Tacos in St. Louis area
Discussion in 'Mid West' started by headhunter247, Jan 1, 2009.
  1. Jun 25, 2020 at 12:41 PM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Again, another instance where a "death wheel" emoji would properly serve us.....
  2. Jun 25, 2020 at 12:44 PM
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Definitely helped me after the lift install.
    I hit a bump on the highway and my truck wanted to dip right. Checked my panties afterwards, almost got a little brown on my pink fabric.
  3. Jun 25, 2020 at 2:39 PM
    G.T.
    G.T.
    CONUS
  4. Jun 25, 2020 at 7:08 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Anyone have any 3rd gen TPMS sensors they are willing to part with?
  5. Jun 25, 2020 at 7:11 PM
    Shellshock
    Iowa
    :confused:
    95tojo and CygnusX191 like this.
  6. Jun 25, 2020 at 8:08 PM
    uploadadventure
    Dixon, Mo
    I need 1.
    Wanted to see if I could pick one up locally before I buy from eBay / Amazon
    CygnusX191 likes this.
  7. Jun 26, 2020 at 6:50 AM
    TacomaDad18
    TacomaDad18 overlanderrr asf
    1uz 2018 SR5
    Hard round things Soft round things Metal bouncy things Shifty thing Locking thing
  8. Jun 26, 2020 at 6:51 AM
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Ain't gonna be this weekend. Allegedly thunderstorms saturday into sunday.
    Do have a huge bonfire to burn though, maybe next weekend....
    CygnusX191 and Sasquatch3153 like this.
  9. Jun 26, 2020 at 6:53 AM
    uploadadventure
    Dixon, Mo
    :mudding:
  10. Jun 26, 2020 at 7:11 AM
    Shellshock
    Iowa
    Gonna have the teryx by then?
  11. Jun 26, 2020 at 7:20 AM
    uploadadventure
    Dixon, Mo
    :notsure:
    Sasquatch3153 and TacomaDad18 like this.
  12. Jun 26, 2020 at 8:59 AM
    TacoDia
    TacoDia Well-Known Member
    St. Louis
    11 DCSB SR5 V6 OME Kit H-Dakars
    Morning boys, question for ya. When it comes to power consumption I'm pretty uninformed. Been tossing the idea around of getting a Dometic CFX28 but currently don't have a dual battery setup. I do have the small Jackery 240 with panels. Just wondering how long could the fridge run before draining the Jackery or if I were to run it from the truck. I know many variables come in so lets say 40 degree internal temp with 90 external.
  13. Jun 26, 2020 at 9:12 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    @Shellshock
    Shellshock likes this.
  14. Jun 26, 2020 at 9:20 AM
    Shellshock
    Iowa
    I don’t run a dual battery system either. I could get 12+ hours run time off the shitty stock battery and a arb elements 63 in 100+ temps down in New Mexico
    I’ve since replaced that battery with a x2power 27f and I’ve yet to hit the low voltage cutoff
    Currently running a domestic 35 and I can get 2+ days off the battery I have.
    I don’t typically sit somewhere more than overnight, so I haven’t done any solar as of yet. If I was, I would do something like you describe with a battery pack and solar. There’s a lot of calculations you can do but with 100w of solar, you should be fine indefinitely unless there’s no sun running a fridge. I had 200 watts with the trailer I had and with mediocre sun things would be topped off in a couple hours
    if you look up how many amp hours your battery pack has, then assume 1 amp hour draw for the fridge (it’s actually a bit less usually) that’ll give you a rough estimate of run time
    mcharfauros and CygnusX191 like this.
  15. Jun 26, 2020 at 9:28 AM
    TacoDia
    St. Louis
    In regards to you last statement that was my initial thought. From what I found the pack has 16.8 amp hours. So as long as there is sun it sounds like I should be fine. The panel is a 60W so a bit slower but still decent enough. Overcast or cloudy days I might have to jump back and forth with the truck battery I guess.
  16. Jun 26, 2020 at 10:08 AM
    GilaTrails
    GilaTrails Well-Known Member
    Champaign IL / Safford AZ
    2018 Inferno Tacoma TRD Offroad
    Matching Colored Tire Valve Caps
    I finally got my email response from SOS on mounting their front hook point. In the end I had to go to Fastenal and order shorter bolts.
    SOS Concepts <sosoffroadconcepts@gmail.com>
    10:48 AM (59 minutes ago)
    to me[​IMG]
    Thanks for your email. The factory recovery mount bolts to the passenger side. They do not fit on the drivers side, if that helps.
    Thanks
    SOS
  17. Jun 26, 2020 at 12:25 PM
    95tojo
    95tojo Well-Known Member
    Jared
    So IL
    '19 Cement Grey TRD Sport 4x4 6MT
    Who makes a bed rack so that an RTT will sit flush(ish) with the bed rails ?
    Google search only came up with 1 company, 4x.
  18. Jun 26, 2020 at 12:44 PM
    ResearchMonkee
    Derrick
    KCMO
    Relentless Fabrication, my bars.
    Maybe I'm misunderstanding though.
  19. Jun 26, 2020 at 12:46 PM
    TacomaDad18
    1uz 2018 SR5
    me... lol jk I suck
    I will make my own for spare and rtt though.
  20. Jun 26, 2020 at 1:03 PM
    Shellshock
    Iowa
    ResearchMonkee and CygnusX191 like this.
