Tacos in St. Louis area
Discussion in 'Mid West' started by headhunter247, Jan 1, 2009.
  1. Sep 1, 2022 at 9:35 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    @CygnusX191 Mr mechanic man, how does the ebrake work work on 3rd gen Tacomas? Like does it just activate the same way with same parts as if you are hitting the brake pedal? Only reason I ask is I was messing with it a little on gravel roads and it feels somewhat violent. Like there is a little delay and then a thump when it activates and I was curious what exactly was occurring :D
  2. Sep 1, 2022 at 9:55 AM
    Shellshock
    Iowa
    It’s a cable that runs to the rear axel
  3. Sep 1, 2022 at 10:07 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    I knew that, I was just curious if the cable activated the exact same parts as braking or if there was a separate mechanism attached with the cable. I'm mainly just wondering if repeated use for tomfoolery would cause any damage and or issues lol. My thinking was it'd be fine because it would be just like hitting the brakes but wanted to confirm that was true.
  4. Sep 1, 2022 at 10:48 AM
    Shellshock
    Iowa
    Nah if anything it’ll save you the issues of it seizing up from never being used lol
  5. Sep 1, 2022 at 12:09 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It engages your rear drums. On rare submersible in the winter occasions, the spring release can freeze and "lock" your e brake on..... Just put it in lo range to pop it open and then you're good.
    That being said if you're fooling around with handbrake turns... Get somebody to film it. But no it really shouldn't hurt anything. Turn your traction control off for best results (press and hold overhead switch for 10 seconds)
  6. Sep 1, 2022 at 12:12 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
  7. Sep 1, 2022 at 12:19 PM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Just rub it in....
  8. Sep 1, 2022 at 12:32 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Fort Kickass is a bit smaller than it used to be...
  9. Sep 1, 2022 at 1:57 PM
    Shellshock
    Iowa
    Obviously that means you should have brought more stuff!
  10. Sep 1, 2022 at 3:05 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    More people should've brought themselves :boink:
    Progress is being made
    Slashaar and Sasquatch3153 like this.
  11. Sep 1, 2022 at 3:34 PM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Quite the setup you have there Timm....
  12. Sep 1, 2022 at 4:29 PM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    :pout:
    Right?!
  13. Sep 1, 2022 at 4:32 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Could be rubbing it in together but you're not here
    Wait......
  14. Sep 1, 2022 at 4:47 PM
    Missouriprerunner
    Missouriprerunner Well-Known Member
    Adam
    STL MO
    2018 dbl cab sr5
    I've always either camped solo or with friends for a float trip but this all looks awesome
    Slashaar and CygnusX191 like this.
  15. Sep 1, 2022 at 4:55 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
  16. Sep 1, 2022 at 6:20 PM
    Shellshock
    Iowa
    Are you just sleeping in that chair? Or the back of the truck gq style?
  17. Sep 1, 2022 at 6:32 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    There's a full party here now
    Slashaar likes this.
  18. Sep 1, 2022 at 6:53 PM
    Tacomania
    Tacomania IG: _tacomania
    Crazy Mike
    86 4runner / 2016 SR5 Tundra
  19. Sep 1, 2022 at 7:01 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    You're just jealous
  20. Sep 2, 2022 at 5:47 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    GQ style with a box of Rust Flakes. They're GRRRRREAT!
