at idle so maybe it will bump up on the highway? It also didn't start charging until the car had run for a couple of minutes after I started the truck, and gave a "low voltage" light at first - so it's not going to compete for cranking amps against the starter battery. All in all I'm really happy about it.
    List of components:
    250 ah lithium battery with 200 amp charge / discharge capacity. 250 amp terminal breaker.
    2000 watt renogy pure sine wave inverter
    Victron 15 amp 110 volt charger
    30 amp Renogy combined DCDC and MPPT solar charger
    A 12 volt aux circuit in the cab so I can play music and charge my phone for hours without running down the truck battery
    Wire run to the bed for the future 12 volt / 30 amp distribution panel
    Wirw run from the inverter to the bed for future 110 volt outlets, including a remote on/off control for the inverter.
    I have appropriately sized breakers on all the components and a main power switch, so I can easily isolate and trouble shoot. Shockingly, everything worked perfectly the first time, but there's always something later on.
    This was a lot of work! I spend hours and hours just making cables.
    Now I can build Ella's bed platform, for which she has been waiting impatiently, by which I mean she has been - apparently by coicidence - standing behind or in front of the truck every time I try to leave since I took her bed out.
    edited to add gratuitous pics of Ella
  10. Sep 17, 2022 at 7:54 AM
    Mbn1972
    Mbn1972 Member
    Martin
    Keep the updates and pics coming.!
  11. Sep 17, 2022 at 4:44 PM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    Finally! Tidied the wiring, built the hinged platform, put the dog back in the truck, BOOM!
    (oh and also put some sound deadening mat on the back wall)
    Steves104x4 and POOLGUY like this.
  12. Sep 21, 2022 at 10:55 AM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    Got the Leer 122 installed today! The truck looks a little dorky with it on, but it's exactly what I need for the camper. Including my smiling face so you can see how much head room it has. I am sitting on top of the wheel well, and I'm 5'6".
    Twins09, Redfox88, BigEasy and 3 others like this.
  13. Sep 21, 2022 at 8:31 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Cool!
    TacomaWillow[OP] likes this.
  14. Sep 21, 2022 at 8:50 PM
    Mbn1972
    Mbn1972 Member
    Martin
    I like the topper with the extra headroom and lots of windows... Looks like you have some slider windows with screen for ventilation too. Nice!
  15. Sep 21, 2022 at 8:54 PM
    #35
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Great job!
  16. Sep 22, 2022 at 8:07 AM
    #36
    4x4spiegel
    4x4spiegel Well-Known Member
    @TacomaWillow you and Ella are doing a fabulous job keep the updates and pics rolling
  17. Sep 22, 2022 at 8:16 AM
    #37
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    The BedRug is in, and a new player has entered the scene: Killer approves. First step after the BedRug was connecting a 12 volt port to power some working music (ok, podcasts because I'm a nerd). Next step, building the bedframe with aluminum angle.
    POOLGUY and 4x4spiegel like this.
  18. Sep 23, 2022 at 3:33 AM
    #38
    POOLGUY
    JEFF
    ALABAMA
    Looking good! :thumbsup:
  19. Sep 23, 2022 at 5:09 AM
    #39
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    These caps don't come with a handle to close them from the inside. I used 3M high bond value tape to attach one left over from my kitchen project.
    Tape is strong *enough*, and that's a principle of my approach to a build. You know what most camper build-outs start with: a bed load of lumber. 3/4" plywood, 2x4s, hell I've seen a build using 2x12s. Stop it with that! We are not trafficking gorillas by steamership from the Congo!
    The Bedrug weighs almost nothing and is well insulated and is fine, I don't need a plywood floor. I'm not, as I mentioned, a gorilla, so a bed that would be strong enough in a house is certainly strong enough for occasional use in the camper.
    I'm building the bed from aluminum angle and 80/20, with bed slats instead of a platform. I want to keep the total weight of my build, including the 200 pound cap, my bedding and recreational gear, and consumables like water and food, well under 500 pounds. I think using aluminum framing, and 1/4" or 3/8" fronts where needed, will make that possible.
    I will also be using the tie-down rail to support the backs of the bed and furnishings.
    My initial pass may not have enough rigidity, but the beauty of 8020 is how easily I can add reinforcing members after the fact as needed.
    Gratuitous Ella and Killer on the farm.
    eta: yikes the handle looks crooked in this pic! And that VHB tape is there to stay. I promise it looks better from inside.
  20. Sep 23, 2022 at 9:45 AM
    #40
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    Bed frame complete, and supports my weight just fine. Much sturdier than I expected. Using twin channel 8020 provides a lot of rotational rigidity.
    Mbn1972 and POOLGUY like this.
